Question about Maytag Neptune FAV6800AW Top Load Washer
Spin only no pump out - Maytag Neptune FAV6800AW Top Load Washer
    Top Expert:
  • Maytag Master
  • 9,472 Answers
You need to check the pump and the waste lines for any obstructions. Listen to see if you can hear the pump trying to work and if you do not hear it, replace it with this part.
Posted on Dec 31, 2010
  • 520 Answers
Check the pump belt
AWO/D 4505 not spinning
does it pump out all the water when it spins the first time? when they spin slow sometimes the pump is not pumping out all the water causing it to spin slow.
May 15, 2014 | Whirlpool Washing Machines
Water not pumping out
Water is not pumping out since the drain pump is not working. This pump is a separate motor besides the main motor. The main motor has 2 functions, one is for agitation and the other is for spinning. Check to make sure it is spinning then the problem is only at the drain pump. If it is not spinning then the problem is at the mechanism for spinning, not the drain pump. Good luck.
Apr 18, 2010 | Washing Machines
Washer motor spins but not the belt in spin cycle only,
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin It pumps, but doesn't spin It spins only with the lid closed It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing machine wont spin in spin cycle ,makes spinning sound just wont spin
Jan 01, 2010 | Washing Machines
My machine don't engage in spin cycle
If your washing machine is not spinning or gets stuck in between a spin cycle you need to check for these:
Thank You for contacting Fixya.com
Nov 26, 2009 | Maytag PAV2300 Top Load Washer
Will not cycle
Nov 26, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
F02 message but pump propellar doesn't spin totally around
The pump impeller should spin freely and cannot have any broken or missing blades. If the impeller has any broken/missing blades or if it won't spin freely, the pump is defective. Hope this helped and best wishes.
Aug 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Won't pump out water at the end of wash or rinse cycle.
I don't know this model at all, but hada similar set of syptoms on an electrolux .....
Just a thought, but have you checked the pump chanber is not impeded by a stray hairgrip, or bit of wire?
The fact it doesn't pump when it should, but allows water to pass when the centrifugal force of a spin cycle builds up, would indicate that maybe its the pump that either has a jammed impeller, or a blown motor (or fuse).
Feb 15, 2009 | Kenmore 23822 Top Load Washer
Gibson front load washing machine will not spin
are you sure the pump is plugged up and was the impeller damaged
Mar 29, 2008 | Washing Machines
Maytag Neptune FAV6800AW Top Load Washer Logo
35 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
