Question about Dryers
How to wire US dryer to UK supply - Whirlpool WED8300SWD
We brought our 220/240v dryer from the US with us to the UK. Whirlpool WED8300SWD
I want to know how to wire the 60hz twin supply appliance to the 50hz UK three wire supply safely as I know the US supply is +120 / -120 to ger 240v instead of straight 240 here.
We had UK purchased similar appliances here before so it must be possible!!??
Thanks
  • 2 more comments
  • kevjus07 Jul 08, 2008
    Thanks for info so far.
    The 3 wire connection as shown will not work as there are 2 hot wires for the US connection either side of the neutral; we only have 1 hot wire in UK, a neutral and a ground.
    The appliance is rated OK for 240v but perhaps the motor has to be wired/connected some different way?
    Looking at the appliance (as in diagrams you linked to) the middle wire is white (neutral) the two outer wires are live/hot. In UK I can wire the neutral OK but I only have one live wire.
    I imagine I have to get the back off the dryer and the motor will be wired differently for UK 240v?
  • kevjus07 Jul 09, 2008
    Thanks for these links; will let you know the outcome!
  • kevjus07 Jul 10, 2008
    Wiring diagram
    Sergeant:
  • 287 Answers
THIS document has a lot of info about the wiring for the unit you have. starting at page 6
I am, however confused about the voltage requirements as reference to 12/240VAC with a note to check the "rating" plate
If your unit is marked as 240VAC then it should be a simple task for an electrician to wire up the power. The instructions/details are in the manual (link provided) to connect it up as a standard 3 wire system used in the UK
The issue you have is that the motor may not like running on 50hz and may run HOT. It will also run slower on the lower frequency.
The specs on the website are as follows:-
Electrical Requirements
30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED
It may be worth getting all details off the rating plate and posting back here...
My suggestion is that you consult a qualified electrician before attempting to connect the unit to the power
Better safe than sorry.
Posted on Jul 08, 2008
  • 1 more comment
  • Dave Jul 08, 2008
    What colur are the wires?
    The manual does not mention 2 active wires (that would imply 2 phase which is rare), the 4-wire setup in the manual has the extra Neutral ground wire (protective ground).
    The US wiring has the BLACK as Acive (although it sometimes is RED or BLUE) and the WHITE is Neutral. Do you have 2 white wires?
  • Dave Jul 09, 2008
    Well I'm stumped!
    Found THIS
    Is it possible that you'll need to wire the 240VAC across the 2 "HOT" wires? leave the centre terminal vacant and earth the chassis?
    THIS may also be worth a read too
    The only option is to take a closer look at the way its wired up internally? A full cct diagram would be handy about now ...
    I am intrigued now so you will have to post back the outcome.
  • Dave Jul 09, 2008
    These maye be of some interest too
    LINK
    LINK
Where is the thermal fuse on a 3rlsq8033
It is usually attached in the area of the dryer vent. Remove the back of dryer and look for a white plastic part about two inches long that has two wires going to it.
Sep 27, 2014 | Whirlpool Dryers
WED8300SWD no heat F22
You have done a nice job replacing all the things that it might be. Now you need to check continuity through all those things and from the source. Please make sure that it is unplugged when you do this.
Nov 25, 2013 | Dryers
WHIRLPOOL LER5636EQ3 HOW TO CHANGE THE DRYER CORD FROM 3 PRONG TO 4 PRONG?
It seems to get confusing where the wires go in the back where the cord connects to on your brand new,or previously dryer that you have brought to a home thats new to you
4 wires goes as such with oldtech2332.jpgthe red wire going on the right side,the black wire going on the left,the white wire goes on the center terminal. Now what exactly do you do with the green wires is what your asking yourself. It goes onto the cabinet after removing that little link that went from the center terminal that was beweeen the cabinet and and the white wire terminal.Yes remove that link and install the green wire where that link was just attached to a minute ago.
GENE
Oct 12, 2011 | Dryers
Hi there, I just bought Whirlpool AWZ8578 today. Can anyone tell me if a drain hose is supplied with the purchase? as mine did not come with it.
The drain hose is not supplied with the dryer. You need to purchase the accessory kit separately (either from the dealer that sold the dryer or from the Whirlpool After-Sale Service Center). The drain hose is available here: http://www.espares.co.uk/part/tumble-dryers/hoses/whirlpool/p/1585/278/0/0/495005/drain-hose.html .
