Question about AutoZone
Need GM Auto Trak II transfer case fluid Do you carry it?
Z71 transfer case
Transfer Case
NVG 236 and 246 Auto-Trak II Fluid Gm P/N 12378508 NVG 261 and 263 Manual Transmission Fluid GM P/N 88861800
Aug 18, 2013 | Cars & Trucks
What type of fluid do i use in my transfer case
If you have the manual transfer case (lever actuated), use DEXRON-III Automatic Transmission Fluid. If you have an automatic transfer case (push button actuated), you should use the fluid that GM recommends. Some owners' manuals may say to use Automatic Transfer Case Fluid (GM Part No. 12378396), which is a reddish colored fluid. GM has a new Auto Trak II Transfer Case Fluid (GM Part No. 12378508), which has a bluish color to it. The newer fluid has better friction modifiers. While your doing the job, it's a good idea to change the drain and fill plugs (GM Part No. 15032997) out too.
Nov 19, 2012 | 1998 Chevrolet K1500
2002 envoy trans problem--second 1 thats burned out the trans and transfere case has th same fluid in it
The two units do not share or mix fluids. The transmission needs automatic transmission fluid and the transfer case uses ONLY Auto-Trak II fluid (only available at GM dealer). Do not put any other fluid in either.
Aug 29, 2012 | 2002 GMC Envoy
Tranfer case fluid takes trak 2 can i use some thing eles
NO, GM Trac II is the only recommended fluid for the transfer case.
Jul 31, 2011 | GMC Sierra 1500 Cars & Trucks
What is the replacement fluid for transfer case fluid (GM part no. 12378396) for 2000 silverada
Use only auto-trak II in automatic t-case . Use dextron III in manual t-case. You will need two qt.'s
Aug 03, 2010 | 2000 Chevrolet Silverado
What kind of oil goes in the transfer case for the four wheel drive
If it's a manual case ( pull stick ) then it's dexron III automatic trans fluid , if it's automatic ( push button ) then use GM part # 12378396
Jul 15, 2010 | 1999 GMC Sierra
Changing transfer case oil need to now what to put back in. Autozone is say its a dealer item???
I hate to say it but there right.
Auto Trak II fluid
GM part number 12378508
Will take 2 qts. to fill it.
Jun 17, 2010 | 2005 Chevrolet Tahoe
I have a 1998 bravada with the smart trak system. No fuses are blown and all wiring has been checked and no breaks were found. Ive been told that it can be the motor on the trandfer case or possibly a...
I have 2K bravada. Make sure you have serviced your transfer case with the "blue" GM Auto-trac II fluid. The "encoder" motor is a common failure item also. Unplugging it at the transfer case should cause the "service smart trac" light on dash to appear. This tells you that probably the encoder controller is good. Only buy the GM/Delphi/AC Delco motor, or you'll be changing it often. Try "thepartsladi" on eBay!
Feb 02, 2010 | 1998 Oldsmobile Bravada
1999 olds bravada smart trac four wheel dosent engage
Probably the transfer case encoder motor. Unplugging it at the wiring harness should make the "service awd or smart trac" light come on. This will tell you the awd controller module is probably OK. Common failure item to Bravada's. Try "thepartsladi" eBay store for lowest price motor, beware aftermarket!!! Also make sure transfer case fluid is "blue" GM Auto-Trak II only! If not bllue when checking change twice after driving for a week with blue fluid.
Oct 21, 2009 | 1999 Oldsmobile Bravada
Ned to change the oil in transfer case
The Z71 typically comes with the auto 4wd transfer case (cannot remember the GM number). This requires AutoTrak II, which is available at a GM dealer. Do not use any other fluid in this transfer case! The previous post was correct in the location of the two plugs, but not on the fluid (the other types of transfer cases by GM use ATF). The transfer case is located under the truck right under the cab. There is a small skid plate under it, and a large driveshaft leaves the rear end of the case heading to the rear differential (axle). If you have the manual or electronic w/o auto 4WD transfer case, you can use Dexron III, but Dexron VI is a better fluid that is also now available at your local auto parts store. Again, if you have the AUTO 4WD button in the dash, use the AutoTrak II fluid from the dealer.
Apr 19, 2009 | 2003 GMC Sierra 1500
AutoZone Logo
165 people viewed this question
Top AutoZone Apps Experts
Erin Wood
Erin Wood
Are you an AutoZone App Expert? Answer questions, earn points and help others
