Question about Measuring Tools & Sensors
The crankshaft in my Vtwin Briggs and Stratton broke. The engine is 4.5 years old. There was oil in the engine. Is this a common problem?
  • 2,926 Answers
No, this is not a common problem and really should never occur. Even if the shaft were to hit something when rotating, the key-way would break before the shaft or the shaft may bend, but breakage is a rare circumstance.
Posted on Dec 31, 2010
Engine rpms is constantly going up and down.
Is the air filter clean?
Governor Ajustment Briggs V-twin - YouTube
? 3:12
www.youtube.com/watch?v=tOoArROpM_oJun 26, 2010 - Uploaded by IFIXIT4U The Briggs manual does not do a very good job. You have to adjust the tension on the two springs to set the RPMs that the engine runs at the low and high position. ... I really really need help guys my race motor has a 21hp vtwin brigs, .... Briggs & Stratton opposed twin carburetor series 1 of 3 disassemble ...
Sep 17, 2015 | Briggs & Stratton Briggs Stratton Intek V...
Why would my 21 hp b and s engine suddenly begin using oil ?
it probably has a partially blown head gasket on one of the cylinders pressurizing the crankcase and forcing oil into the combustion chamber
Jul 21, 2014 | Briggs AND Stratton Intek Briggs &...
I have a Z445 with a Briggs & Stratton 23 hp V twin, the air filter will not seal, lets trash into engine. It smokes, uses lots of oil. Can I put a Honda or Kohler on it, don't want another B &...
Hi, yes you can. You will need to take the model, type and code numbers with you to a Kohler or Honda dealer. Either will have a listing on an equivalent engine. Regards Phil.
Apr 30, 2011 | John Deere 23HP VTwin Dual Hydrostatic 48"...
What is the high speed rpm setting for a intek 22hp vtwin?
Generally 3,600 rpm is the high speed setting for many of these type of engines.
Mar 03, 2011 | Briggs & Stratton Briggs Stratton Intek V...
What kind of oil does the 22 hp briggs stratton take
from briggs site:
For optimum performance, you should change the oil in your small engine after the first five hours of use and then annually, or every 50 hours of use (whichever comes first).
  • Use Briggs & Stratton SAE 30W Oil above 40°F (4°C) for all of our engines.
  • Check oil level regularly.
  • Air-cooled engines burn about an ounce of oil per cylinder, per hour.
  • Fill to mark on dipstick. DO NOT OVERFILL.
Apr 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
18 HP V tech B&S single is smoking only 4 years old
18HP vertical Briggs & Stratton vtech twin ohv; can't find oil leak; motor runs great; is leaking onto housing where motor is bolted to; any suggestions where leak may be coming from????????
Jul 01, 2009 | Briggs & Stratton Briggs Stratton Intek V...
No fire canged magnito & checked magnet
could be a low oil safety switch on the briggs & stratton gone bad. Try disconnecting it and fire it up.
Apr 26, 2009 | Briggs & Stratton Pressure Washer...
Measuring Tools & Sensors Logo
255 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
