Question about Frigidaire FLGB8200DS Top Load Stacked Washer / Dryer
Our stacked washer will start filling with water then after a few seconds stops. Then after a few min it starts again then stops. My last load of laundry came out soaked before this. Thanks for your help. The model number is fTF2140ESO serial XC51118832.
Coldcut
  • 1554 Answers
SOURCE: Laundry washer broke
if the top door lid sensor is bad it will refuse to wash or spin.
do you hear it click when you open and close it.
try pushing it in manually to see if it makes a diff.
Posted on Feb 04, 2008
huuum
  • 750 Answers
SOURCE: Affinity LTF7000ES door not staying locked
unplug the washer and wait 5 minutes before plugging it in again!
this resets the system. If this does not work then you may have a faulty door lock, latch, or switch!
An need hands on service on location
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Jan 01, 2009
marka19
  • 1430 Answers
SOURCE: Frigidaire FEX831CS Top Load Stacked Washer won't
First you should remove the hoses and clean the screens in the ends of the hose, some hoses have screens in both ends. While the hoses are removed look inside the water inlet valve there should be a screen in there also remove and clean the screen out. Some screens will not be removable so you will need to clean in place or remove the water inlet valve. If all is clear you will need to check the solenoids on the water inlet valve for power.If the solenoid has power when put in a fill cycle and no water eneters your washer you will need to replace the water inlet valve. Most water inlet valves must be replaced as a unit, so if one solenoid fails you replace the hole valve assembly. These are inexpensive and easy to replace. There is a video at http://appliancehelponline.com/topwaterinletvideo.html that will walk you thru the testing procedure. It may be a different model but the testing will be the same. If you need help disassembling there are also videos of disassembling most styles. You can also enter your model # for diagrams and illustrations of your specific model. Not all models will be available. All parts come with installation instructions.
Posted on Jun 03, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a 2002 Kenmore washer dryer laundry system.
It appears your clutch assembly has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Constant filling and siphoning of water sans cycle.
Remove the front panel and open the control panel. Check all wires for loose or broken connections.
Dec 06, 2011 | Frigidaire FEX831CS Top Load Stacked...
LSE7806A stack: the wash fills to the water level/load size selected. it starts to agitate then stops and begins to fill with water again which causes overflow, help please
Your fill sensor is leaking and allowing air pressure from the clear tube to seep out. First make sure your clear tube from the tub to the water level valve is firmly connected. If it is then you may need to get a new water level adjuster switch.
Mar 09, 2010 | Maytag LSE7806A Top Load Stacked...
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
Same problem
Power it off at the mains for 60 mins and then rety. If it still does the same then call in a repair man as it is most likely thatthe main controller board is faulty and needs replacing.
Sep 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Kenmore top load washer machine
check that none of your hoses are blocked, by pulling the back cover off. If any of these hoses r blocked it will stop the washing machine from working same thing happened to me and thats how i fixed it
Jun 02, 2008 | Kenmore 80754 Top Load Stacked Washer /...
Maytag washer
This is similar to a problem I had after my power suddenly went out while the washer was filling with water. When the power resumed the washer would no longer run water... all other systems (agitate, drain, spin) worked fine.
A 10 minute, $113 dollar service call revealed that there was a fuse inside the front upper left area that had blown. Remove the 2 screws at the bottom of the front panel to get access to the inside.
Check it out and replace it if necessary.
Jan 20, 2008 | Maytag LSE7806A Top Load Stacked...
KENMORE TOP LOAD WASHER
i have the agitator dogs, but my agitator is not turning. Can you help me in getting it off. kenmore model 11022954100. please help !!!!!! wife is tearing me up!
Oct 29, 2007 | Kenmore 22422 Top Load Washer
Frigidiare washer not doing anything
Before replacing check the voltage to the machine. Make sure the machine is not on any extension cord.when the machine is turned on make sure the voltage doesn't drop more than a few volts.
Oct 05, 2007 | Frigidaire ATF6000ES Front Load Washer
Frigidaire FLGB8200DS Top Load Stacked Washer / Dryer Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
