Question about Dryers
My GE gas dryer will work when you turn the start switch but stops when you let go
  • Dryers Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Jan 03, 2011
Why want this dryer stay on ?
you have a bad belt switch,if the dryer stays running while you hold the start button on and stops when you release the button its the belt switch part WD21X10261 i've seen this a few times,go here and look at part 803 this is the bad part.
www.searspartsdirect.com/model-number/DPXR473EW0WW/0432/0151200.html
Oct 03, 2017 | GE Dryers
Start button starts dryer and dryer stops when button is released.
Ge dryers have a belt sensing switch inside that won't let the dryer run (just as you describe) when the belt breaks or comes off. My guess is you broke a belt. With door open---hold in button door switch and hit the start switch to get it too run a few seconds. Watch the drum and see if it turns. My guess it will not. Belt is a long skinny band that goes all around the drum outer area and then down around the motor.
Jul 09, 2015 | GE GTDP180GDWW Gas Dryers
GE Dryer DBSR453GB1WW AFTER RELEASING THE START SWITCH THE DRUM STOPS!
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
heatman101
Jul 17, 2011 | GE DBSR453GBWW Gas Dryer
GE Profile gas dryer won't ignite
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 01, 2010 | GE Profile DPXH46EAWW Gas Dryer
Problem with Push to Start Button on my GE Gas Dryer
This dryer is under warranty. Call the store where you purchased it as they are obligated to fix it for free or take it back.
May 07, 2009 | General Electric DCVH640GJ Gas Dryer
Dryer will not start
CHECK TWIST TO START SWITCH OR DOOR SWITCH
Apr 29, 2009 | Dryers
Gas dryer just quit working
Try changing the door switch out this may take care of the problem I know on some models it will not work at all if the switch goes out hope this helps
Mar 16, 2009 | GE Dryers
My dryer will not get hot
My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Dec 15, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Dryer won't stay on
When you turn your start switch it gives temporary power to the motor and then centrifugal switch in the motor kicks in and gives power to the motor until the timer stops it or the door is opened.Your motor centrifugal switch could be bad due to poor contact or heavy linting in and around the motor.Vacuum inside the dryer specially around the motor. If it doesn't fix it you have to buy a new motor, centrifugal switch cannot be bought separately.
May 30, 2007 | GE DBXR463GB Gas Dryer
Dryers Logo
Top Dryers Experts
