Question about Planet Audio Car Audio & Video
My stereo planet audio p245u play only the usb and sd use can use the volume and the others buttoms not
3 Suggested Answers
  • 340 Answers
SOURCE: planet audio in dash stereo wont turn on after car battery dies
A lot of car stereos won't come back on after the power has been disconnected until a code is entered in the radio. This is to make the radio useless if someone steals it. If it requires a code it should have come with the user manual.
Posted on Dec 05, 2012
Mintex
  • 442 Answers
SOURCE: Can I put my micro sd 16gd into this and play music through usb on car stereo?
To my knowledge, USB ports on smartphones are only used for transferring files to/from a PC. You'll need either a mini-phono (1/8") input on your car stereo and a male-male mini-phono adapter cord or play to a Bluetooth receiver that either transmits to your car's FM band or has an audio input to your car stereo. (Like the example on Amazon)
Cootree Portable Car Bluetooth 3 0 Audio Music Streaming Receiver Adapter...
Posted on May 02, 2015
May 02, 2015 | Cell Phones
Tip
How do I connect my iPod to a stereo Kenwood
<p>The superior audio quality thanks to the Kenwood stereo system is as good as any on the market. However, many of Kenwood audio receivers contain no iPod connection port. Even the business hubs of high-end entertainment that interface with the computer via USB cannot provide connectivity to an iPod. But that does not mean you cannot high-quality audio through your stereo Kenwood iPod. <br /> <p><br /> <p>1. Put your Kenwood stereo. Connect devices with the stereo turned on may lead to spikes in volume that can damage the speakers and even your ears. Turn up the stereo, so you can use the set of connectors on the back to see. <br /> <p><br /> <p>2. Connect the end of 3.5 mm 3.5 mm to RCA cable for the headset from your iPod. If you do not have a cable 3.5mm to RCA, you can buy one of the sound equipment stores or electronics stores like Radio Shack. <br /> <p><br /> <p>3. Connect the RCA end to your cable 3.5mm to RCA in an available port on the back of your Kenwood stereo. Put your Kenwood stereo, so you can access the buttons on the front. Turn the sound and select the channel of your iPod is connected. <br /> <p><br /> <p>4. Test the connection. Lower the volume on the Kenwood stereo and start a track playing on your iPod that you can recognize. Turn your volume until you play the iPod through the stereo to listen. If you hear no sound, check the "Monitor CD2/TAPE2" is active, and "Mute" is off <br />
on Aug 09, 2011 | Apple iPod touch
How do I set the clock on my Pyle PLR34M mobile audio system?
press and hold DISPLAY button until numbers start blinking on display screen use volume knob to change numbers press volume knob to switch from hours to minutes press DISPLAY when done
Jul 11, 2014 | PYLE Audio NEW PYLE PLR34M IN DASH USB SD...
Downloaded music on sd card but can"t get it to play
Do you get normal sound other than that downloaded music? If so you may need to change the format the music is in. Do an internet search for "How to change the format on an audio file". What program you will need to use depends on the format the original is in.
Apr 10, 2014 | Universal Mini Speaker Tf Card/ Mp3/usb...
Can not get sound from tv to play through sterio reciever
One simple way to accomplish this is to run RCA audio cables from the red and white (left and right) AUDIO OUT jacks on the back of your TV, and plug those into the red and white (left and right) AUX INPUT connectors on the back of your stereo.
Then just select AUX on the input mode selector of your stereo and you will hear the TV audio through the stereo speakers.
Make sure your TV volume is turned up about halfway way and then adjust the volume on the stereo to your liking.
In the AUDIO OPTIONS of your TV menu you can usually select whether you want the TV speaker to be OFF or ON. That way you can just control the stereo volume with your stereo remote to hear the TV audio.
Or you can select VARIABLE OUTPUT LEVEL for the rear audio output connectors on the TV, and then you can control the volume with the TV remote and just leave the stereo volume set at one volume all the time.
There are many other ways to hook up sound through your stereo, that is just one cheap and simple one.
