I have a ricoh ft5535 copier. When I click copy the display panel reads, "misfeed remains inside" and the area "A" light comes on. There is no paper in the machine anywhere.
    New Friend:
Ricoh ft 5535 copy light code
Posted on Dec 29, 2012
  • 488 Answers
This alert can result from the smallest portion of a paper misfeed. Open all doors and look into each roller corner for a piece of paper that may have been jarred into a corner.
Posted on Dec 31, 2010
I have a ricoh ft5535 photocopier.. the problem is when the copy come out i has two line on both side left and right... i want to reset my machine to factory default setting... somebody help me... plesae
This is not related to factory settings. This have everything to do with general service and consumables, so do optical cleanup and replace drum, cleaner blade, fuser rollers and corona wires.Developer must be adjusted by sim 65 then you can do exposure setting with sim 48.
Jun 11, 2011 | Ricoh FT3713 Copier
Ricoh Aficio CL3500N printer phantom misfeed
It seems that the sensor is having dust or toner settled upon it. Kindly remove the toner and clean the residual toner. Take a hard stock paper and give one copy command and push it while it tries to pull the paper. Paper misfeed is not the same as paper jam. Paper misfeed refers to the blank paper tray and paper jam refers to paper which has been taken from the tray and now inside the unit.
May 19, 2010 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio 250, clear misfeeds at w and finisher
Clean the sensors in this parts and try reset the SC codes:Enter in the SP mode press 5-810 (SC code reset)select 1.Then hold down the Photo mode key and the +key at the same time for at least 4 sec.
Sep 23, 2009 | Ricoh Aficio 250 Copier
Ricoh FT5535 paper misfeed
I know your Ricoh. Your problem simple. However me it is difficult you tell in internet.
Let's on order. I Sergey, My experience of the work 18 years. Rico although and good копир, however moody. Here, it is difficult without skilled help. I have understood so that beside you stick the paper in enterring трэке. And with hands direct move and with pallet. Then listen. I shall enumerate причичины, but in afterwards check.
1. Vysoh giving roller.
2. The Substrate, which is found under rubber roller or is damaged or disappeared.
3. Exists the damage to axis of the presenting the paper and she on adjoins to paper exactly 4 Simply there is hindrance to passing of the paper 5 Sensors of the entering the paper or is littered or small flag sensor came out of jack and his(its) has wedged 6 Nakonc, most probably, this only in device Ricoh - on axis, which provides in motion feeder, seizes the paper, on which roller, on the part of opposite front behind there is bushing of the joining, she provides in motion roller joinings and stretches the paper. This bushing of the joining устроета thereby that she abrades or is polluted by dust. It is Necessary to remove the back cover, get before this bushings to see her(it). Otkrfti front lid and put(deliver) the stub on sensor to make lid and look, what operates the mechanism of the drive in moving the axis on which is located roller of the presenting and tracktor of the papers. Attentively define in what time stops the paper. Advisable give the paper with hands without pallet. If you find that gross does not revolve, but щелчQк there is, you necessary to analyse the bushing which on axis and wash the alcohol and define her wear-out, otherwise her(its) zameniti. my address goodgold@inbox ru Sergey. Write
Sep 11, 2009 | Ricoh Office Equipment & Supplies
Misfeed when attempting to make a copy - Ricoh FT5535
If you are a technical person you may want to remove the tray from the machine (pull all the way out, tilt upwards, and pull.) to clean the rollers. Once the trays are removed you will see a set of three rollers for each tray. They can be removed and cleaned or cleaned directly on the machine. They may have build up dust on them preventing feed. Reinstall the trays the same way they came out but in reverse steps.
Then:
1. Pull offending tray all the way out and remove paper.
2. Unlock the side guides and make sure they move freely
3. Set about 100 sheets of NEW paper for now and adjust the side guides and the end fence. The end fence must be against the paper (touching) and the side guides must NOT be too tight agains the paper as this will prevent the tray from lifting.
4. Make sure the paper size dial is set to the paper SIZE and ORIENTATION.
5. Close tray and test.
Let us know what happens. In the worst case it could be a Magnetic clutch malfunction
Aug 28, 2009 | Ricoh Office Equipment & Supplies
Paper jam in Ricoh Aficio 1515MF
Go to this link, and click on "How to clear misfeed a,p,y"
http://www.ricoh.co.uk/KBase/KBLink.cfm?ProductUID=1878
copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 10, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh FT5535
Either the lens sensor is not seeing the lens at home position, or the lens is not getting there. Also check fuse 303 on the DC board.
Sep 08, 2008 | Ricoh FT5832 Copier
Ricoh aficio 200
Ricoh Aficio 200 copier has stopped copying from side tray. Can you help?
jimgoatley@slingshot.co.nz
Feb 17, 2008 | Ricoh Aficio 180 Laser Printer
97 people viewed this question
k24674
jasbo
jasbo
