Question about Cameras
Can i charge my samsung s860 by plugging in an adapter to the ac/dc jack on the camera when i have rechargeable batteries installed
  • 747 Answers
I'm going to say no, The AC power "jack" as you refer to it as is for external power supply from house hold current this is an optional device if it came with your camera it was a bonus. Anyway back to the question this AC power will not charge batteries and the reason behind this for two reasons is heat and additional size. The camera would have to be enlarged the size of the battery charger to accommodate a charging cycle.
Posted on Dec 31, 2010
Can i recharge rechargeable batteries that are in the camera s860 using a USB connection to a computer
No. The S860 uses standard AA batteries. If you want to use rechageables then you must charge them outside the camera using a separate charger.
Jan 10, 2014 | Samsung S860 Digital Camera
Tip
Samsung TL205 Battery Charger Samsung TL205 Charger
With the most high-quality camera battery charger,
Description: Home Travel Charger
Input Voltage (AC): 100-240V 50-60HZ
Car Input Voltage (DC): 12-24V
Output Voltage: 4.2V/8.4V
Output Current: 600mA
Dimensions: 1.86" x 3.33" x 1.50"
Weight: 2.5oz (85g)
Color: Black
Features:
A. Direct Plug-In wall Samsung TL210 Battery Charger - No cable necessary
B. Samsung TL210 Battery Charger Output: DC 4.2V 600mA
C. 110-220 Volts - Works in every country in the world
D. AC Car Adapter - Charge your battery at home or in your car
E. Fast Charger 800mA - Charges most batteries in 60-120 minutes
F. LED Charger Indicator - Red light: needs charging, Green light: charging is complete
G. Samsung TL210 Digital Camera Battery with Manufacturer's 1 Year Warranty.
H. The Samsung TL210 Battery Charger is for charging your battery only. It does not work as AC adapter for your camera
on Sep 21, 2010 | Cameras
Samsung n145 will not power up
Related to a Samsung Np-n145 Notebook PC:
Plug the laptop into power for 24 hours. See if the Battery charges up.
Next test, or have tested, the AC adapter (Charger) See if it is putting out 19 Volts -> DC.
Know someone with a multimeter? I can guide you in testing.
AC adapter is good? Things go downhill rapidly here.
The next problem could be a DC Power Jack.
The DC Power jack is the jack on the laptop, that you plug the AC adapter into,
1) The DC Power jack may be broken
2) The solder joints holding it to the motherboard may be cracked. Poor connection to motherboard.
The DC Power jack can be replaced, or it's solder joints re-soldered.
DC Power jack proves to be okay?
Power MOSFET's have gone bad. The next link, is an article that deals with bad Power MOSFET's in an HP laptop. Used for an example,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Let's hope it's a bad AC adapter
Regards,
joecoolvette
Jul 18, 2012 | Samsung Notebook Np-n145 10.1" Laptop...
New battery 6600 mAh does not charge anymore
It is possible it is a bad battery again. Also could be a bad solder joint on the DC jack or bad AC adapter. To test power off and unplug the laptop, remove the battery. Now plug in the AC and power on the PC. If it comes on, gently wiggle the AC plug going into the PC. If it shuts off you have a bad DC jack solder joint. If it stays on the battery is probably bad or the battery connector on the PC. If the PC doesn't come on at all with just the AC gently wiggle the AC plug and tap the power button repeatedly. If it comes on briefly than off again it is the jack solder joint. If it doesn't come on at all then it's a safe bet the AC adapter is bad.
Apr 17, 2012 | Acer Computers & Internet
Dell 910 mini will not recognise any battery and will not recharge
You may have a loose DC jack:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Jan 23, 2011 | Dell Inspiron Mini 10 Notebook
I have ac adapter plugged into the wall, and into the computer, the charge pack light is green, the battery is in the computer and the computer won't turn on at all
You probably have a bad or loose DC jack on the laptop:
Problem symptoms:
  1. Laptop randomly shuts down without any warning.
  2. Power LED and battery charge LED start flickering when you wiggle the power cord or the AC adapter tip on the back or your laptop.
  3. The battery will not get charged.
  4. When you plug AC adapter, the laptop appears to be dead and there is no LED activity at all (DC-IN jack on the system board is broken).
http://www.insidemylaptop.com/laptop-dc-power-jack-repair-techniques/
Nov 30, 2010 | Gateway SL1450-30145063 Notebook
Laptop won't power on with ac adapter or battery
Could be a combination of things.
1) Battery is low. Not enough power to turn the laptop on.
Caused by;
2) AC adapter has a plug on the end of the cable. The plug plugs into a DC Power Jack on the laptop.
The DC Power Jack is bad.
2a) The DC Power Jack has a bad connection to the motherboard, (Cracked solder joints), and/or the jack itself is bad.
2b) Center Pin is loose in the jack's mount.
The back of the Center Pin where it mounts has become loose.
2c) The plastic body of the jack, which composes the jack's case, is cracked. This allows movement of the Center Pin.
2b, and 2c cause a bad connection with the AC adapter plug.
