Question about Westinghouse L2046NV Monitor
My monitor was working fine now the screen is dark and the green light is on what is the problem?
  • 11,361 Answers
It may have failed power supply for the backlights circuits due to bad caps, failed circuits in the backlights, worst case will be failed lamp assemblies.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed WESTINGHOUSE monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Jan 01, 2011
My dell inspirion 6000 laptop screen goes black but sometimes I can see the windows screen but it's very dark. When I attach it to a desktop monitor it works fine but the laptop is still dark. Sometime the...
The back light is the whole of the screen, the screen is illuminated by a CCFL lamp (fluro tube) on the bottom of the screen. A inverter supplies high voltage to this CCFL lamp.
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Feb 08, 2011 | Computers & Internet
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
Hi there! Dell 2407WFP - Front lower right green LEDs light, turn on and off, but screen is dark. I cannot even see a picture searching with a flashlight in the dark. So i believe it is not only the...
Probably the backlight then. If you take a look on eBay you can probably get one for this screen and do the job yourself, they're relatively inexpensive.
Dec 12, 2009 | Dell UltraSharp 2407WFP 24" LCD Monitor
Monitor is blinking green light but no dark screen
does you cpu have a built in vga or you use a separate card? check at the back of the cpu, if you are using a cpu that has a built in vga and youre using a separate vga card may you have just connected your lcd monitor on the built in in which many cases will not work you need to connect your lcd on the separate vga card, if that is not the case and you head a beeping sound with intervals then there a problem with your vga card now if you use built in video you need to put on a separate vga card agp or pci-e which ever is supported by your motherboard, hope this help
regards
michael
Nov 20, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Monitor light flickers on orange never goes to green.
Sir,
You are suggested to check if you serial cable is in fine condition and it properly pluged into the Monitor and VGA. and do also try changing the serial cable .
Aug 30, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
LG L1717S has no light
Hi, this is a common problem. One thing you want to observe is that the screen works, what's going on is that the screen LCD illumination doesn't work while the screen display is active. LCD's have screen lamps behind the screen, they are often called CCFL, (Cold Cathode Flouroscent Lamps). The inverter board in the monitor supplies High Voltage power to the lampls, so the colored wires should lead you to the lamps. This is the problem causing the screen to dark. You can research the model lamp type for an accurate replacement. Usually there are 4 or 6 lamps in LCD Monitors.
Apr 23, 2009 | LG L1717S-BN 17" LCD Monitor
MONITOR KEEPS SWITCHING TO STANDBY
Either the power supply is going bad (power light will be orange or off when it goes dark) or the screen itself has the problem (inverter?). If the power button stays green but the screen goes dark, that'll be the problem.
Jan 10, 2009 | Computers & Internet
Monitor is Blank and Power Light Blinks
JH77,
Hi...Ya! It's seems your LCD monitor backlight inverter just run out of lucks... it's burnt out. Need to replaced a new inverter. Have a nice day!
Sep 25, 2008 | Dell E173FP 17" LCD Monitor
Westinghouse L2046NV Monitor Logo
67 people viewed this question
Top Westinghouse Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
Alun Cox
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
