Question about JVC Audio Players & Recorders
Trying to get my JVC radio connected into my 2005 cavalier. I need a converter because the connection for the factory radio which is in right now doesn't fit into the port in the back of my JVC cdplayer. I was wondering if you could help me find the right part which would connect the two.
    Scholar:
  • 144 Answers
Try your local electronic store, they might have the correct plug.
Posted on Jul 08, 2008
Installing a Dual XDVD276 radio in a 2005 Chevy Impala without the factory end of the wiring harness.
You will need to splice the wires as it will be hard to find the right connector to attach to the harness wires. Use the wiring diagram for the car (get it at Alldatadiy.com) and the one that came with the Dual unit to figure out which wires connect to each other.
Nov 30, 2017 | 2005 Chevrolet Impala
2000 chevy venture. How do I install a JVC stereo?
Check your local Walmart or Auto Parts store for the correct wiring kit to change your factory radio to a JVC...the kit is inexpensive and provides professional connections that are easy to trace...remove the face plate around your factory radio, and you will see 4 corner bolts that hold the radio in place...be sure the antennae connections are the same size. Hope this helps.
May 15, 2015 | Chevrolet Cars & Trucks
I am trying ti install a pioneer stereo in my 04 cavalier and the speakers hum but no stations come in
Check to make sure all connects are right and the ground is connected to a good clean body surface. It is best to use a factory ground, the wire is black and the bolt/screw will be green. Also use the originl stereo's power wire.
Jun 25, 2014 | 2001 Chevrolet Cavalier
I am trying to connect my JVC KD-G340 car CD player to a headboard in my bedroom. I am using a radio shack A/C to DC power converter as a power supply. When I connect the Black Wire (instructions say to...
your ac-dc converter is not properly shielded or grounded, you need to replace it with a good one.(or you may wire you cd player chassis to a grounding receptacle, most ac outlets the center plugs are the ground terminals)
some car cd-player has a memory circuit, that will remembers on what state it was before power was remove, like yours it will play again as soon power is applied to it..
Feb 09, 2011 | JVC KD-G340 Car CD/ MP3 Player
2003 E250 Would like to replace original basic stereo radio (only two speakers in front doors at present) with JVC radio (that can connect to 4 speakers). Need radio removal directions and type of speaker...
There are 2 holes on each side of the face of the factory radio. Special U-shaped rods slide into the holes to unlock the clips and pull it out. You can buy them from a parts store for a few bucks or use a metal coat hanger and make them yourself (all they do is push straight in the holes). To install a (JVC) radio, you can buy an adapter plug from a car stereo shop or best-buy that connects to the factory harness.
Jan 25, 2011 | 2003 Ford E250
Installing a cd player in a 1992 honda accord
The harness looks like what is depicted on this link: http://cgi.ebay.com/JVC--16-PIN-WIRE-HARNESS-FOR-CD-PLAYER-BLACK-BRAND-NEW_W0QQitemZ370214069143QQcmdZViewItemQQimsxZ20090612?IMSfp=TL090612198008r8862
This connector fits the following JVC Car Radio/CD/MP3 Players with 16 pin connection.
All wires are labeled.
Hope this helps....................sodeep
Jul 26, 2009 | JVC KD-G220 CD Player
Installing subs, how to use rc converter
from the rc converter i connected to the rear speakers taking both positive (left and right) to the positive on the factory speakers, then done the same with the negative (left and right) to the negative of the factory speakers. i connected with a quick connect. then from the converter to the amp using rc's. since my battery is in the trunk, the only wire i had to run through the car is the remote wire from the radio to my amp and then my subs to my amp.
May 14, 2009 | 2005 Chrysler 300
Trying to figure out if i really need a special wiring harness for my 2005 gmc sierra 1500 i just got a new kenwood stereo to replace the factory one and have been told that i have to have a special...
HI there... It would be a wise idea to get the special wiring harness for you aftermarket radio. There are several reasons for this. 1 is that it will make your installation a lot easier because it will plug right in to the factory plug and all you have to do is wire the radio to the wires on the new plug.
2) the newer vehicles have the radios wired for lights when you turn your headlights on. aftermarket radios don't always have that. also your stock radio probably stays on when you turn your ignition off and goes off when you open a door. the aftermarket radio is not set up for this and could cause electrical problems if not hooked up. to avoid any nasty electrical headaches I would advise getting that special plug. Hope this helps you out
Jan 03, 2009 | 2003 GMC Sierra
Factory CD changer connecting to after market radio
Most likely, not. If the CD changer is a JVC, some car manufactures use name brand components, then you should be able to find an adapter. 99% of the time it has to be JVC to JVC, Sony to Sony, etc. I came across a similar situation and decided to use a head unit with a USB input, now I have thousands of songs on a USB mem. stick and no longer need the CD changer and gained some extra room in the back of the vehicle.
Hope this helps ya.
Aug 19, 2008 | 2001 Ford Expedition
Amp
if its the factory radio more likely it dont have RCAs ..You will need a 'speaker to line level adaptor" ..This has 3 or 4 wires at one end and RCAs at the other.simply connect a left and right set from behind radio or from rear speakers into left and right sets on adaptor ..then connect your RCA cables side to amplifier using RCA wires.
Dec 15, 2007 | Car Audio & Video
22 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
