Question about Sony KV-32V65 TV
KV32FS120 red light flashes 9 times per cycle Problem-No picture;no sound What is cause of problem
  • heyesroofing Dec 31, 2010
    I wnat to confirm solution to 9 times flashing red light
  • 10,594 Answers
It seems main power supply section is not working, check IC600 MCZ3001DB and replace it to turn On main power supply section to provide 135V, 14V, 18V and 9V supplies to other circuits in tv.
IC600 is located on A board of tv.
Above info are for technically skilled person, please avoid tv repairing if you do not have prior experience of electronics stuff repair to remain safe.
Thanks.
Posted on Dec 31, 2010
  • 597 Answers
There are most likely two sources of such problem. First is either the lamp is faulty or there is a bad capacitor on either the main panel or the power panel. Power is reaching the unit of the television but it is not utilizing it, that is why you have the power light blinking 9 times/cycle.
First press a channel button from the remote or the television to see if it is not just the standby light that is blinking. If it does not power on, then you need to disassemble the television and and check which is the faulty component out of a bad capacitor or a bad lamp.
To Fix this problem, you will have to unplug the television for a while, at least about 6 hours for the high voltage to dissipate as television stores voltage in it. Then you get a screwdriver, open the back compartment and assess the lamp, If the lamp seems bad(either has a blackish substance in it or broken), then you replace the lamp as it is the cause for the problem. If it looks okay, then you need to check the main panel and the power panel of the television to see if there is a bad capacitor on any of the two.
You will have to disconnect the main panel and power panel from the television, then you check if there is any capacitor that has shrinked, melted or burnt out, then you get a soldering iron, to melt it off from the back side of the panel, get a replacement capacitor, then you fix it in then solder it back on with some lead, then you cut out the extra tip from the capacitor, then you place the main panel and power panel back on then you reverse the process to couple the television back together.
If you are not familiar with such technical and electrical activities i will strongly advice you call a friend to assist you on this.
Hope this helped.
Take care and good luck
Sony KV32FS120 Trinitron TV No picture or sound when power button on remote is turned off. Red light at front of TV blinks nine times per cycle.
Once your television blinks about 9 times then it means there is a problem somewhere most likely the lamp of the television. Another source of this problem is also a bad capacitor from either the main panel or the power panel.
If your remote turns off actually it is because there is nothing to operate on the television, so once your television starts the blinking light, the remote will not be able to operate the television, once you unplug the television and plug it back then press the power button, the remote will do the same.
Until the television is fixed is when the remote will work normally.
Dec 31, 2010 | Televison & Video
Panasonic TCP58S1 has no pic. or sound. Red light blinks 9 times.
It's dead. 9 Blinks means the display adaptor is dead. If it's still under warranty, you're covered.
Jan 22, 2010 | Panasonic Viera TC-P58S1 58 in. Plasma...
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Jul 15, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Troubleshooting
I will need the model number of your set and how many times the LED is blinking in between pauses.Then I should be able to help you with wahts happening with your Sony
Jul 04, 2008 | Sony Televison & Video
Toshiba 52Hmx94
How many times does it blink?
I replaced the ballast in my 62HM84 and it fixed it. The problem was TV would not turn On, Red light solid green light blinked 9 times then TV would try to restart. At first I thought it might of been the bulb, so I replaced it, same results. Next I replaced the ballast which is pretty easy, just take pictures before you remove the light engine so you can go back to the picture to verify the connections when reinstalling.
Dec 25, 2007 | Toshiba 52HM95 52" HDTV Projection...
No picture or sound - Power Save light blinks red 5 times - nothing on the screen
i also have the same problem with the flashing green light for a while then a different red light starts blinking on and off around 5 times....and i replaced my burnt bulb with a new one...still no picture.
Oct 24, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Sony tv kv32fs120 has no power , 9 times blinks
Replace diodes D645, and D647 in standby power supply circuit.
Part# 6-500-567-01
Aug 29, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32V65 TV Logo
110 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
