Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
I've forgotten how to transfer spreadsheets from my computer to my flash drive (been a long time since I used it!) Probably need a new one for more space - how can I tell?
  • SanDisk Master
  • 27,725 Answers
Right click on the drive select properties will tell you how much free space is on your drive
click start all programs open windows explorer navigate to the spreadsheets the select the spreadsheets right click copy and then paste them into your cruzer usb or select all spreadsheets click and hold the cursor and drag and drop them into cruzer or right click and select send to cruzer
hope this helps
Posted on Dec 31, 2010
Windows run doesn't keep my work history
you have to physically save any work
save the history to a usb drive in case you have computer failure
Plug the flash drive into your computer's rectangular-shaped USB drive.
Wait for Windows to recognize the system.
Windows operating systems use "plug and play" technology, which means that computer peripherals like USB flash drives can be recognized instantly by the system without further need for device configuration.
Open the drive on your computer.
Open the "My Computer" directory if using Windows XP or the "Computer" directory if using
Windows 7 or Vista. Locate the flash drive letter and icon under the section named "Devices with Removable Storage." Double-click the flash drive icon to open it.
Transfer files to the flash drive.
Click the "Restore" button in the top-right corner of the "Computer" or "My Computer" directory to shrink the window so that you can view your computer's desktop background.
Open the folders or locations of the files which you want to save to the flash drive.
Click and drag with your mouse each of the files and folders you want to save to the flash drive over to the empty space in the "My Computer" or "Computer" window.
Release the mouse button to let the files "drop."
Close the windows and directory locations when finished.
Save files directly onto the flash drive. From an open file (i.e. text, spreadsheet, image files. etc.), click the "File" menu and "Save as" option.
Select the "My Computer" or "Computer" directory in the drop-down menu at the top of the "Save As" box. Double-click the flash drive letter under the "Devices with Removable Storage" section.
Click the "Save" button to save the file onto the flash drive.
Close the windows and files when finished
hope this helps
Oct 17, 2012 | Microsoft Windows XP Professional Full...
Can't transfer my email files from old computer to new computer
Good Day!
To transfer files from an old computer you can use USB or flash drives, copy the files from your Old Computer to Flash drive, after copying---attach the flash drive to your new computer then copy the files and save it. This is the easiest way to transfer files.
Other way of transferring;
-You can also transfer files by Burning your files into a CD/DVD and copy it to your new computer.
-Get your hard disk from the old computer and attached it to your new computer
-Or connect/network your two computers.
I recommend USB or Flash drives, the simplest and easy way.
Hope I was able to help.
Jul 16, 2010 | Microsoft Windows XP Professional for PC
Antivirus System PRO virus.
Hello and thank you for using Fixya!
Purchase a flash drive (a cdrom will not work for this) and back-up your data on the thumb drive. I would recommend an 8 gig as to fit all your files.
Place the flash drive in the new computer and scan it immediately with the Norton.
By the way, there is one great software that will save the old computer and it only cost 30 dollars. I use it to kill this Rogue on all my customers computers and it takes me 10 minutes to get rid of it. Definetly worth the purchase!
http://www.enigmasoftware.com/
Dec 06, 2009 | HP Computers & Internet
I have windows vista just had a new hard drive installed the data off the old drive has been put onto an hdd caddy how do I load it back onto the new hard drive of my computer, the caddy is a plug in via a...
When you insert the usb cable from the caddy into a USB port on your notebook, Vista will automatically recognize it and open a dialog box. Choose to view files and folders.
Open another Window using Explorer and resize it so you can see the contents of your C: drive.
Then simply drag your files and folders from the caddy to the C: drive where you want them.
Remember that transferring program files will NOT help you as many of the files needed to run a program are located in other folders such as yours Windows directory. You will need to reinstall any software you wish to use.
This method is strictly for data transfer, as an example all your pictures, documents, spreadsheets, etc.
Sep 24, 2009 | Dell Studio 15 Laptop
Transfer memory from hard drive
Hey jockos,
If you're positive that it's only the motherboard on your first computer that's currently defective, you should have a number of options available to retrieve files from your hard drive.
Generally, the easiest way to do so is simply installing the hard drive into another computer. This should allow you to transfer files back and forth between the two installed drives freely, using a standard drag-and-drop method. Often step-by-step instructions on how to install a second hard drive can be found in your computer's owner's manual documentation, but may just as easily be found by looking for "how to install a second hard drive" using an online search engine.
Please keep in mind that once the hard drive has been installed onto another computer, it is strongly suggested that you only copy and transfer saved files such as word documents, spreadsheets, pictures and movies to the new drive. Transferring full programs and executable files manually may result in software conflicts/errors which may not be easily resolved.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 02, 2008 | Computers & Internet
Sandisk cruzer 1gb
empty the recycle bin? reformat the flash drive?
Dec 03, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
69 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
