Question about Friedrich M18CF Split System Air Conditioner
Help We have a Freidrich - floating air, air condition and its not working. We pulled the cover off, and then put it back on and all of a sudden the unit stopped working. The operating and timer light is flashing, so its on. I don't know what to do, can anyone please help me.
  • catherine th Aug 23, 2008
    my timer button is on and it didn't work right because it didn't produce cool air
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
Do the lights flashes alternatively or simultaneously? If they flash simultaneously (at the same time) the unit is in test mode. If the flash alternatively, then there is a fault with the unit. Obviously when you pulled off the cover you must have touched or moved something.
I would get the unit repaired by a professional
I take the time to answer you questions so please rate me
Thankyou
Mat
Posted on Aug 29, 2009
The water light comes on and stops the machine from working even if water is full
There's a float (with a small magnet) in the watertank. This float should go up when the tank is filled with water.
So the float can be stuck in the bottom position, or the sensor doesn't work.
You can test the sensor.
  • Take the left cover off: two screws on the back, slide the cover backwards, then lift the bottom up and pull the toppart out downwards.
  • On the main board there's a plug right at the top, that's the cable from the watertank-sensor. With the watertank removed it shouldn't conduct.
  • Now fill the watertank, check whether the float is going up, put the tank back in the machine.
  • The sensor switch should be conducting now. It it is, then the problem is in the control board.
Hope this helps!
May 28, 2015 | DeLonghi Esclusivo Magnifica ESAM3300...
I have a 2001 Cavalier Coupe, I am having problems with the air condition. Freon was added, that evening the air condition started to work. The next day, I turned on the air condition, no cold air. I was...
There is a power distrobution box under the hood containing relays and a few heavy duty fuses.
I'd take the cover off and find the A/C relay usually depicted in the diagram inside the cover.
Start the car, turn the A/C switch on and then under hood at A/C relay give it a light tap with the handle of a screwdriver to see if compressor clutch on compressor "kicks on".
Relay can even be pulled out and put back in to make a better connection.
I'm betting the problem is that relay...or dirty contacts.
Hope this helps...
Aug 07, 2011 | 2001 Chevrolet Cavalier
I have a freidrich quietmaster wall air conditioner and the condenser works fine until you use the money saver then it starts to blow hot air
blowing hot air is the unit's way of further cooling its compressor, this should not last long and should cycle back and forth
May 03, 2011 | Heating & Cooling
RAV4 spare tire cover seems to be hard to uncover and put back. Want to check air puressure of spare tire but hesitant because of this. Any advise for smooth work for this cover ? (mine is hard plastic...
These covers seem to shrink with age. One of the best solutions I've heard is to keep the cover conditioned with one of the many products available at your local parts store. Also wiping the tire down with silicone helps alot too.
Dec 01, 2010 | 2008 Toyota RAV4
How do i get it out to put new one in
find the offending carb or carbs by pulling float bowl over flow hoses to the side and starting motor, 1 or move hose will be pouring fuel, follow hose to offending carb, unmount all 4 carbs from motor,(unmount tank,1 bolt 2 hoses,2 wires) then (unscew hose clamps from front and back of carbs) next(reomove scew from very top font of air box,near metal cross bar behind fuel tank) then wiggle carbs to separate from rubber intakes,unhook trhottle cables pull carbs out one side(either side of bike) once off turn upside down,take 4 bowl screws out ,remove cover,take out small pin holding floats ,needle will come with it,use the right wrench and uscrew brass seat needle came out of(make sure any rubber o ring come with) reinstall seat &any orings take old needle off float install new one,put needle in hole of seat,pin float put cover back on bottom of carb,re assemble bike.I hope you've maked where everything goes,a little oilon rubber helps with reassembly .
Jul 17, 2010 | 1981 Suzuki GS 750 L
My 2005 883 low's petcock rubber went bad and i think a piece went into the carb. The carb now sticks and I have replaced the petcock and cleaned the carb but it is still sticking and leaking gas every...
If the carb is leaking gas, that's about all it could be. Remove your air filter cover, the air filter element, and the backing plate from the engine and carb. Once you have this out of the way, you can gain access to the four screws that hold the float bowl on. Remove these four bolts and allow the float bowl to drop off the bottom of the carb, you may have to tap the bowl a bit to get it turn loose. Gently tap it with the handle of a screwdriver. With the float bowl off, you can now push out the small pivot pin that holds the float on. The float and the needle will drop away from the carb. Notice that the needle has a wire clip to hold the needle onto the tab on the float. When replacing the float, make sure your needle is positioned on the tab with this spring clip. Remove the fuel line from it's fitting on the carb and blow compressed air into the carb fitting to blow out any trash that might be in the "seat" of carb.
Inspect the end of the needle valve and put it back on the tang of the float. Reposition the float with the needle in the seat and put the pin back in. This can be aggerevating since the carb is upside down for this operation but it can be done. Once you get the pin back in. gently lift up on the float until it stops. Then slowly lower it until your finger comes away from the float. This is to check to see if it is sticking somewhere. As long as it has a full range of motion and moves feely your alright there.
