Question about Maytag MGR5750 Gas Kitchen Range
GAS OVEN DOESN'T HEAT
I SAW A QUESTION IN A EARLIER POST SIMILAR BUT MINE HAS A BIG DIFFERENCE,,, MY OVEN DOESN'T EVEN ATTTEMPT TO COME ON ,, WHEN I PUSH BAKE AND THE UP BUTTON ONTHE TEMPERATURE , I GET IT TO THE TEMPERATURE i WANT (ON THE DISPLAY SCREEN, AND ABOUT 30 SECONDS LATER IT REVERTS BACK DOWN TO 100, AND THE OVEN NEVER EVEN ATTEMPTS TO LIGHT,,, I TRY THE SAME ON THE BROILER MODE AND IT DOESNT' LIGHT EITHER,
    Scholar:
  • 148 Answers
You need a new ignigter for the oven the one you has is weak or already died,it should be located near the burner
Posted on Jul 08, 2008
Oven baking element lower heat source doesn't heat
Check valve for power, if power is there than look for part elswhere as 166 is a lot. Mine was 40 but you do not state make or model
May 18, 2015 | Kitchen Ranges
KitchenAid KGSC308LSS Gas Kitchen Range OVEN won't heat up
Does the igniter in the oven glow white hot when it tries to start?
Dec 20, 2012 | KitchenAid KGSC308LSS Gas Kitchen Range
Our GE profile oven model JGsp31wet1ww oven will not heat up. When i set the oven to say 400 degrees, it just stays at 100 and never heats up. The broiler seems to work fine and the stove top gas burners...
pull out the racks and remove the bottom floor of the oven,turn it on bake,if the ignitor doesn't glow most likely it's bad,if it does glow and it doesn't ignite within 40 to 60 seconds the ignitor is bad.even though it glows doesn't mean it's good,it works by amps.it takes 3.2 amps.for a flat ignitor to open the gas valve and 2.5 amps for a round ignitor to open the gas valve.
May 15, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a dual fuel Dacor ERD30 range that will not stay hot. Lately, it will heat up to the desired temperature and beep to indicate it is ready, but then will not hold the temperature. And strangely, if...
Sounds similar to what mine is doing.
Since Dacor uses the gas broiler to preheat the oven, the problem is that the lower heating element isn't getting power.
I took out the element and verified that the element is still good, but no AC voltage coming from the relay board to the element.
Try setting on the Pure Convection mode - it will probably heat up and hold the temp fairly well - that still doesn't do any good if you need to bake something covered (convection modes are useless for covered container..
Mar 28, 2011 | Dacor Epicure ERD30 Dual Fuel (Electric...
My oven works fine it just doesn't heat-up. I can hear ignition clicking but no fire from burners. A technican told me to purge the union above gas to get rid of air in the line. Thanks Louis
Personally I wouldn't describe an oven that doesn't heat up as working fine. You shouldn't have any air in your gas line unless this is the first time firing the oven, in either case the air in the gas line would work its way out eventually and the oven would light on its own.
Check to see if your ignitor is glowing before you hear the clicking, if the ignitor isn't glowing it needs to be replaced and is fairly easy to do so. If your ignitor is glowing you should check to make sure you are getting gas to the burner. The only way I would recommend checking this is with your nose, do you smell gas when the gas valve clicks? If you do then something is wrong with the burner, either dirty or the exhaust is too strong, or even gas pressure too low. If you don't smell any gas that doesn't necessarily mean no gas is coming out, at this point you should call a authorized service provider to take it over from here.
Nov 03, 2010 | Baxter BXA2G Stainless Steel Gas Single...
Oven will not heat - lights on panel do work
I keep having the same issue with mine, but if I go to the fuse box and flip the breaker off for about 10 seconds and then back on, it works fine. Obviously this isn't a permanent fix but it gets my stove working again for a couple of days usually. I have not been able to find anything on this issue until I saw your post.
Dec 23, 2009 | Whirlpool Accubake RF362LXTT Electric...
PRD486EDG doesn t heat up Oven light blinks once
PRD486EDG Oven doesn't heat up. Oven light blinks twice, then the heat light blinks twice. Tried reseting the power
Mar 18, 2009 | Thermador Pro Grand PRD486EDG (Dual Fuel)...
Temp stuck on 100 degrees
try unplugging the range for at least 30 minutes
Feb 08, 2009 | Amana ACF3355AS Gas Kitchen Range
Jenn Air oven door won't open after clean cycle
You need the repair man; not a diy project. Please contact me if you need further help and leave feedback. Thanks for letting me help you!
Nov 30, 2008 | Jenn-Air JGR8775QD Gas Kitchen Range
Oven won't light, burners and broiler work
Here ya go...
The same method applies to both the broiler and bake manifold:
1. UNPLUG the range and turn the gas off if you have a local gas cut-out valve (it is recommended that you do).
2. Open oven door and remove (if possible). Refer to your owner’s manual to see if there are instructions on how to remove the oven door. Some have spring-loaded locking hinges, while others just lift out. If you cannot figure out how to remove the oven door, use care not to lean on the door or put too much weight on it. A common complaint following any kind of oven maintenance is that the oven door doesn’t shut correctly any longer. This is usually caused by bending the hinges or springs coming loose.
3. Remove the oven racks, and remove the oven pan. (There are usually two screws either in the back or front of the oven holding the pan in place).
4. Remove the Flame Spreader. This is a metal plate on top of the manifold.
5. The igniter will be mounted directly to the gas manifold. Follow the wires that lead to igniter. It will either be plugged into a connector, or be connected together with ceramic wire lugs. Your replacement igniter should come with extra ceramic wire lugs. In the event the plug does not match the one on your range, cut the wires and connect using the ceramic wire lugs. DO NOT use standard wire lugs, they are not heat resistant and will melt.
6. Unplug the old igniter and remove the mounting ***** holding it to the gas manifold.
7. Install new igniter on gas manifold using care not to handle the element on the igniter with your hands. The oil from your hands can cause damage and/or premature failure. The igniter is also considered FRAGILE.
8. Reconnect the wires using the recommendations mentioned in Step 5.
9. Plug in the range, turn the gas valve back on and do a visual test by setting the oven temperature to the desired range. Allow 30 – 90 seconds for the igniter to light the gas. Turn oven off and allow sufficient time to cool. If the oven has only been lit for a minute or so, the cool down period will be brief.
10. Reinstall the flame spreader, oven pan, and racks. Reinstall door if necessary.
NOTE: Most igniters cost around $50. Prices will vary with models. I hope this is the information you needed.
Mar 11, 2008 | GE Profile JGS968 Gas Kitchen Range
Maytag MGR5750 Gas Kitchen Range Logo
110 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
