Toshiba Printer Model #2830C, Error Message "CE20"
  • scallydu7 Jan 04, 2011
    yes. finally had a repair person in . A new drum was installed and sensors were dusty
  • 8,197 Answers
[CE20] Image quality sensor abnormality (no pattern level)
1. Check if the transfer belt or transfer belt unit are securely installed.
2. Check for any abnormal stain caused by poor cleaning, large flaw or break on the transfer belt
surface.
3. Check if the drum and the transfer belt are rotating. If any abnormality is found, correct any
mechanical problem.
Is the connectors CN345 on the LGC board disconnected?
Is the connector of the image quality sensor disconnected or the surface of the sensor stained?
Is the harness between the LGC board and the image quality sensor open-circuited?
Is the shutter of image quality sensor opening and closing normally? Is the shutter damaged?
Posted on Jan 01, 2011
How do i print envelopes with toshiba 2830c?
according to other forums and blogs, they say it is a pain to do on the 2830c and that you would have to sit and baby sit it, newer printers were being recommended for this task.
press the helpful button
Feb 04, 2016 | Toshiba Office Equipment & Supplies
How to do periodic maintenance 0088 in Toshiba Studio 2330c
Toshiba e-STUDIO 2330c
Is given error message "Close Front Cover". The front cover is closed and I can not get error message to go away.
Where can I buy Power Supply (6LG03347000)
Mar 23, 2015 | Toshiba E-studio 2330c 2830c Color...
Toshiba 2330c error cd71
Waste toner transport motor drive locking error.
Jun 10, 2014 | Toshiba E-studio 2330c 2830c Color...
Error code of C970 and call for service
Toshiba Copier Error code c 970 problem solution help: Toshiba E STUDIO 2330C, Toshiba E STUDIO 2500C, Toshiba E STUDIO 2820C, Toshiba E STUDIO 2830C, Toshiba E STUDIO 3500C, 3510C, Toshiba E STUDIO 4520C
PROBLEM:
1.The charger wire at the side door is broken. angry.gif:(" title="Angry">
2. The charge wire is vibrating. angry.gif:(" title="Angry">
3. Main charger grid could be deformed. angry.gif:(" title="Angry">
4. Broken T/S wire. angry.gif:(" title="Angry">
5. High voltage transformer abnormaility. angry.gif:(" title="Angry">
Solution:
4. Check if the spring of the high-voltage supply contact point is deformed. cheesy.gif
May 08, 2014 | Office Equipment & Supplies
Estudio 2830c
Double check your printer driver.
Oct 15, 2013 | Toshiba E-studio 2330c 2830c Color...
Toshiba estudio 2830c error code ce40
I want to locate the position of the image sensor for a toshiba E-Studio2500c.
Mar 19, 2012 | Office Equipment & Supplies
Error ce20
Hi how are you this is jack ... jack_pak@hotmail.com
Dear follow the procedure...
surface.
mechanical problem.
PLEASE VOTE ME.
Thanks,
Best Regards,
Mar 29, 2010 | Toshiba E-Studio 3511 Color Copier
Toshiba e-studio 350 error ce20
ce 20system management module access abnormality
Mar 28, 2010 | Toshiba E-Studio 3511 Color Copier
Every time i print message comes up as "Error-Prin....." and i can't print
What is the exact error message and what is the make and model of your printer please?
In the meantime, you would probably want to try a hard reset and a reinstallation of the driver.
Hard reset:
Unplug printer from mains and PC
Wait for 15-20mins
Hold power button on and replug printer to mains and PC.
Try this first and also send me the error message and make model of your printer.
Thanks
May 03, 2008 | Office Equipment & Supplies
323 people viewed this question
jasbo
jasbo
