Question about Microwave Ovens
Looking for the beater's to my mixer - Microwave Ovens
    Brigadier General:
  • 8,909 Answers
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads (if applicable) as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Dec 31, 2010
My Kenwood does not cream butter and sugar to 'light and creamy' mixture. I am using the standard large bowl that came with the mixer and have tried both the wire whisk and Kbeater. The mixture...
Hi Julie
It could be that you are using too much sugar, therefore making a more coarse mixture. Beat your butter first, then add the sugar until your mix is as you want it. The Beater would be the proper tool for this. The whisk is for meringue or whipped cream type mixes.
I hope this helps you to some degree
Joe
Sep 07, 2011 | Microwave Ovens
How many amps a fuse in breville mixer
Not knowing the model of the mixer you are talking about, or where you are in the world and the voltage you are running at, I can't tell you. But I can tell you how to figure it out. Simply do this:
You obviously know what your main power supply voltage is, either 240 volt or 110 volt
You can look at the mixer and there will be a data sticker with the wattage of the motor on it
Watts divided by volts = Amps
Therefore, if you have a 500 watt mixer on a 240 volt system 500/240 = 2.083 so use a 3 amp fuse
a 750 watt motor on 240 volts 750/240 = 3.12 so use a 5 amp fuse
a 500 watt motor on a 110 volt supply 500/110 = 4.5 so use a 5 amp fuse
etc etc etc.....
Hope this helps
Jul 26, 2011 | Microwave Ovens
Kitchen Aid Mixer Model KSM5PSGR . I have had this mixer for about 15 years and recently while mixing dough, it started struggling to spin, and at some point stopped spinning. I just turned it on, and it...
it's possible the brushes on the motor are burned out. Are there 2 screw holes on the sides? You should have one on either side that look like a flathead screwdriver would fit in them? If so, inside those chambers are the brushes and springs for your motor. You can try replacing them. You should be able to order replacement brushes based on your model number(found on the bottom of your mixer). Let me know if that helps.
Jun 10, 2011 | Microwave Ovens
My Model K5SS was making a squealing sound when mixing. I unscrewed the black screws on the sides to check the lubricant but when I replaced them the mixer will not turn on at all. Is there a reset...
Those plastic screws on the sides are for the brushes for the motor. If you took them out, they need to be re-inserted in the same side they came out of and the curve in the end of the brush has to match the shaft. If you take them back out and look at them there will be a half circle appearance to the ends. Make sure that you put it back in so that the they look like this ( ) in the mixer.
Jan 19, 2011 | KitchenAid Microwave Ovens
Good Day, One of the beater ends broke off my BC1206cr Betty Crocker hand mixer while mixing cream. The other one is loose as well. Can these be replaced? Where do I purchase them or is there a...
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Jan 05, 2011 | Microwave Ovens
My grandmother gave me her Sunbeam Food Preparation center before she expired and I need a part for the mixer. The food preparation center model # is 736-26. The part I need is a rubber piece that fits...
I hope this helps.
Jan 04, 2011 | Sunbeam Microwave Ovens
Looking for C100 mixer manual Hobart
Toll free: 877-828-4616. Complete manual available. ... C10; C100; A120; A200; D300. These mixers can be damaged, broken, with burned up motors, etc. ...
www.food-equipment.com/parts_Hobart_mixers.htm
Nov 01, 2010 | Microwave Ovens
Microwave Ovens Logo
18 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
