Question about LG 32LD350 32 in. LCD TV
How do you get the stand off the bottom of the TV? i want to wall mount it but the stand is in the way? Any solutions?
    Problem Solver:
  • 16 Answers
Theres usually screws holding the stand in on the back of the tv
Posted on Dec 31, 2010
Hi, we have just bought a second hand Hitachi Hi Plasma TV Model PD1, 42PMA400A. We have a wall bracket but what we'd eally like is a stand ... the base plate and two stems that go into the bottom of...
If you search on Ebay for your TV's exact model number, sometimes you can find a replacement stand for it there from someone who has their TV mounted to the wall and is no longer using it. These are normally fairly heavy and bulky items, so Ebay purchase prices and shipping costs can vary widely.
I did not see any for your exact model of TV available there when I looked, but the online selection changes daily, so you can always keep checking back. Just search on Ebay for 'HITACHI TV STAND' or 'HITACHI TV BASE' and you will see a wide variety of them available for different Hitachi TV models as well as what the average price for them is.
Otherwise you can just buy a generic wall mount floor stand for around $100 which bolts to the TV like a wall mount, but actually sits on the floor instead of being bolted to the wall.
Here are some links to a few different models currently available on Ebay which include pictures so you can see what I mean:
http://cgi.ebay.com/PLASMA-LCD-FLAT-PANEL-MOUNT-TV-STAND-WALL-SHELF-STAND-/390330001764?pt=LH_DefaultDomain_0&hash=item5ae17b2964
http://cgi.ebay.com/Plasma-LCD-Flat-Panel-Console-Shelf-Wall-Mount-TV-Stand-/270797719452?pt=LH_DefaultDomain_0&hash=item3f0ccd479c
I hope that was helpful to you, good luck and take care.
Joe.
Aug 30, 2011 | Hitachi Televison & Video
Took it off the wall of the camper we just bought. Would like to use it in my guest bedroom, but the stand is gone. Can you help locate one for me?
If you search on Ebay for your TV's exact model number, sometimes you can find a replacement stand for it there.
Here is a link to one example currently available for an Emerson TV:
http://cgi.ebay.com/Emerson-LC320EM8A-32-Inch-LCD-Flat-Panel-TV-BASE-STAND-/110728286130?pt=LH_DefaultDomain_0&hash=item19c7eb8fb2
If you choose to rate this solution by clicking on the YES THIS WAS HELPFUL icon, I thank you very much for your time and consideration.
Joe.
Aug 11, 2011 | Televison & Video
I can't remove the stand off the tv
Hi, i have instruction on removing your base stand.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the four screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all four screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Feb 12, 2011 | Toshiba REGZA 52RV530U LCD TV
How do I remove the stand to mount the TV on the
the TV will mount to the wall via the VESA screw mounts on the back of the LCD. If it is a smaller, monitor sized LCD then the screw pattern will be either 75x75mm or 100x100mm. On larger TVs is it usually 100x200mm. Sometimes the base is screwed into this mount and othertimes to the bottom. Simply unscrew it from the screen. Be sure that the wall mounting kit can handle your LCDs VESA screw pattern, screen size and screen weight.
Feb 07, 2010 | Televison & Video
How do I take the stand off of the TV? (For wall mounting)
There will be clips or screws on the back of the TV which will need to be removed and the base stand will slide out of the bottom of the TV. Do NOT start taking screws out of the back of the TV without the wall mount with instructions. Sometimes there are spacers that need to be used with the wall mount and generally only four screws need to be removed from the TV. The TV should have instructions on how to prepare the TV for a wall mount as well. All are different, but very similar to do. If you lay the TV face down on a soft surface (do not slide it around) you probably can see what screws need to be removed to remove the TV base. Keep the screws with the stand for later use if desired because you will need them to re-install the case later. Here are two examples;
I hope this helps and good luck!
Nov 12, 2009 | Televison & Video
Removing back stand supports
First I am not to sure about the brand you got there, But if it is not wall supportable you do not need to reove anything but by a wall mount that will hold the bottom in place and yes there are wall mounts for this tpye of arrangment see not all flat panels go on walls thus hence you cannot remove the stand easy. Try finding a wall mount the has a L shape to it, it will hold the bottom of the tv and it comes with a little strap to hold it back into securement. Please do not try to remove the stand I would suggest a diffrent wall mount- Rulds2008 TV expert for 20 years
May 14, 2009 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Taking stand off toshiba regza tv
forget the four holes on the bottom of the stand. Remove the five allen bolts on the back bottom of the tv-not the stand. Yank on stand and metal plate slides out with stand.
Jan 25, 2009 | Toshiba REGZA 47HL167 TV
Tv stand on the wall
It is not made for wall mounting unless it has 4 bolt holes in the back cover. Some wall mounts grip the tv on top and bottom, but they look like hell.
I bought the same Samsung, but took it back.
Dec 28, 2008 | Samsung SyncMaster T200 LCD Monitor
Is this TV wall mountable?
Just mounted this TV this past weekend...Used Peerless flat panel wall mount bought on Ebay for $39.99 free shipping...Remove the stand by removing the 4 small screws on the back of the tv where the stand connects...then slide the stand off from the bottom...VOILA
Jul 22, 2008 | Sylvania LC320SS8 32 in. LCD Television
Remove base of Insignia ns-ltdvd26-09 lcd tv for wall mounting
Open up the panel on the back of the TV which covers the various input connections. At the bottom of the area previously covered, there are 8 screws (two rows of four screws). Remove them, and the entire stand should now slide right out of the TV. You can then replace the screws back in their holes, so you don't lose them. You do not need to disassemble the stand to do this.
Jul 11, 2008 | Televison & Video
LG 32LD350 32 in. LCD TV Logo
106 people viewed this question
Computer Repairing
Computer Repairing