Now, turn the float bowl upside down and remove the two screws that hold the acellerator pump cover on. Under the cover you'll find a spring, a diaphragm, and an O-ring. Pay attention to how these parts are positioned. Lift the diaphragm out and hold it up to the light. Gently stretch it and see if you see any holes. If not, the diaphragm is alright. Place the diaphragm back into position with the raised lip along the edge positioned into the groove around the pump cavity. Position the O-ring in it's location in the cover and stand the sping on top of the metal piece in the diaphragm. Put the cover on and replace the two screws.
Reposition the float bowl and replace the screws. Reconnect the fuel hose. Replace the air filter backing plate, air filter element, and cover. Check the throttle for proper operation. You don't want to start the engine only to find out that the throttle is stuck wide open. Once you're sure you've got everything right, start the engine.
Good Luck
Steve
Jun 16, 2010 | 2005 Harley Davidson XL 883L Sportster
Freidrich cp06e10 will not cool room. Cool mode
is it just the condensor motor thats not comming on
Apr 08, 2010 | Friedrich QuietMaster SL28J30A Air...
Locate manual for a challenge air conditioning unit
Check out fixya .com for a manual of your choie.
Dec 17, 2009 | Heating & Cooling
How do you change the heater core in a 2002 Dodge Intrepid?
  1. Disconnect the negative battery cable from the remote battery post located near the right strut tower.
    CAUTION After disconnecting the negative battery cable, wait 2 minutes for the driver-s/passenger-s air bag system capacitor to discharge before attempting to do any work around the steering column or instrument
    Remove the instrument panel by removing or disconnecting the following:
  2. NOTE On the LHS or 300M, remove the center bezel prior to the shifter bezel
    Shifter knob Allen screw Both instrument panel end covers Using a trim stick tool, gently pry upward on the shifter bezel; then, disconnect both wiring connectors and a light bulb socket connector; then, remove the socket.
  3. Remove the 2 lower instrument panel cover screws (outside end) and disconnect the deck lid release switch wiring connector. Pull the lower instrument panel cover rearward releasing the clips. Remove the cable-to-brake release handle. Pull the cover rearward and remove it.
  4. If equipped for 6 passengers, remove the lower floor bin.
  5. If equipped for 5 passengers, remove or disconnect the following items:
    Center bezel using the trim stick Heater/air conditioning housing assembly control switch and the traction control switch wiring harnesses Bezel from the vehicle Two left side console side cover screws, pull the cover outward and remove from the vehicle Lower glove box door; the 2 screws are located at the right console side cover, pull outward and remove it 2 bracket screws and the 2 inside the console bin; then, remove the console 2 center lower instrument panel nuts 4 steel reinforcement-to-lower instrument panel cover bottom bolts 16-way DLC from the reinforcement left floor duct/silencer pad screw and the pad Steering column shrouds Shift interlock cable at the ignition switch Column wiring The under column duct section Left panel air conditioning outlet duct The 4 brake pedal support bracket-to-column mounting bolts Lower the steering column Heater/air conditioning housing and the Air bag Control Module (ACM) harness connectors then, the 2 ground eyelets from the floor tunnel near the bulkhead Using a trim stick, carefully, pry out on the left and right A-pillar trim moldings and slide them rearward to remove them.
  6. Using a trim stick, carefully pry upward on the instrument panel top cover, and remove it.
  7. From both sides, remove the scuff plate screw. Using a trim stick, carefully, pry out the scuff plates and remove them.
  8. Remove or disconnect the following:
    3 right side cowl panel screws and the panel 3 left side cowl panel screws and the panel Remove the right side under dash silencer and pad 2 right side radio antenna and amplifier harness connectors Left side junction block and Body Control Module (BCM) harness connectors 8 instrument panel-to-chassis screws Pull the instrument panel rearward Instrument panel from the vehicle with the help of an assistant ischarge and recover the air conditioning system refrigerant.
  9. Drain the cooling system into a clean container for reuse.
  10. Place shop cloths in the interior to catch any excess coolant.
  11. Remove or disconnect the following:
    WARNING The air conditioning lubricant used in this system absorbs moisture readily. Do not leave any portion of the system open for any long period of time.
    Air cleaner hose and the air distribution duct Heater hoses-to-dash panel spring type fasteners and the heater hoses from the heater core. Plug the openings to prevent coolant spillage. Refrigerant lines-to-expansion valve nut and separate the refrigerant lines from the expansion valve. Plug the openings to prevent contamination. 3 heater/air conditioning housing assembly-to-chassis nuts from the engine compartment 2 defroster duct screws and the duct Heater/air conditioning housing assembly-to-dash panel nuts and screws 4 rear seat heat duct nuts and the duct Rear seat heat duct elbow push-pin fastener Electrical connector from the heater/air conditioning housing assembly Pull the heater/air conditioning housing assembly rearward and remove it from the vehicle 2 heater core-to-heater/air conditioning housing assembly screws Heater core from the heater/air conditioning housing assembly
contact me and i can tell you how to put it back together
Jun 28, 2009 | 2002 Dodge Intrepid
Need replacement cover or grille for model # KM18J30
Johnson supply out of Texas has an account with Freidrich. They are an A/C supply house. I believe they are based out of Houston. I would give them a call and see if you can get one through them.
Mar 19, 2009 | Friedrich QuietMaster KM18L30 Wall/Window...
Friedrich M18CF Split System Air Conditioner Logo
726 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