No charge to the Battery, no power to the laptop.
http://www.laptopjacks.com/view_part/For-Gateway-MX6920-DC-Power-Jack-GW51425.html
[ If this is the case the DC Power Jack needs to be resoldered to the motherboard. The cracked solder joints need to be re-melted, (Reflowed)
Entire laptop needs to be disassembled down to the bare motherboard in your hand.
(No Processor, Ram Memory, or any adapter cards mounted to the motherboard. Nada)
OR,
The DC Power jack needs to be replaced.
This entails disassembling the entire laptop, down to just the motherboard in your hand. (Same as above)
The old DC Power Jack is de-soldered, and a new one soldered in place.
Very FEW computer repair shops have the necessary skill level.
They just want to replace the entire motherboard.
IF one is available.
More Ka-Ching for them also. ]
3) The AC adapter is bad.
Not providing power to the laptop, to charge the Battery, nor give power to the laptop without the Battery.
AC adapter cord from adapter to plug, which plugs into the laptop, (DC Power Jack), may have a break in it.
May be an intermittent contact provided by wiggling the cord.
If this is the case the wires have stretched, and broken.
Wiggling causes the wires to briefly touch, and make contact.
Where this cord meets the plug itself. A lot of times there is a break in the wires in this area.
Solution is to replace the AC adapter. There are universal AC adapters you can buy, or perhaps Gateway still has some for sale.
(Ka-Ching)
Oct 21, 2010 | Gateway MX6920 Notebook
Power cord attachment into the back of computer seems worn, it wants to run off battery instead of recharging through power supply
Either Have A Failing AC Adapter, Or A Failing DC Jack
you can test the AC Adapter using a multimeter (available at any home improvement center for $6)..
The DC Jack Would Need To Physically Be Checked To See If It's Faulty... which would intail removal of all parts down to the motherboard and visually inspect the DC Jack (the port where the Charger Cord Plugs into)
Remove The Battery... Plug AC Adapter Into Laptop.. Attempt To Power On....
Nov 15, 2009 | Acer Aspire 5100 Notebook
Battery wont change
A problem is just like a mountain. You don't jump over the mountain, you climb it in steps, one step at a time.
1.How old is the battery? 1 to 2 years old, you can expect it to be at the end of it's Life Cycle. Batteries are rated in so many hours of usage.
Best bet is to let the battery charge 24 hours, then try it.
Would be nice if you someone else that has an Inspiron 1525, and they would try to charge your battery. If it doesn't charge up, you would know it's the battery. If it does charge up you can move on down the charging system, to try to find the problem.
2.AC adapter, (Charger) If you have a multimeter, set it to the 50 volt DC scale.
Laptop and desktop computers use DC current. (Direct Current) Your house, for example, uses AC current, (Alternating Current)
AC is converted to DC by the AC adapter, (Charger)
An example of DC current are flashlight batteries, and your laptop battery.
DC current has a Positive pole, and a Negative pole.
The center pin of the plug of your AC adapter is the Positive pole. Any of the four outside pins on the plug, are Negative.
The Red, (Positive), probe of the multimeter goes to the center pin. The Black, (Negative), probe goes to any of the outside four pins on that plug.
Example of a DC Power Jack, for the Dell Inspiron 1500 Series of laptops, 1525 and 1526, (This is the jack inside your laptop, where you plug the AC adapter into),
http://www.megaemarket.com/dc-power-jack-for-dell-inspiron-150150015011505.html
3.It may be that DC Power Jack itself is bad, or one of the solder connections is cracked. It's hard to see it clearly on the link I provided, (So I Right-clicked on it, Save Image As, and put it right in my My Pictures folder. Then I magnified it), but in the photo you will see some metal pins sticking out of the rectangular body.
The metal pins are sticking up. In reality those pins go down, when the jack is mounted on the motherboard. They go through the motherboard, via holes, and are soldered on the other side.
It is these solder joints that may crack, is what I'm referring to.
Solution to 1?
Obviously buy a new battery.
Solution to 2?
If your multimeter findings show lower voltage than needed, it's time to buy a new AC adapter. They have generic ones that can be used on a variety of laptops. The voltage will be stated on the top of the AC adapter.
Example: 19.2V-1.0A
That's 19.2 Volts at 1 AMP.
It may just be the plug end on the AC adapter itself. The plug end that goes into the DC Power Jack, on your Inspiron laptop.
Solution to 3?
Unless you are a skilled Electronics Technician, and have Excellent de-soldering/soldering skills, I advise taking it to a computer repair shop. It may not just be cracked solder joints. The DC Power Jack may need to be replaced. Maybe the motherboard is one of a bad design, and where the DC Power Jack attaches to it, has cracked.
Jul 25, 2009 | Dell Inspiron 1525 Notebook
My battery doesnt hold a charge
That means that you will be needing a new battery. I would suggest that when you get a new battery (hopefully from the manufacturer) What you should do it charge it, and don't recharge it untill it has completely dead. That will help to preserve the battery longer.
All The Best,
Ryan Frame
Creative Energy Associates Technical Center
Jul 09, 2009 | Toshiba Satellite L45-S7423 Notebook
Cameras Logo
52 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
