Question about Kitchen Ranges
Where is the thermostat reset button on a DLG2526W gas dryer
5 Suggested Answers
  • 180 Answers
SOURCE: How do I change the orphus on my LG gas dryer
You have to get to the gas valve which is located in the front right bottom of the machine.  You will need to remove the top.  The screws for the font panel will be on the inside top and might be a couple behind the door.  If you need more detailed instructions let me know and I can send you parts of the service manual
Posted on Oct 25, 2009
heatman101
  • 43501 Answers
SOURCE: I have an LG DLG0332W
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Aug 30, 2010
heatman101
  • 43501 Answers
SOURCE: Our gas dryer is working
heatman101
Posted on Jan 03, 2011
cpldw48
  • 211 Answers
SOURCE: How do I test the coils on my lg dryer model number DLG2526W gas dryer? Any videos online to show me?
If u. Talking about the gas. Coil. On the gas valve if u have a volt meter u can ohm them out are put your meter test leave on the gas coil test the volt going to the coil are if the glow bar come on an go back out without ignite. Gas then the problem would be your gas coil
Posted on Apr 03, 2015
My LG DLG2526W gas dryer wont start
I had a problem like this and our fix was to reach in and turn the drum a half a turn and push the start button. it worked for us because the motor had a dead spot on motor and once moved pass that spot, it did its job. you may have a different problem but, try it.
Sep 03, 2014 | LG DLG2526W Gas Dryer
Our gas dryer is working on individual cycles, but does not let the gas heat come on. DLG2526W LG gas dryer. Where do I find instructions to re-set thermal overload or check the ignitor for operation?
heatman101
Jan 01, 2011 | Dryers
I have an LG DLG0332W gas dryer and it not getting hot. Read that the thermostat my need to be reset. have the dryer torn apart and I am having trouble locating the thermostat reset button. Where is it?
heatman101
Aug 30, 2010 | Dryers
LG DLG2526W gas dryer not heating after 1.5 years. Unplugged unit to attempt reset. Cleaned out back vent which did have some lint build-up. Still not heating. Is there a reset button somewhere or do I...
I was having similar symptoms and have finally solved my issue.
We noticed that clothes weren't drying as well as they use to...when using sensor dry they would come out slightly damp (just barely). Intermittently we would smell natural gas in the laundry room. After reading numerous forum posts, I decided to swap out the main control board because many people said changing the ignitor and gas valve didn't fix the problem. I thought that I had fixed the problem as we didn't smell gas for a few weeks.
Well, the problem did come back a few weeks later. I ordered a gas valve thinking that was the most likely culprit. The swap out that part I had to remove the drum which exposed everything in the dryer nicely. It turns out the exhaust tube had dislodged internally and a decent amount of lint was being blown inside the machine. Lint was everywhere.
The lint had built up inside the gas tube and must have caused turbulence in the gas flow which prevented it from lighting properly. I cleaned everything up, reconnected the exhaust tubing and taped it securely before putting everything back together. I didn't replace the gas valve as the original one ohmed out properly. The dryer has been working like new for several weeks now.
I hope this helps other with similar problems.
Apr 02, 2010 | LG Dryers
How do I change the orphus on my LG gas dryer model number DLG2526W
Oct 25, 2009 | LG DLE0332 Gas Dryer
Kitchen Ranges Logo
76 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
