Question about Fantom Drives 120 GB Hard Drive
Light blinks red, blue, red, blue, no action - Fantom Drives 120 GB Hard Drive
Blinking red light no picture
No picture or do u have a blue (or some other color) screen? And the blinking red light, is that the indicator light down by the power button that is blinking? I have the same tv and very similar problem, i have a blue screen and the red indicator light is blinking. If you have gotten ur problem fixed I would love to know how, or vise versa if I get mine fixed.
Sep 11, 2011 | Toshiba 65H84 65" Rear Projection HDTV
My wii fit board will not turn on it is new please help
Steps:
  • You need to make sure game is in first
  • push power than blue light will blink
  • after the light finishes blinking and still does not turn on then do sync procedure
  • open the battery side and push the red sync button then quickly push the sync button on the wii and wait for it to blink and light should be on
Mar 05, 2011 | Nintendo Intec Nintendo Wii Fit Action...
When charging battery green light flashes then red 3 times
KODAK Easyhare digital camera light status
1. Blinking green light(or blinking blue or white light in some models) - Means camera is performing a power up procedure. Note: Wait a few moments to see if the camera displays a solid green (or blue or white) light or a blinking red light.
2. Solid green light(or blinking blue or white light in some models) - Means Camera has sufficient power
3. Blinking red light - Means camera batteries are weak or need replacement; If battery are new and still red light camera needed to be repaired
For futher assistance contact Kodak support line 1 800 235 6325 (23KODAK)
Nov 21, 2009 | Kodak EasyShare M863 Digital Camera
They Won't Charge!
Try to press the power boton in the same time you plug the charger, after this action mine is working and charging perfectly, maybe this is the "reset" solution... Hope this helps you.
Nov 17, 2009 | Motorola Mobility S9 Headphones
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
Tv lights blink, tv not turning on
HI, the fly back transformer has failed in your unit. this will occur if the dust level is high inside the set. the dust will settle on the cooper windings and, create an arch that will short out the entire power sector of this unit.
The fly back is usually the first to take the hit. replacing this will fix this issue.
Jul 11, 2009 | Televison & Video
I have a plantronics 520,
Start with your headset turned off. Press the talk button on the headset. Hold it until you see the light on the headset begin to rapidly blink red, blue, red, blue, red, blue, etc. Let go, the light should continue to blink red and blue. Go into your phones blue tooth menu and search for the headset. The phone will only find the headset if the headset is in pairing mode (blinking red and blue). The pass key is 0000.
Apr 10, 2009 | Plantronics Hama Voyager 520 Bluetooth...
Hello i have a JVC model # HD56G786 DLP TV. The problem i have is that the set will not turn on. Whe i try to boot the set up it starts as normal as the blue power light stays on and the small red...
I would agree with you on that the power board could be at fault. The best course of action would be to get the board/TV checked out professionally. It could be the dry joints, resistors or capacitors.
Dec 04, 2008 | Televison & Video
Tv troubleshooting
I have a 61" JVC that just stoped working. I turn it on and nothing bu the blue light stays on and the red light blinks 8 times and then the blue light joins in.
Oct 30, 2008 | JVC HD-61Z575 61" Rear Projection...
Fantom Drives 120 GB Hard Drive Logo
Top Fantom Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Lyle Siemens
Lyle Siemens
Are you a Fantom Computer and Internet Expert? Answer questions, earn points and help others
