Question about Xerox WorkCentre M20i All-In-One Laser Printer
Machine says open heat error what does that mean? it will not send faxes or receive or copy
  • Anonymous Sep 25, 2008
    error fuser
  • 2,072 Answers
You need to replace the fuser. There is a different type of element in that heat roll and the element goes bad.
It is easy to replace, if y ou open the right side door and look on the upper portion of the frame there are 4 silver phillips screws that hold it in. On the right side there is a small plastic cover over one white conntector, you remove the 4 screws, unplug the one small connector and pull the fuser out, just reverse the procedure to install.
Look up on google a place called The Parts Drop, Call or E-mail them, If you call ask for Britt or Joe. They will have what you need.
I think a fuser is approximatly $200. A little less I think.
But that is your problem and its an easy fix.
Posted on Jul 08, 2008
  • Rick Kasper Jul 08, 2008
    I loked up the price
    Retail : $175.00
    Thats less than Xerox would want. Same part;
I am change fuser but not ok prob.
Posted on Sep 04, 2008
The fax is received by the other party but we receive an error code J72. There is no jam
If you are sending the fax using ADF, there may be the document jam, Open the ADF cover check the path for any foreign objects.
Also you can send from platen glass without document jam.
Also this may happen to the other end fax machine, better you do a test copy from ADF and Platen glass. and confirm your fax machine is ok.
Mar 05, 2015 | Panasonic PanaFax UF-8000 Laser Fax
How do you send a Fax?
1 Load the document face up into the Document Tray.
2 Dial the receiving party's fax number.
3 Press [Start/Copy].
The fax begins sending.
If an error occurs during sending, the fax beeps intermittently for a few seconds and an error
message appears on the LCD. If this happens, correct the problem and then press [Stop], then
try sending the document again.
The fax automatically redials if the receiving party does not answer or if the line is busy.
Feb 21, 2011 | Canon FAX-JX200
Some lines are missing when receiving faxes
Horizontal or vertical? Or do you mean lines of text?
Did you try to copy a document? If the copy is fine, then the fault is on the sending side, or there are severe transmission errors.
If the copy exhibits the same faults as the received faxes, then something is wrong with the printing part of your fax, and solving the problem will depend on the printing technology used (inkjet - clogged heads, need cleaning, or empty ink, needs replacing etc.)
Feb 10, 2010 | Office Equipment & Supplies
Q. 1 - When I try to send a fax I get an error message that says: Fax Send Report is set to Off Q. 2 - I have an 1/2 inch black line down one side of any copy I try to make.
1. Usually a "fax send report" just means that you will not receive a "receipt" or "confirmation" that the fax was successfully sent. Changing the setting to off is pretty much just saving you ink & paper. When my fax machine report is set to off, I only receive a receipt if the fax was unsuccessful. However, all fax machines are different and have a mind of their your best bet it to refer to the owner's manual or call the company where it came from.
2. The only thing I can think of is maybe you need to replace the plexi-glass on the copier or do an internal wipe of the underside of the glass. Sometimes the ink can smear from underneath when faxed papers get jammed or printed.
Sep 04, 2009 | HP Office Equipment & Supplies
It's not sending or receiving faxes, but line is working
May I know what exactly the model that you have?
Initially, first check the settings of the machine if it was set to tel/fax or fax settings. Check if there was an error message appear on the unit or better to print out a copy of the fax transmission status. Fax machine will print out a copy of the transmission if it has a problem or it has a communication error on the line or in the other side whose receiving the a fax.
Kindly update me again here.
Jul 28, 2009 | Canon FAXPHONE L80 Laser
My brother fax machine - only receives black pages
do a quick check on 2 things.
- Copy a document(put a printed page on document feeder and press Copy button) , has the Copy come ok? if copy is also blank that means toner/ink problem, needs to be replaced.
- check with your Fax receive Print settings. is any setting of econo mode/ contrast/brightness Off the track? If found any of such issue then Reset it or put it on average (middle).
Hope this will put your Brother on the track
Jul 14, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Not receiving faxes
Folio is not what you want. The usual is letter (LTR) or 8.5 x 11. You may have to check the settings to set the default paper size.
Jan 14, 2009 | Canon PC-1080F Plain Paper Laser Fax
All Fax pages not received or sent.
have you watched the paper going through the doc feeder are thay goning one by one or is it pulling more then one. try making a copie withe 4 sheets does that work. if not open cover of doc feeder clean rollers. serperation pad. ( pad would be twrods the top of the cover )
Jul 21, 2008 | Canon LaserClass 2050 Plain Paper Fax
Fax Canon JX200
is there any error messages coming out from your fax machine.see the error messages first.the paper should run smoothly during sending and receiving process
May 06, 2008 | Canon FAX-JX200
No confirmation sheet
first i need to know if it receives or copies,if it don't.that code is is heat lamp(fuser) problem.
Sep 13, 2007 | Ricoh FAX3800L Plain Paper Laser
Xerox WorkCentre M20i All-In-One Laser Printer Logo
955 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
