Question about Roper RAS6233KQ Top Load Washer
Roper washer wont spin or agitate.
Roper washer, 14 yrs old wont spin or agitate. it will drain.
  • Anonymous Mar 24, 2014
    if reset doesnt work next possibility?
I already replaced the coupler, it agitated for a few seconds and then stopped again. Then it hummed for about five minutes and then stopped. Any other ideas would help.
Posted on Oct 07, 2008
  • dimond_girl1 Oct 07, 2008
  • 246 Answers
It sounds like you have a broken coupler. (a hybrid plastic/ rubber gear that acts as part gear, part shock absorber). To verify this, first unplug your washer. Pull it forward slightly and tilt it back about 6". Use a flash light to show you the underneath side. You will likely see black shavings, peices of white plastic, or possibly even a mangled chunk of black rubber. This is what is left of your coupler. If ou are able to verify this, grab your model number( the one supplied [ras6223kq] does not come up aa a vailid number). Just lift the lid and look towards the rear where the lid and top of the unit meet. In the center where they meet you should see a plaque with your model number in it. Once you have your replacement coupler, here's how you replace it. 1st - Unplug the unit. Next, open your console. The most common ways to do this are either 2 phillips screws on the back of the console where it meets the top of the washer on the right and left hand sides or there are 2 cosmetic caps on the front of the console. Once you remove the caps, you will find 2 phillips screws to remove. Once the screws are out, pull the bottom of the console towards the front and swing it up. (it should be hinged). Underneath, you fill find 2 large brass colored clips. Find the area where the clips go into the top of of the unit. Use a large screwdriver to simultaniously push down and push the handle towards the back of the unit. This will let the clips out. Now, open the lid and grab the opening for the clothes and pull it towards you while placing your foot at the bottom center to keep it in place. Once you reach about 45 degrees forward, let both the bottom and the top come forward slowly at the same time. Now with the cabinet out of the way, look towards the bottom center of the machine. You should see a white piece of plastic with two black hoses connected. That is your pump. Pry off the two clips holding it on. Underneath is your motor. On the right hand side there is a wire harness. Follow the 2 red wires. This is your capaicitor. If you touch the metal parts is can kill you. So, pull the wires off, then touch a large screwdriver across the two metal plugs where the wires just were. It is now safe. Unplug the rest of the wires where they connect to the motor. There are 2 more clips keeping the motor in place. First remove the screws (they will be either 5/16 or 1/4" screws). Then again pry the clips off. There is a shaft on the back of the motor and a matching shaft behind it on the transmission. Remove any remaining coupler pieces. (you may have to pry or break off the remianing pieces) Take the new parts and press them on the shafts (I find using a spark plug socket and a hammer to press it on works best). Now re-assemble in reverse. If you didn't have the shavings or run in to any other problems, drop me a note back.
Posted on Jul 09, 2008
Washer wont drain or spin what is it?
If this is a top load, direct drive washer, I would first check the lid switch. If it will drain but will not spin or agitate, I would then check the motor coupler.
Dec 30, 2009 | Roper Washing Machines
Washer fills up but wont switch to agitate
posibble bad timer. if it is skipping over the agitate.
Jun 15, 2009 | Roper RAS8445KQ Top Load Washer
GE commercial washer wont spin or drain
If your washing machine is 20+ appliance years old, it's probably due for replacement.
Jul 15, 2017 | GE WNRD2050DWC 3.5 Cu. Ft. Commercial...
MAGIC CHEF 5 YRS OLD WONT AGITATE
Ours started doing the very same thing. I took the top off and found that a mouse had chewed a hole in the vacuum tube. I replaced it with a 3/16" ID small engine gas line hose I bought at local implement dealer. Works like a charm.
tjn
Jul 23, 2008 | Magic Chef CAV2000AWW Top Load Washer
Roper model ras8445kq0
If the agitator does not spin at all, then it is your motor coupling. If the agitator tries to spin but cannot, then it is your dog agitators.
Mar 14, 2008 | Roper RAS8445KQ Top Load Washer
Mo del RAB 1121EW1 serial number CG 402 1770
This is a direct drive washer so there is no belt. The drive coupler that connects the motor to the tub may need to be replaced.
Mar 05, 2008 | Roper RAB2121KW Top Load Washer
Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
110 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