For the manual, see the Whirlpool site, http://www.whirlpool.co.uk/support_instructions-for-use_instructions-for-use.content.html . Click Search and then enter AWZ8578.
I hope this helps.
Jul 22, 2011 | Dryers
Whirlpool dryer duet sport MOD WED8300SW error message
I have a whirlpool duet sport electric dryer with an error code of F 26.
Mar 02, 2010 | Dryers
Hooking a 4 wire power cord to a dryer that came with 3 prongs
*First ; before starting unplug unit or shut off breaker.
you should be able to match up color for color on your dryer, the fourth wire, green (ground) screws to the chassis, or cabinet. if your wires aren't coded as you say, it is red, white and black, left to right. see picture I've supplied.981ddeb.jpg
hope that helps
good luck
Sep 26, 2009 | Whirlpool LER4634J Electric Dryer
Heat cycle stops/goes off
  1. Changing from 3 to 4 wire hookup on a electric dryer
  2. Door switch replacement help for a common door switch
  3. Dryer basics - Venting problems and power supply
  4. Dryer basics - timers and how they work
  5. Dryer basics - power cord problems
  6. Dryer basics - dead dryer
  7. Dryer *general* repair flow chart....Click here
  8. Gas dryer smell
  9. How do dryer thermostats work?
  10. How long can my dryer vent be in length?
  11. How to change a common rear drum seal
  12. How the belt is suppose to look at the motor and idler pulley
  13. Help on replacing dryer motor and some wiring tips for the 279827 motor
  14. Help on replacing dryer motor and some wiring tips for the 279787 motor new25.gif
  15. Help for storing an appliance
  16. Important Disclaimer
  17. I dropped something down the lint filter area....help!
  18. Inglis, Whirlpool and Kenmore most common style dryer - how to take apart ( lint filter on top )
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show( lint filter on top )
  20. Whirlpool or Sears dryer with heater on the floor and four rollers for drum style - take apart helps ( lint filter in the door )
  21. Inglis, Whirlpool and Kenmore electric style dryers - no heat problems
  22. Inglis, Whirlpool and Kenmore electric element changing procedures
  23. Inglis, Whirlpool and Kenmore dryers - air flow
  24. Inglis, Whirlpool and Kenmore style dryers - noise problems....drum rollers and idler pulley information....
  25. Inglis, Whirlpool and Kenmore style dryers - belt change
  26. Inglis, Whirlpool and Kenmore dryer general motor problems
  27. Inglis, Whirlpool and Kenmore gas style dryers - no heat problems
  28. Inglis, Whirlpool and Kenmore dryers - where are my thermostats
  29. If your drum belt looks like either of these....change it!!
  30. Idler pulley slide troubles with newer Whirlpool build Roper dryer
  32. Newer style Whirlpool - Inglis - ( some ) Kenmore dryer front drum support ring install help
  33. Pilot flame help
  34. Sample wiring diagrams
  35. Test for ohm meter checking on electric dryers with no heat
  36. Taking apart an Duet or HE3 dryer for a belt change
  37. Taking apart a Whirlpool Thin twin washer/dryer to replace the belt
  38. Timers and some common Auto dry troubles and solutions
  39. What is a grounded element?
  40. Whirlpool - Kenmore dryer motor problems in the dryer with Even HeatControl....info on this is here + new25.gifExpanded repair helps for a common "Even Heat" dryer
May 15, 2009 | Whirlpool GGQ8831L Gas Dryer
Whirlpool gas dryer turns on drum spins exhaust is clear and blows air but it wont ignite
  8. Gas dryer smell
  19. Inglis, Whirlpool and Kenmore most common style dryer - how to take apartslide show ( lint filter on top )
Mar 30, 2009 | Whirlpool LGR8648L Gas Dryer
My dryer won't heat
Is it a British front loading dryer? If so, is it a condensor dryer? If so, it is usually the thermostats although could be the element. If it is a regular dryer, the heater and stats come as one unit. Occasionally, the wires also burn out where they connect to the heater or stats. New terminals can be fitted if this is the case. Power off before you remove any panels! Typically heaters are around £35 or so for the majority of whirlpool dryers (UK).
Feb 25, 2009 | Whirlpool Dryers
Dryers Logo
525 people viewed this question
Top Dryers Experts