Please comment back here to this page if you have any details to add, have any questions, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
May 30, 2011 | Televison & Video
Is there a setting on Sonilex external speakers/ MP3/ SD players to use as speakers. It plays songs from USB, but speakers dont operateon audio in.
Keep multi-function round-knob pressed till LED turns green. Now it will play audio signal thro' stereo pin.
R C Chhabra
Nov 01, 2010 | Office Equipment & Supplies
Audio braks when volume 1/3, permanent
If with another position of the volume buttom the sound is normal, maybe the problem can be dust or something jammed between volume buttom and its knob. Try to carefully pull out the volume buttom from the unit and then clean its internal part with some neutral lubricant as well as the knob where it it is fixed.
Sep 19, 2010 | Technics SA-DA10 Receiver
Hey yeah ummm when my like stereo is off I can connect a cord with my ipod and play it... But since the stereo is technically "off" I can not control the volume on it unless it's the volume control on my...
SEEMS LIKE YOU ARE TRYING TO PLUG INTO THE HEADPHONES JACK AT THE FRONT ! NO GOOD . YOU NEED TO HAVE STEREO ON. AND USE AUX. TO DO THIS pLUG IN YOUR MP3 PLAYER WITH 3.5 STEREO JACK OTHER END BACK OF STEREO INTO AUX. RED AND WHITE RCA PLUGS.
THIS LEAD COSTS LESS THAN $7.00 AND THE SOUND IS VERY LOUD THEN. !
I DID IT MYSELF AND AM HAPPY WITH IT .
May 19, 2010 | Panasonic SC-AK320 Shelf System
Car dvd players
sory I did not see that this system will play external vieod, it looks like soumd only not video.
her is a list of specs you ca see for your self.
hope this helps you.
DESCRIPTION
N-CITY DVD-393 In-Dash Car
DVD/VCD/CD/CDRW/MP3/WMA/MP4 Player with Digital
Slot for USB/MMC/SD Memory playback
The New DVD 300 series from N-CITY comes with
everything you expect
Fully featured with Digital Media Slot for
USB/MMC/SD Memory
DIVX Playback, Sub-Woofer output & smart resume function
��. Support USB & MMC/SD Memory Card for direct playback
��.Big size Dot matrix Display
��.DVD/DVD-R+/DIVX/VCD/MP3/ WMA/MP4/CD-RW Compatible
��.Fold Down Detacheble Front Panel
��.MP3 Selection by Sequence Number & Track Name, ID Display
��.Encoder Volume Control
��.Super Electronic Anti-Shock
��.Preset EQ (Flat/Pop/Rock/Classic)
��.AM/FM/MPX PLL Tuning Stereo Receiver
��.30 Memories System (FM18/AM12)
��.Auto Memory Store
��.Repeat/Program/Random/Intro Play
��.Electronic Audio Control
��.8-Times Oversampling
��.Mute / Loud Control / Clock
��.Auto Loading and Ejecting
��. 1- Bit D/A Converter
��. RCA Preamp Output
��. Subwoofer Output
��.ISO Mouting Chasis
��. 4 Channels Output (2V Preout)
��.60W X 4 Power Output
��.Full Function Remote Control
Jan 13, 2009 | Soundstream VDVD-300 DVD/CD/MP3 Player +...
HELP PLEASE
Probably, but don't buy this stereo! It has a lifespan of about 6 months. I am not the only person to have had the same series of events happen with my VR-3 stereo. The same breakdowns I had, were mentioned by other customers on www.vr-3.com. The usb, and SD slots will breakdown. I have played my MP3 player throught the Auxiliary port, (which would be the way you play youe ipod) but the sound quality is not great. It requires that you turn the mp3 unit up to full, and increase the volume on the car stereo significantly, and still not great sound. I am actually planning to contact Target where I purchased mine, and reccomend they drop the product.
Dec 21, 2007 | Virtual Reality VRCD500-SDU CD Player
Car Audio & Video Logo
89 people viewed this question
Top Planet Audio Car Audio & Video Experts
Tygh Duval
Tygh Duval
michael galang
Are you a Planet Audio Car Audio and Video Expert? Answer questions, earn points and help others
