Question about Magic Chef Refrigerators
I have a Magic Chef frig model MCBR460DS. recently all food freezes. the thermostat is set on 1, the warmest setting. what could be the cause of the food frezzing?
SolutionGuy
  • 331 Answers
SOURCE: Freezing food in Frig especially lower compartments
Kathleen, you'll have to provide an accurate model number from the inside of your fridge for us to pull up any tech data on it. Open the door and look toward the ceiling of the fridge. But, from what you describe, it sounds like a thermister problem not a thermostat problem. A thermister is a small, temperature sensitive device that communicates with the computer to tell it what temperature its' location is at any given moment. The computer then adjusts air flow dampers, defrost cycles and cooling times accordingly. There can be many thermisters in any given refrigerator model line. These are inexpensive to purchase and easy to replace, but sometimes difficult to locate. They are usually hidden behind a small plastic shell, that looks completely unobtrusive. But they are easy to recognize for they have 2 white wires going into them that are tightly bonded together. To find them, you'll have to gut the fridge (food, shelves and all) and look closely. Focus your attention toward the area of the problem, the lower shelves/crispers. You may need to pull the rear panel out to find it, but when you do replace it. (UNPLUG YOUR FRIDGE FIRST!) Hope this gives you something to go on. If not, provide your full model number so we can assist further.
Posted on Sep 01, 2007
fridgetech
  • 473 Answers
SOURCE: Magic Chef Refrigerator
Not a themostat. 3 most common causes are defrost problem (frost on back freezer panel), bad evaporator fan motor, or damper.
Posted on Oct 05, 2007
SOURCE: rs645 freezing food in fridge
Good day.
Your thermostat might be busted thats why you cant control the temperature. Also, check for the drain pan. if it is dry, then there might be some particles(I.e. soot, ice,) along the drain channel. Try to defrost the unit first and check for the drain pan. If water came out from it. restart your unit. if problem persisted, replace the thermostat. This shoul resolve the problem.
Response is highly appreciated.
chris
Posted on Mar 30, 2008
  • 1122 Answers
SOURCE: jenn-Air Refrigerator JCB2059GES freezes
your thermostat is bad,get the model number from inside and call your local appliance store and get a new one,let me know,thanks-mike
Posted on Jun 23, 2008
SOURCE: My refrigerator freezes my food solid
There are vents that allow the cold air to flow from the freezer to the fridge. If those vents become clogged with ice or fail mechanically, they can become stuck open or closed. The temp adjustment should move the damper in the vents. But if they are frozen open, then the fridge will become too cold.
Thank you for contacting us.Please do rate fixya if you like the solution.
Posted on Dec 10, 2008
Frig is freezing everthing
A defective thermostat is a strong possibility for the fresh food section freezing. Short of replacing the thermostat ,try setting it to the warmest position for a day ,then check the temp.
Apr 16, 2018 | Refrigerators
Magic Chef mini frig freezing everything.
The thermostat is part of the temperature control found on page 6 here=> MCBR445S1_Parts_List Parts can be found here=> MCBR445S Parts If you have questions please let me know, Thanks Sea Breeze
RF-7350-59 Temperature Control Thermostat
Dec 09, 2012 | Magic Chef MCBR445S1 Stainless Steel...
I have a Magic Chef compact refrigerator model MCBR270 that now runs constantly and freezes everything I put in it no matter what setting is used on the temperature control knob. What can I do to diagnose...
Well, this answer is 6 years late.
I have the same model MC frig - 14 years old. There is only two electrical components; the compressor and the thermostat. Since the compressor is running and freezing, the thermostat must be stuck on. You need to replace the thermostat. My thermostat is also bad. I can't find one. One of the numbers on the thermostat is LR62862. Another is PFN-110U 02D. May be time for a new frig.
Feb 06, 2011 | Maytag Refrigerators
I have the Magic chef 18EYW-2 1.7 refrigerator and everything is being froze when set on 1. I have even tried setting on the preferred setting. Everything is still frozen. HELP! Thanks.
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 05, 2011 | Refrigerators
My refrigerator is not working properly.. the freezer section is work fine.. but the other section is not getting cold...I bought this refigerator six months ago...the model is .. MCBR1010W
Your complaint is not unusual, except that you say the frig is only 6 mo. old. First, I suggest you call the manufacture for warranty service since the unit is still new. There are several items that could cause this problem. It usually will not help by playing with the controls for frig & freeze; the unit should work properly with the controls set at normal midrange for both frig and freez; changing the settings from normal cannot compensate for a mechanical problem. is the refrig in an enclosed space that cannot get good air circulation, or does this frig have the black grid coil in the back and you have the frig up against the rear wall so that no air can remove the heat from this coil ? Any other cause would require mechanical work within the frig components.
Aug 10, 2010 | Magic Chef Refrigerators
Magic Chef MCBR445W1 seems like it dosen,t stop
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Check on the cold control if faulty, replace the cold control, not having found any other problem, do check on plastic air deflector at the top rear of the frig had been knocked off. replaced it if faulty. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, which is now functioning properly.
Good luck.......
Aug 01, 2010 | Magic Chef MCBR440 Compact Refrigerator
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
Magic chef freezer not working unless on "fast freeze"
Fast freeze is overriding your thermostat so the freezer compressor works all the time.This will kill your compressor.Try change thermostat.Jan
Feb 11, 2009 | Magic Chef 5 cu. ft. / 142 liter Chest...
Open Questions:
Refrigerators Logo
415 people viewed this question
Top Magic Chef Refrigerators Experts
evans_lloyd
Level 1 Expert
John Tripp
John Tripp
vince
Are you a Magic Chef Refrigerator Expert? Answer questions, earn points and help others
