Hoover SteamVac Carpet/Upholstery Deep Cleaner Vacuum Logo
Posted on Dec 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Hoover Platinum carpet cleaner, and it has stopped dispensing cleaning agent and water. This model has a separate tank for water and separate tank for shampoo dispensing. It also has a power hand unit that dispenses shampoo. All along the hand unit has continued to dispense shampoo. Symptom #1, the water tank seemed to be taking on shampoo, as it was getting sudsy. Symptom #2 - On wash mode, nothing would come out, on Rinse mode, sudsy water would come out. Later, symptom #3 - nothing is coming out, except shampoo at the hand unit. There are no lights on for any of the tanks, all seems in order, I empty the dirty water after each use, and use only the platinum shampoo, and warm water in the water tank. I have had this unit about a year and use it monthly for spot cleaning for cat throwups for an aging cat. I have never used it for whole room cleanings.
Colin Stickland
Level 3:
  • Master 22,516 Answers
  • Posted on Jan 01, 2011
Colin Stickland
Master
Level 3:
Answers
22516
Questions
Helped
6992917
Points
66324
Somewhere on the outlet is a control tap thats driven by a rubber band and something is up with this control ,best advice here is put it in the boot of the car and take iot to a hoover dealer ,they will do it seconds for you
2answers
Why does the soap dispenser not work on a Hoover carpet cleaner?
pump inoperative or feed tubes clogged. need to check the small belt; not the main belt.
My Hoover smart wash carpet cleaner did great the first time I used it just a couple days ago. Now it doesn't dispense water or such it up
check for tank not seated properly. look for air leak at all seals. no water unless clean water tank is correctly seated.
1helpful
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
1helpful
Hoover steam vac dual v carpet cleaner has stopped dispensing soap. Water is still flowing fine
You probably have a solenoid valve which has failed and will not open. This will require replacement of the valve. For temporary use you can mix a soap solution and put it in the rinse tank. The correct mix is 5 ounces of Hoover shampoo to a gallon of hot water.
Hoover carpet cleaner won't dispense solution or water. Everything else works.
1.Remove bottom tank and look for pinched hose. 2.Use small screwdriver or toothpick on small holes which disperse solution-remove rotating brush first. These were problems with my steamvac (f5861-900 model).
2answers
Whare does the dirty water go in the bissel 12 amp pro heat carpet cleaner
the clean water goes into a "Bladder Bag" that is located inside the tank. The way it is designed to work, as the clean water dispenses from the bladder bag, the outer part around the bladder bag fills with the dirty water. It never touches the clean water. Seems wierd, but it works! I hope this helps, if it does, please give feedback, as it helps me to gain ratings. Thank you! Remember to have your cleaners serviced every year by a qualified tech! Rene (The Vacuum Doctor)
Instructions on Using The Hoover Steamvac Ultra cleaner
CARPET CLEANER\r\n™
i went the xtra mile to look this up you give me a incorect modlel # put the user guide are the same ps: dont for get to vote for me when it ask if i helped you lol sawdust46
MaxExtract™ technology features the most advanced
combination of multi-action agitation, carpet washing, dirt
removal and direct heat drying - all in one machine. This
technology delivers a floor that is not only deeply cleaned,
but a room that can be lived in again within hours!
• High intensity LED
- illuminates problem areas
• Stream Setting
- ideal for smaller spots
and stains
• Spray Setting
- attacks heavy traffic areas
Dual scrubbing1, multi-directional
brushes have been specifically
engineered to surround carpet
fibers, removing dirt at every angle.
1Patent pending
High velocity suction removes both
dirty water and soap residue, leaving
carpet revitalized. Forced heat further
speeds the drying process. No sopping
wet carpets. No musty odors. Just
clean carpet.
STREAM
SPRAY
REMOVES MORE DIRT2
INTEGRATED SPOT CLEANING
2Test of leading brands of household extractors using FCTP-0024p
Our exclusive pre-programmed
cleaning modes take the
guesswork out of revitalizing your
carpets. Simply select your carpet
type and cleaning task, and let
the pre-programmed modes take
care of the rest. Fully equipped
with Process Feedback Lights
and Full Tank Indicator Lights,
this Intelligent Cleaning System
makes cleaning your carpets
easier than ever before.
HOOVER PLATINUM COLLECTION™ DETERGENTS
TO MAXIMIZE CLEANING PERFORMANCE
PROFESSIONAL STRENGTH
Carpet and Upholstery Detergent
PET PLUS
CARPET CLEANER
Instant Stain Remover
Carpet and Upholstery Spray
AN EFFORTLESS CLEAN
CONVENIENCE IN HAND
Powered Scrubbing Tool,
Upholstery Brush and
Crevice Tool included for
cleaning fabric covered
items such as:
• Stairs • Upholstery
• Mattresses • Pillows
• Area Rugs
To learn more about the Hoover Platinum Collection™
visit www.Hoover.com ™ ®
Six new vacuums, six new standards of clean, and six
new reasons for Clean Freaks to Rejoice. The Hoover
Platinum Collection™ saves you time and effort while
giving you the confidence of knowing your home is truly
clean. Whether corded or cordless each item is distinctive
in both appearance and performance, offering best in
class cleaning through a combination of innovative
technologies and carefully engineered ergonomic design.
With the Hoover Platinum Collection™ you get fast and
effective deep cleaning so you can move on with what
is next in your day, knowing you have efficiently
accomplished the deep clean you desire. With these six
superior cleaners from Hoover®, it is a wonderful time to be
a Clean Freak, and a terrible time to be a dirt molecule.
EXCLUSIVE HOOVER PLATINUM COLLECTION™ MEMBER SERVICES LINE:
1.877.MYPLTNM (1.877.697.5866)
Hoover®’s Best In Class,
Limited Six Year Warranty
Hoover steam vac model F5853-900 series 17.9
Make sure that the recovery tank is completely close.
Can I get a new clean water tank for my Hoover? After filling tank, as soon as I lock it in water poors out even before I can start cleaning carpet.
Take the clean water tank off, and look at the underside very carefully. This tank is made of a very thin plastic, and chances are, your tank is cracked or broken. Sometimes the valves fail as well.
There is a new tank available, a single-piece tank instead of separate water and detergent reservoirs. The part number you want to look for is 42272104. The new tank does NOT come with a handle, so save your handle and use it on the new one.
Search for this new part number online and find the best price. I have seen them for around $40.
Top Hoover Vacuums Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
