Question about Vivitek H1080FD DLP Projector
We cannot get our pc to run through our projector
    Brigadier General:
  • 8,909 Answers
If you browse the projector manual for VGA specifications, set the pc's VGA adapter to match and that should work if the correct input on the projector is selected.
Hope you get it going.
Posted on Dec 31, 2010
My laptop is not working with projector because it has no driver
The video shouldn't require a driver. Just ensure your PC has the external video selected. If you're talking about using the projector remote to control presentations on your PC, unfortunatley, there are a lot of projectors that just aren't compatible with many PCs. You'll have less frustration in the long run just going out and buying a wireless presentation controller made by Kinsington or Targus.
Apr 11, 2014 | Sanyo PLC XU40 Multimedia Projector
Troubleshooting benq cp220
You don't need any software to make your projector work with your PC. Here is the instruction for the Projector. (http://bit.ly/1byZlZT)
Instructions:
1: Plug your projector to your PC.
2: On your projector Choose your input device. (In that case your PC)
3: If you find any connection from you PC you will see same display as your PC. ( You will see a Duplicate of your Screen, you can configure it to be a separate screen).
4: you are done. :D
If you need Further help please do contact me or Replay.
Thanks
Feb 08, 2014 | BenQ Computers & Internet
I'm using an acer aspire laptop and a viewsonic projector. projector colors and disply works fine with an xbox bt when i se my laptop, the projector screen goes red. is it the settings on the comp
Make sure you have all drivers and software necessary for the projector installed on your laptop. You can find them on viewsonic's website. Also go to Control Panel>Display>Connect to a Projector and insure all settings are correct. Let me know if you run into problems.
Jun 13, 2012 | Acer Aspire 5100 (5100-5674) PC Notebook
Our new Optoma projector TX612 will not display any windows from the PC nor will it play any dvd's. Not sure how to reset it.
You need to add the projector to the display list in Windows Control Panel on the computer. if you have an install disc with the projector, run it on the computer.It may have drivers for the projector on it.While you are running the disc- Watch!!! You can save yourself frustration.
Aug 31, 2011 | Optoma TX612 Projector
Why does my infrocus projector keep ficking between image and search
Hello it sounds like you are giving the projector to high a PC resolution. Most machines run best at 1024X768 at 60HZ. You can adjust this in your windows display properties. If you tell me the exact model I can verify for you the correct PC Resolution to use.
Thanks the Projector Guy
Apr 21, 2010 | InFocus In2102 Projector
Cannot get LP340 to work on Vista pc
Try Lowering your screen resolution slightly and/or booting up the pc after the projector is plugged in and running.
Also if the 340 has multiple inputs check you are on the correct RGB or VGA input.
Good Luck!
Dec 17, 2009 | InFocus Projector Lamp for LP340, LP340B,...
I am trying to run a presentation from 2 computers into the projector. one pc as the display and one as the presenter, is this possible
If the projector has two RGB inputs (they will be blue & look like female serial ports and be marked input1 & input2 or possibly RGB1 & RGB2) then both PC's can be connected, but only one image from one of the PC's can be displayed at a time. To change between them use the "input" button on the projector or remote control to switch between RGB1 & RGB2. If your projector has only one RGB connector at the back it is still possible to use the video input for the second PC but you will need a special adaptor for the RGB cable from one of your PC's.
Jul 10, 2009 | Epson EMP-S5 Projector
COLOUR MISMATCHING
befor going anywhere change vga cable between pc and projector.-and run video source from anywhere and check colour mismatch.if you got mismatch from both pc and video go to menu and make some correction to colour . if all failed you have to pass it to service center.
Jan 29, 2008 | Toshiba TDP-T90 Multimedia Projector
Vivitek H1080FD DLP Projector Logo
186 people viewed this question
Top Vivitek Office Equipment & Supplies Experts
Electro Med Services...
Are you a Vivitek Office Equipment and Supply Expert? Answer questions, earn points and help others
