H P Pavillion dv 9700, problem : screen is black like in sleep mode. I shut off, removed battery reinstalled battery, turned back on could hear the windows sound coming on but screen is still black. How do I wake it up?
  • 2 more comments
  • supersalenco Dec 07, 2008
    I have a similar problem, and the laptop is new!!!! my second hp pavilion 9700 that does not work proprly.
  • Anonymous Jan 02, 2009
    Same problem and never had any other problem.
  • Anonymous Jan 18, 2009
    when i switched on the laptop there's a beeping noise and the screen is completely black.after a while there is the normal windows opening sound yet the screen is as black as in sleep mode. I have disconnected all powers, removed the battery and installed after a while yet the problem remians the same.
  • bugfish1 Apr 13, 2010
    my laptop HP Pavilion dv9700 will not see the hard drive please help
Try this -- it is called a Power Drain Procedure -- HP technical support helped me with this --
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter.
5. Turn on the Notebook power.
Posted on Jan 06, 2009
MSI L1600 netbook seems to be stuck in sleep mode. The power also cannot be turned off - even removing the battery and replacing it.
try to boot the computer, if you hear the start up sound then mobo is not bad. this issue could be caused due to boot sector viruses as well. see if the back light turns on ..
check the settings in bios and try to run a recovery. if neither helps
call 1-877-805-1027 for expert help
Jul 30, 2015 | MSI Computers & Internet
HP Pavillion screen goes black when inactive for short time. Even when I fixed all of the power settings to never shut off or go into sleep mode. If I don't use it for 30 seconds then the screen...
A blacked-out screen doesn't necessarily indicate a broken monitor.
If the computer has run out of charge or is in hibernation or sleep mode,
if the screen is too dark, or if the display cable has come disconnected from the motherboard, the screen may appear black or fail to turn on. To fix a blacked-out laptop screen, troubleshoot the screen settings, check the LCD connector and see if the computer is awake and receiving power.
Touch the touchpad or move the external mouse to see if the computer is asleep or hibernating. If the computer fails to respond, press "Enter" on the keyboard. Press the power button if the screen remains black.
Confirm that the power indicator light, found at the front of the computer or above the keyboard, is glowing solid green or blue. Confirm that the power adapter is plugged into the computer and into a wall outlet. Confirm that battery indicator light is glowing solid green or blue. Hold down the "Fn" key. Press the up-arrow to see if the screen brightness increases.
Some computers also use the "F6" or "F7" keys to increase screen brightness.
Hold down the power button for 10 seconds to turn off the laptop.
Remove the AC adapter from the computer, close the screen, and then turn the PC over.
Slide the battery latch to eject the battery. Pull the battery out of its compartment. Turn the computer back over, open the lid, and insert the edge of a flathead screwdriver or other flat, solid object beneath the bezel above the keyboard. Wedge the edge of the keyboard bezel off of the top cover.
Work your way along the edge of the keyboard bezel to loosen it.
Pull the bezel off the laptop.
Trace the cable coming from the laptop screen to the connector found beneath the bezel. Reconnect the display cable to the motherboard if the cable has come loose from the connector. Line up the tabs on the bezel with the slots along the top of the keyboard. Insert the right edge of the bezel into the gap above the keyboard, and then push the bezel back in place. Turn the computer back on. If the laptop screen is still blacked out, connect an external monitor to the video port on the side of the PC to confirm that the video card isn't defective. If the external monitor works, the LCD screen could be broken. If the monitor doesn't work, the motherboard or video card might need to be replaced. Hope this helps
Dec 08, 2012 | Computers & Internet
I have an HP Pavillion dv9910us laptop running Windows 7 32bit... It has been running fine, as usual. Lately I have had a lot of problems, however, with resuming from sleep or hibernation, it powers up but...
WHY NOT GET IT FIXED.?
NOT ONCE RUN IT WITH NO BATTERY AT ALL.!!!
FAIL NOW?, BAD POWER PACK IF BIOS IS DEAD
WORKS NOT, BATTERY IS DEAD SHORTED , BAD.
EASY NO?
ALSO KNOW SLEEP MODE! facts of life.
Only works if all driver on laptop are correct at hp.com
or it will fail for sleep.
or virus infected.
turn off sleep mode (ac/ and batter) under powers settings CP
work now>? i bet does, (battery out)
new power pack but why do that, take out the battery first
laptops need no battery and with no battery it can run perfect
does it.?????????????????? (ac wall power good sure)
Mar 01, 2017 | HP Pavilion DV9910US Notebook
Screen goes black. Put it in sleep mode. Then hit the start and it comes back on even with powercord in..what can fix it?
this could be probably due to static charges or corrupt bios settings.
Turn off the PC, disconnect the AC Adapter and remove the battery. Now press and hold the power button for 45 seconds.
Now download and install the latest BIOS update available for your notebook from manufacturer's website. If issue persists, reinstall the display drivers.
I hope this will help to resolve the issue.
May 20, 2010 | HP Compaq Business nc8000 Notebook
Computer will not wake up from sleep mode
- your comp is in hibernation mode
- go to control panel>>power management>>put to NEVER the sleep mode,hibernation,HDD,battery
- restart system
Mar 25, 2010 | HP Pavilion dv2000t Notebook
HP Pavillion DV 6000. Turned it on and it shuts
Is heatsink connected to this problem? (sic) Most probably not, it is more than likely a simple Driver problem. Try to startup in SAFE MODE, press F8 at boot time. If this works you could run a "System Restore" back to a time before it went faulty. Or troubleshoot from safe desktop.
Feb 10, 2010 | HP Pavilion dv6000z Notebook
HP Pavillion won't bring monitor back from sleep mode
hi...if u can read " no input signal" from ur screen, this means that ur monitor is ok..
Look if u have power buttons on ur keyboard.. try to wake it from there.. some pc may have shortcut keys to bring back the pc... look @ ur pc docs on the internet for more info...
However if it's a hardware issue, it may be that ur RAM memory needs to be cleaned
Feb 01, 2010 | HP Computers & Internet
Hp pavillion dv6000 shuts off and wont power back up
make sure laptop is having sufficient power on battery remove the battery and directly connect the main power and see it is switching on or not otherwise connect the battery and connect the power adopter and don’t switch on the laptop keep for 10 minutes and then switch it on.
Jan 15, 2010 | HP Pavilion dv9000z Notebook
Aspire one with windows XP. Won't turn back on while in sleep mod
I've had spotty luck with Windows and sleep or hibernate modes. I would suggest just disabling sleep/hibernate mode. The options can be found under the control panel under power options. While turning off the sleep mode won't help your battery life, if you ask me, it beats having to power off the laptop by pulling the battery out. If you don't want to turn it off, you can try adjusting the amount of time it lets pass before it goes to slee.
Mar 05, 2009 | Acer Aspire One Netbook 8.9" Notebook
Nb acer aspire 7520G - black screen (no light) on startup - starting from sleep mode
Pull the battery and unplug it.
Plug in the AC adapter and see if it boots.
if it does shut it down and reinsert battery, problem solved.
if that doesnt do it then i would check that your ram is seated properly and try swapped between 2 ram chips in both sockets (if your laptop has 2 sockets.
Hope this helps!
Nov 28, 2007 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
2,913 people viewed this question
David Payne
David Payne
