Question about Danze & Antioch™ Single Handle Lavatory Faucet - Brushed Nickel
Low flow. How to clean screen? - Danze & Antioch™ Single Handle Lavatory Faucet - Brushed Nickel
  • 520 Answers
I dont know exactly what you have but most aerators just screw off.
Posted on Dec 31, 2010
The water flow on my kitchen faucet is very low-like a trickle
There are several of things that could cause that but the first thing I would do is unscrew the little screen thing at the tip of the faucet.
If you then get good flow, clean it and put it back on.
water flow on my kitchen faucet is very low YouTube
Sep 29, 2014 | Plumbing
Price pfister ashfield f-529-myp
leave the screen out something is restricting the flow at the screen or take guts out of aerator and keep screen some have flow restrictors that may get clogged usually a plastic disk
Aug 29, 2014 | Pfister F-529-MYPS Ashfield Pullout Spray...
Hansgrohe ecostat not at full water flow
The most likely cause for a decrease in flow on the Ecostat mixer is debris in the filter screens. Try removing the thermostatic cartridge and cleaning the filter screens on the the cartridge. Doing so will most likely resolve the low flow issue. If you need instructions feel free to contact me at Hansgrohe Tech. 1-800-334-0455. Press 2 for Tech and ask for David Scarborough. I'll be happy to provide instructions for the Ecostat mixer.
Feb 04, 2013 | Plumbing
Sysrem keeps saying low flow
Three areas that can cause low flow 1) the intake on the pool, if you are using the pool sweep basket feature, then undo the connection at the pool wall and you will find that the wall filter is plugs with fin bug particles that can not make it past the wall screen. Clean and replace the hose to the wall. 2) the filter is clogged and dirty, clean the filter clean the filter compartment and replace, 3) you have an air leak allowing air to enter the pump system causing air to restrict the flow of water. Check the hose connection for leakage, check to make sure the bleeder valves are not loose or over tightened, as both will cause an air leak.
Aug 14, 2012 | Intex Automatic Salt Water System for ...
Does not Dry. Appears to have low air flow.
most of the problems associated with this problem are caused by lint being in vent tube to outside and restricting the air flow. clean out vent tube, from dryer to outside. this should help. repost if need be. good-day ! if you have too. clean out bottom of drier with a vacuum. around the fan and where theres lint trapped.
Jan 24, 2012 | Whirlpool WGD7300XW Dryer
I keep getting code 90 (low water flow) on my Intex Salt Water System for Above Pools. I imagine that it could be a result of my water filter not being powerful enough. Could be the problem. I want to be...
If your pool has the skimmer system there is a hose coming from the bottom of the skimmer to the wall of the pool which would be your suction to the pump. Disconnect the hose clamp from the suction port that goes through the wall of the pool remove the hose then unscrew the blue adapter on the inside of the pool there you will find a strainer / screen. Whatever gets pass the basket in the skimmer get's plugged up in that screen causing the pump to starve for water causing the LOW FLOW sensor to go off on the Saltwater pump.
Let me know if this helps any.
Jun 04, 2010 | Intex Automatic Salt Water System for ...
Low pressure,cleaned screen in tip,checked incoming supply,seems strong,yet pressure is low??
Has pressure always been low? If faucet is new than there will be a flow restricter in the aerator. Most flow restricters can be removed easily. Some are a pain. Have you tried checking the pressure with the aerator off. That would tell you if the problem is there or in the valve.
Apr 20, 2010 | Moen 7310 Legend Single-Handle Kitchen...
Low flow from water dispenser
If there is a filter on the unit, change it. If not, then sounds like the screen is clogging up. You will need to pull the unit out and remove the water supply line and take off the adaptor to access the filter screen and clean it...
Apr 10, 2009 | GE GSS25SGMBS Side by Side Refrigerator
DELTA MODEL 470-WH LOW WATER FLOW AT KITCHEN FAUCET
This could be a couple of things.
  1. First remove the aerator from the wand and make sure you have plenty of flow with it off.
  2. If there is flow clean or replace the aerator.
  3. Remove the wand and look between the hose connection and the wand there should be a screen between them. Remove the screen and clean or replace.
  4. Make sure hose is kinking under the sink.
If you need a diagram of the faucet with part numbers here is the link:
Delta 470
Hope this helps!
Dec 05, 2008 | Delta Model 470: Signature Kitchen...
Danze & Antioch™ Single Handle Lavatory Faucet - Brushed Nickel Logo
77 people viewed this question
Top Danze Plumbing Experts
David Wiebe
Level 1 Expert
Donni Steen
john h
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
