SOURCE: no steam coming out and water tank not pumping water into generator to make steam
The Rowenta DG-980 Iron/Steam Generator works great from our experience (it is a consumer grade unit with commercial grade technology) and over 90% of the user reviews I have seen are happy with it, unfortunately it is a discontinued model & the newer replacement is not as good. Service seems to be rather thin, as is the case with most corporate entities; I was on the phone for 30 minutes before I was able to locate service center in Concord, CA (I am in SoCal), and is the only one in the state that does repairs on them, and I am going to check them out...stay tuned.
SOURCE: Rowenta DA75 - Won't Steam
Can you remove the steam button if you can fill with water heat to maximum and holding over sink remove steam button rod this will clean the steam traks but be careful this gets very hot.
Thanks J
SOURCE: Taking a Rowenta DX1900 Apart
Not sure about your model, but newer irons have the screws hidden under snap-on covers. Look for a small cover that may have a slot where you can insert a small screwdriver and lightly pry. Chances are you'll leave marks. They are not made to take apart so there is also a chance you'll break the internal tabs that snap/hold it together. You may be able to super glue them back. There should be a removable coverplate at, or near each end.
SOURCE: rowenta dx6700
The wire inside the cord is likely torn ant it connects and disconnects as it is moved back and forth. This happened to me too. I just need to find where to get a new cord.
SOURCE: Rowenta Effective Iron - Model DX1700-U1 NRB01-01
I just drop it a few times on the floor really hard a few times and then it gets hot again!!!
