Question about Logitech QuickCam Pro 9000 Web Cam
Installation disk is not opening up and activating installation. What do I need to do?
Where to put activation code
Please try the below step and try activating the products and let me know the status;
1. Ran McAfee Removal tool . Click here > http://download.mcafee.com/products/licensed/cust_support_patches/MCPR.exe
2. When you try install McAfee through your disk chose Custom installation and install McAfee Anti spam alone.
3.Once installation was completed try to activate McAfee.
4.If Activation completed successfully then open McAfee and click on Navigation option in top right hand side.
5.In Navigation windows click Featuresin left hand side and install rest of the McAfee features.
Regards,
Bryan
Jul 22, 2014 | Mcafee AntiVirus Plus 2011 1 User
Activation code
Check on the disk and the disk sleeve.
Terry
Mar 28, 2014 | CorelDRAW Graphics Suite v.X6 - Complete...
Slow Maclaptop version 10.5.8 memory 4GB 1067 Mhz DDR3; can not open instalation from open cpn program
please explain what you mean by "cannot open installation from open cpn program".
You can try booting from installation disks and using Disk Utility from the installation disk menus to Repair your disk, and to Fix Permissions.
Nov 29, 2013 | Computers & Internet
Maxtor 32049h2 20.4 GB setup disk for windows 2000
After installing the hard drive in the computer then boot up with the Windows 2000 installation CD. Proceed with installing Windows. delete the existing partition , create a new partition, then format the hard disk in NTFS file format, follow the instruction to complete the installation.
You will also need the product installation code to complete the installation and you will need to activate the Windows license by the Internet or by phone. You will also need to install the motherboard device drivers.
Mar 14, 2013 | Maxtor DiamondMax VL 40 (32049H2) 20.4 GB...
I was given a computer with a homemade tower... I need to factory reset it but don't know how??
Basically you need the Windows installation CD plus the product installation code. Boot up with the Windows installation CD to install Windows on the hard disk, follow the on screen instructions - delete the existing Windows partition, create a new partition and format the new partition (full NTFS format - not a quick format) and continue with the installation.
Next you need to install the motherboard device drivers, you can download them from the motherboard manufacturer's WEB site from a computer with internet access. Copy these drivers onto an USB memory stick and insert this memory stick into you PC tower and install these drivers.
After installing these drivers you can now connect to the Internet to activate your Windows, You can activate Windows over the phone.
Feb 24, 2012 | Toshiba Computers & Internet
Background is always black and theres always a "you may be a victim of software counterfeiting" at the lower right corner of the monitor. Hope someone help me
You need to reinstall the operating system and see if that repairs the problem. I had this same issue about a month ago. What happened, assuming you went through the activation process and I assume you have Windows Vista installed, is the file that has you activation information in it was corrupted and needs to be rebuilt. Use the System Recovery CD's, make sure you save any data you need and have the installation disk for anything you added after the computer was purchased. Microsoft ended up sending me a set of installation disk after they confirmed that I had previously registered the product and had a legal copy.
Aug 09, 2011 | Computers & Internet
Product is Roxio Easy CD & DVD Burning. We put the cd in the drive, we get lights on the drive, we get hard drive disk activity but no installation program comes up. We tried turning off Norton AV,...
Most probably the CD does not have the autoun function or the autorun is no functioning. If you need to install the software, open the Windows Explorer and click on the drive for the CD and on the Explorer right side plane double click the "setup" installer and the installation should run.
Hope it helps.
Nov 13, 2010 | Roxio Easy CD & DVD Burning
I'm not able to open any of the applications on Win7 OS. Everytime I try to open any applications it asks me to save it. Could you please what is the problem and how can it be resolved?
Is you Windows 7 pre-installed with the computer? If not, please insert the Windows 7 disk, and try to run "Repair Install".
1. Start Windows 7, and log on to an administrator account.
2. Disable any 3rd party firewall, antivirus, or other security program to avoid it from possibly preventing the repair upgrade installation of Windows 7.
3. Place your Windows 7 installation DVD into the DVD drive, while still in Windows 7 (Step 1), and click on the Run setup.exe option in the AutoPlay window from within the currently installed Windows 7. (See screenshot below)
NOTE: If the AutoPlay window does not open, then open the drive folder in Computer and run the setup.exe file.
