Question about Plantronics Voyager PRO Bluetooth Headset
I have a voyager pro+, about a month old, and now the red light does not flash on when I press the 'on' button, or plug the charger into it. Any ideas?
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
If your are charging through the USB port, and you have put it in wrong at all at any time, the connection will be shot and it will not charge. If this is still under warranty try to see if you can get it replaced.
Good luck from Headsets Direct!
Posted on Oct 31, 2011
I bought voyager pro last month. Today the headset will not charge. Was plugged in all night and it tells me that I have an hour of talk time. I tried plugging into the automobile charger and the red light...
Since you bought it last month I am hoping you have a warranty on the headset. It may be that it is just a bad battery, and the batteries are not replaceable. Sometimes that happens straight out of the package, but not very often. It could have been due to heat or cold damage. Check your connections again, maybe try a different outlet, and is it plugged into the headset correctly?
Jul 05, 2011 | Plantronics Voyager PRO Bluetooth Headset
My voyager pro+ keeps flashing red when charging. However when it is unplugged with charger, it does not work at all. Please kindly help.
If it is flashing red like it is supposed to be charging, and it is not, look at the connections. Are they worn, not connected properly? Make sure that the AC charger is plugged in firmly. If this still fails to charge your bluetooth, it may have to do with the bluetooth itself. If this is still under warranty have it replaced. Try a different outlet or charger to see if that is what is not working.
Jun 19, 2011 | Plantronics Voyager PRO Bluetooth Headset
My plantronics voyager pro will not charge turn on or anything. do you know the peoblem?
I have seen on some Plantronics Bluetooth headsets that you can perform a system reset by doing the following, It might help but not sure.
Instructions:
While plugging in the AC charger, hold the power/pair button. The headphones will show a solid red or blue light when they have been successfully reset.
Jun 18, 2011 | Plantronics Voyager PRO Bluetooth Headset
Voyager pro / can't turn off, can't re pair, light flashes red blue red blue
Had the same problem. Light just flashed blue and red. I decided to put the headset on the charger while it was flashing and after about 30mins of being left on the charger it started working normally again. Hope this works for you.
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
I bought the plantronics voyager pro bluetooth headset two months ago and now it's dead. It's been working great for two months. When it's plugged into the wall for charging the red light is illuminated....
One thing you can try is to power down and then power the headset back up. The instructions are on the link below for the Plantronics Voyager Pro, particularly the page "Listen To The Voice."
Plantronics Voyager Pro User's Guide
If that doesn't help, then you have a bad processor in the headset. It's still under warranty so contact Plantronics at 800-544-4660 x5 x5538 for warranty service.
Apr 28, 2011 | Plantronics Voyager PRO Bluetooth Headset
I cannot connect my Plantronics Voyager Pro to my iPhone 4.
Once you make your iPhone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
Jan 25, 2011 | Plantronics Voyager PRO Bluetooth Headset
I need to pair my plantronics (voyager) earpiece with my new phone. I don't have my instructions anymore. I cannot get it paired up with my phone. How do I do that if I don't have the numerical code for...
hello, . Press and hold the power button until the indicator LED flashes red/blue. The Voyager Pro headset is now in pairing mode. If you don't see the red/blue flash, press and hold the power button to turn your headset off, and then press and hold the power button again until you see the red/blue flash. try 0000 as the code good luck
regards
shaun
Oct 10, 2010 | Plantronics Radio Communications
Gateway M-6862 laptop will not turn on; battery light flashing re
Seems to be a problem of not enough power.
First check the voltage output of the charger(adapter) and match it with its specs.
Also try to reset the hardware using the following steps:
1 Disconnect battery and the charger
2 Let it sit for 1-2 minutes.
3 Press and hold down the power button for 30 seconds.
4 Reconnect battery and charger and try to start by pressing the power button.
Mar 07, 2010 | Gateway Computers & Internet
My Voyager won't charge. I plug it in, and it doesnt even say anything. I have tried different chargers too.
This happened to me last week. The pins inside your charger port must have been shifted (pushed up or down). The plug, once inserted does not go all the way through or is not fully inserted within the port. To fix this, get a butter knife (this is what I used) or something flat and skinny that would fit into the port. Then, push it down or up to the middle. Try connecting the plug and check if it's now charging. I hope this works and helps you.
Jun 13, 2009 | LG VOYAGER VX10000 Cellular Phone
Plantronics Voyager PRO  Bluetooth Headset Logo
71 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
