Question about GE GSD5130 Dishwasher
GE GSD5130 locking mechanism broke. Any suggestions for a fix from someone not very mechanical (with it being the holidays). I can't get the latch to budge. Thanks.
3 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: My GE wall oven model
Hi
Thanks for using FixYa. It seems that you interrupted the self clean cycle in between or you ran the self cleaning cycle after a long time, as these kind of issues are usually caused due to these reasons. The issue is with the latch assembly going bad and should be replaced. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 13, 2010
tunde007
  • 2382 Answers
SOURCE: I have a GE Spacemaker
Hi, normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
Normally you have to separate the door panels (as shown in the manual) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
The best place to order GE parts is Tritronics.
Posted on Jan 02, 2011
I have a BMW 328i 1997 and I broke the hood latch to open the hood. How do I open the hood or fix it with little work?
Can yu reach the lock mechanism at front of hood w a long screwdriver. pry back where cable for release is attached for first latch. then as you would normally for safety latch.
May 15, 2017 | BMW Cars & Trucks
04 tahoe liftgate will not lock
Make sure key is in the center locking position when removed. May have bad lock mechanism or lock mechanism was jammed shutt befor closing. You can take a screwdriver and pry out the lock latch while turning mechanism with key. Mechanism should pop open and lock should work. Do you have power locks? have someone work the switch as you attempt to free up mechanism with screwdriver.
Jan 19, 2013 | 2006 Chevrolet Tahoe
Error code F9 and lock on computer On Maytag gas range.model mgr587bdb.
The F9 error code refers to the door latch. The problem seems to be with the latch motor or a switch associated with the motor. If I am reading your question correctly you say that it would not unlatch and then upon resetting it unlatched but the oven won't work and you still get the error code. If so try resetting again but have someone come out to check it out or you will continue to have this problem.
The F9 indicates one of two possible problems. One you have already done and the other is the door lock mechanism. If the lock mechanism got stuck in between the lock and unlock neither switches on the lock mechanism are closed. This could be caused by a post on the lock mechanism that has failed.
I just looked up the part for the door lock and it is no longer available, with no other source for the part.
So I guess I would suggest having a technician come out and see if he can see if the lock mechanism can be fixed so the oven will work but you will no longer have the clean cycle working.
They may or may not want to do this for you, but you could use a local service company and they may be able to make it so you can use your oven.
I hope this helps (remember to rate and comment this answer).
May 12, 2011 | Microwave Ovens
Have a 1993 Ford Taurus, someone back into it and broke hood latch. Hood is in the closed positon and i would like to open hood without breaking rest of latch...
If your able to reach up betweent the bumper and radiator support bracket, using a flat head screw driver, locate tap with spring on the latch locking mechanism, use screw driver to push tab up and hood should pop open.
Jan 25, 2011 | Ford Taurus Cars & Trucks
I have a 1996 Mitsubishi Galant, 4-door, and my driver side rear door will not stay shut. Not sure if it is because of cold weather or some mechanism that broke. Unable to drive car!
Sounds like the door latch mechanism (inside the door frame) is faulty.
You'll need to either fix yourself, or have someone do it for you.
Jan 11, 2010 | 1996 Mitsubishi Galant
Front outside door latch does not work
Remove the inner door panel which allows access to the door lock. Remove it and you should be able to remove the outer latch mechanism by removeing screws from the inside. Check both the lock mechanism and the latch for whatever broke or bent.
Oct 31, 2009 | 1995 Isuzu Rodeo
The locking mechanism latch broke and we replaced it
helps to lift the door a lil when shutting it hinges may be worn and latch is easy to get to just take the clamp loose around the boot and 2 screws hold it
Jul 07, 2009 | Frigidaire ATF6000ES Front Load Washer
The door latch has been pushed in so now the door can't close.
remove the outer casing so that you can gain access to the door locking mechanism, you will then have to use common sense to decide how to repair
Feb 26, 2009 | Microwave Ovens
VGB3 leg lock broke
On the velbon vgb 3, the leg locks consist of a lever, one or two pieces of metal and a plastic piece. The metal and plastic pieces rest in a depression against the lever. When the lever is pulled out, pressure against the smaller leg section is released. When the lever is pushed in, pressure against the smaller leg section is exerted, locking the legs in place. On the back side of each joint, there is a phillips head screw which acts as a stop to keep the leg section from coming all the way out. When the screw is backed out, the leg section can be removed, exposing the latching mechanism. If the only problem is that the latch mechanism came apart, it can simply be reassembled. If, however, something broke and allowed the latch assemby to come apart, that will have to be dealt with as well. My guess is that the phillips screw may have become loose, and the latch came apart.
Aug 14, 2006 | Velbon Chaser EFL-4 (A) Tripod
GE GSD5130 Dishwasher Logo
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