4. If prompted by UAC, then click on Yes.
5. Click on the Install Now button to start the installation. (See screenshot below)
6. Uncheck the I want to help make Windows installation better box (unless you would like to ), and click on the Go online to get the latest updates for installation option. (See screenshot below)
7. Windows 7 will now check online for and install any available installation updates. (See screenshots below)
8. Check the I accept the license terms box and click on Next. (See screenshot below)
9. Click on the Upgrade option. (See screenshot below)
10. The installation of Windows 7 will now begin. (See screenshot below)
NOTE: During the installation process, your screen may flash and computer will restart a few times.
11. After the final restart, you will see this screen for a moment. (See screenshot below)
12. Type in your Windows 7 product key number. (See screenshot below step 13)
13. Uncheck the Automatically activate Windows when I'm online box unchecked, then click on the Next button. (See screenshot below)
NOTE: You can activate Windows 7 later after you make sure it is running properly. (See step 20 below)
If you chose to automatically activate Windows online when you set up your computer, automatic activation begins trying to activate your copy of Windows three days after you log on for the first time.
14. Click on Use recommended settings. (See screenshot below)
15. Select your time zone and set your time and date settings, then click on the Next button. (See screenshot below)
16. Click on the option for your computer's location to select the correct network location type settings to be applied for that location. (See screenshot below)
NOTE: It is best to select Public location for the best security.
17. Windows 7 will now prepare your desktop to startup. (See screenshots below)
18. Check to see if you are missing any user files. If you are, then you can copy them from the C:\Windows.old or the hidden protected operating system C:\$INPLACE.~TR and C:\WINDOWS.~Q backup folders. (See screenshot below)
19. If everythig checks out in step 18, then you can run Disk Cleanup (step 6 at this link). You will need to click on the Clean up system files button first, and then check the Files discarded by Windows upgrade, Previous Windows installations, and Windows upgrade log files boxes. (See screenshot below)
NOTE: This will delete the C:\Windows.old, C:\$INPLACE.~TR and C:\WINDOWS.~Q folders from step 18 above.
20. Refresh your Windows Experience Index (WEI) score.
21. When done, all you will need to do is to activate Windows 7, and make sure that your security programs are enabled again.
Jul 15, 2010 | Dell Computers & Internet
I install flash cs3 in my pc but canot open it
Installation of Adobe Flash CS3
Minimum system requirements
Windows
•Intel® Pentium® 4, Intel Centrino®, Intel Xeon®, or Intel Core™ Duo (or compatible) processor
•Microsoft® Windows® XP with Service Pack 2 or Windows Vista™ Home Premium, Business, Ultimate, or Enterprise (certified for 32-bit editions)
•512MB of RAM (1GB recommended)
•2.5GB of available hard-disk space (additional free space required during installation)
•1,024x768 monitor resolution with 16-bit video card
•DVD-ROM drive
•QuickTime 7.1.2 software required for multimedia features
•Internet or phone connection required for product activation
•Broadband Internet connection required for Adobe Stock Photos* and other services
Macintosh
•1GHz PowerPC® G4 or G5 or multicore Intel® processor
•Mac OS X v.10.4.8
•DVD-ROM drive
Do you system meet the minimiun hardware requirement?
Jul 12, 2010 | Adobe Flash® CS3 Professional Full Version...
Tomtom go 300
The tomtom GO 300 does not need an installation disk. It has firmware ( thats a sort of pre-installed software ) that is put on it at the tomtom factory. If the firmware has become corrupted it can be reinstalled or "updated" by logging on here > http://www.tomtom.com/plus/service.php?ID=17 then click the DOWNLOAD TOMTOM HOME Link. Then connect your tomtom to your computer with a USB lead. Run the TomTom-Home software you downloaded and select "UPDATE MY PRODUCT" . After that , if you don't already have one you will need a valid SD card for your tomtom containing the maps for your country and some other activation codes which you get when you purchase maps from tomtom.
Jan 25, 2008 | Tomtom GO 300 GPS Receiver
Logitech QuickCam Pro 9000 Web Cam Logo
21 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
