Question about Sony FD Trinitron WEGA KV-36FV310 36" TV
Sony WEGA 36" will not
    Brigadier General:
  • 8,909 Answers
Sony sometimes use a balance power supply, similar design to the Philips design from1978 but updated. A realy efficient and nice design but when it dies it takes out quite a lot.
There is a mains fuse that feeds the bridge rectifier which in turn feeds the power supply. If that is the fuse you are refering to, seek professional help. The circuit is finely ballanced and must be correct otherwise it will go bang again. If this is not the fuse then look for a short circuit on/off switch or filter capacitor network on the A/C side, before it gets to the main power supply.
Hope this helps.
Posted on Dec 31, 2010
Will not turn on
Check all fuses, if you replace fuse and it blows immediately then the two main culprits are power supply semiconductors and line output stage. even if fuses are not blown those are the two areas I would look at
Check for dry joints around the line output transformer also. That is a common fault.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | Sony FD Trinitron WEGA KV-30HS420 30" TV
I have a 36" wega and I can't get rid of the
Press the "Display" button. If it doesn't go off, press it again. If it still stays on, post a comment and I will dig into Sony files. Hope this helps
Jan 14, 2011 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
My sony wega kv-36 tries to power on. the stand by light blinks 6 times every time I try to turn it on. After turning on and off like 50 times, I seem to get lucky and it actually powers on and woks...
The Power/High Voltage board is the main cause of this. Most of these boards must be sent to Sony to be refurbished because Sony no longer manufactures the board.
I hope this helps,
skyassoc
Dec 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony wega 36
power board...count flashes..if any. Call tech support
Jun 02, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
The television will not turn on, its as if the switch that turns on the tube is broken. i can hear the switch turn on but the picture or television doesn't turn on. the nearest tv repair shop that can fix...
take back off and check if fuse has blown. replace fuse with exactly same type and size. if fuse blows again it is unlikely to be the on-off switch.you may be lucky and fuse doesn't blow. tv will start up.
Jan 24, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony xbr 27"
you do have a deffective crt
Jul 30, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
My Sony KDF55WF655 Grand Wega will not turn on. No power at all, and there are no LED's of any color. It's as if it wasn't plugged in. This happened after a local power outage. The Sony wasn't turned on...
Even with the set turned off, there is always a circuit that is active. There is what is called a "standby transformer" that supplies power for this. It is quite possible that the internal fuse of this transformer has opened up. This is a common failure. There should also be an external fuse that may be open as well. Check for any "glass tube" type of fuse close to where the AC cord attaches to the set (inside and with the set unplugged). Try changing that fuse first. If that does not resolve the problem, the standby transformer is the next likely suspect.
Dan
Jun 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony wega kv-36hs20 will not turn on
SEVEN Blinks---High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
Mar 02, 2009 | Sony FD Trinitron WEGA KV-36HS20 36" TV
36" Sony Wega - no power
There are of course internal fuses, but I suggest you better call a technician if you are not an expert, because you can blow the tv trying to rectify power supply problems. If the fuse is blown, there must be a faulty component behind that.
Jan 17, 2008 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
FUSE SPEC FOR SONY KV-36FV16
The rear panel nameplate will state the unit power requirements. Look for number of amps draw. Let's say you read "2 A". Now, depending on where in the circuit this fuse is, your fuse size will be no more than two amperes (sometimes slightly greater if slow-blow fuse spec'ed). So, if your fuse is located immediately near the line-cord entrance to circuit board, start with a 1.0A fuse. If that immediately blows, then increase to a 1.5A fuse. Repeat until 2 A fuse is reached. If still blowing, then there is a problem with the set, either power supply or tube.
Jul 17, 2007 | Sony KV-36FV16 36" TV
Sony FD Trinitron WEGA KV-36FV310 36" TV Logo
75 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
