Question about Kenmore Washing Machines
Have a Kenmore front load washer model #417.29042991 Mfrd:06/99 Will not go into spin cyle.
SOURCE: Kenmore Front Load Washer Problem
Pump may be plugged.Take off back Locate pump remove hoses. Check pump spins freely, remove debis. Mine had a hole in the basket gasket sealt hat let debis get in the pump. Good luck
Posted on Nov 02, 2007
reg501
  • 413 Answers
SOURCE: kenmore washer 24642300
The lid switch has failed. To replace lid switch;
REMOVE POWER, lift the console by removing the trim on either side. Grasp the top of the trim and pull forward to expose a screw. Remove both screws and lift console.
1. You will find a lid switch connector (white in color). Unplug the switch from the connector.
2. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
3. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
The lid switch can now be accessed and replaced.
If you need further assistance, let me know
Regards,
reg501
Posted on Jul 05, 2008
  • 19 Answers
SOURCE: noise/not draining on spin cycle
I had that problem and it was the drain pump trying to drain but it coulsn't because it had lint, plastic, 3 underwires a looney some costume jewellery stuck in the pump. By the pump underneath you'll see a black plastic boot leading away from the pump. disconnect this and inside you'll find the lint trap and if you dig you'll probably find the culprit that stopping your pump from moving. Put it all back together and Voila!
Posted on Jan 25, 2009
  • 188 Answers
SOURCE: Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Posted on Mar 03, 2009
SOURCE: my kenmore 417.42042100 model front
Here's what the problem is.
http://www.youtube.com/watch?v=UwpKP_9_fAA&feature=player_embedded
It's been designed to fail so that you buy an expensive part.
Posted on May 15, 2009
I have kenmore elite washer, when done with spin cycle water is still in bottom of drum. hose's are all clear, could it be the pump is bad?
could be pump and also could be beging of a suds lock meaning high concetration of soap in pump housing creating air pockets which cant be pumped out check pump and hoses do the feel slimy residue run hot water cyle and pour in a cup of vinegar in washer and run a load
Jan 27, 2011 | Kenmore Elite 45986 Front Load Washer
Spin cyle does not come ,but water drain
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 24, 2010 | Maytag PYE2300AY Electric Dryer
Front load washer problems
Hello,Most likely this will be the drum bearings.
Bearings normally last quite a long time but some will fail sooner than others. Quite often bearing failure is due to a faulty drum shaft seal which allows a small amount of water through and in to the bearings. The bearings then start to rust, which then accelerates the wear on the bearings.
Thanks
May 31, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore model 110 23832100 stps after wash cycle before the rinse cyle. The old water has not drained.
If the machine fills, and washes and won't drain or spin out the water you need a direct drive coupling. It is located at the bottom and is on the motor shaft and consits of 3 pieces. Check this first, easy fix and not expensive.
Nov 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 60 series will not drain
Well if this is a belt driven model then your solenoid coil is bad.
This model 's motor only revolves in one direction. To spin it has to shift gears. It does this by means of a solenoid mounted on the transmission called a wigwag. Note: if the lid switch is bad no power can go to the wigwag and shift it. If this is a direct drive model(no belt) then it has to be a bad lid switch.
Dec 28, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Kenmore washer
Check your exit hose spigot, it may be clogged. This is if your filter is all clean (ref manual) There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it (maximum 7 inches). Snaking out your standpipe & drain would be good too..
Apr 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front loading washer/NOT SPINNING in cyle
replace your door lock switch it will run fine till you git to final spin then stops if i not missing the point the model no. will start with a 417 even door locks the switch is bad
Feb 24, 2008 | Washing Machines
Maytag front load washing machine Model MAH5500B misses spin cycle
either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
90 people viewed this question
fordexpert
Mike Squire
Robert Rankin
