Question about Plumbing
The tap newly installed ossilates when turned on.
  • dejong1 Dec 31, 2010
    FIXED THE PROBLEM A.S.A.P Thank you.
  • dejong1 Jan 05, 2011
    IT CERTAINLY WAS,FIXED THE PROBLEM.
  • 8,197 Answers
May I please get a little more info on your problem so I can help you more.
Posted on Jan 01, 2011
  • 43,501 Answers
That is called water hammer...
With certain types of valve/washer arrangements and the right pressures the faucets can chatter like crazy....
There are a couple of ways to fix that...
The simplest usually is to just cutback the shutoff valve(s) a bit on the hot and cold water till the chattering stops...just turn on the water and then turn the shutoff valve till it stops... you still will have plenty of water...
or...
install a whole house pressure reducing valve to cutback the whole house pressure... if you are over 50 psi, that is a good idea as it will make everything last longer and the extra pressure is not needed...
or...
Install water hammer arrestors that will absorb the check waves and stop the water hammer...
heatman101
Posted on Dec 31, 2010
  • D. Floyd Kolb
    D. Floyd Kolb Jan 01, 2011
    Could yo please accept the soulution and rate it so that it comes off of the list of questions to be answered yet...
    Thank you!! Glad your happy!!
My words with friends game stopped working. How do I fix it?
Sometimes it is due to updates newly installed. Go to settings, application, under application look for your game application, on previous android, you can find the installed updates replaced by uninstall update, tap it and it will uninstall the update, on marshmallow, you need to tap storage, you need to clear the cache and data. Now the catch is you will lose all progress if you dont sync it with your social media account but setting up the account hope will do the trick of getting your progress back. Good luck.
May 17, 2016 | Samsung Galaxy Tab Tablet PC
Tip
How to change the mp3 background on ipod.
Turn on your iPod Touch.
  • Step 2 Tap "Settings," then "General."
  • Step 3 Tap "Wallpaper."
  • Step 4 Tap the image you'd like to use as your new wallpaper from the list on screen. Then, tap "Set Wallpaper." Your wallpaper will be changed to the new image you have selected.
    Microsoft Zune
  • Step 1 Turn on your Microsoft Zune.
  • Step 2 Select the "Pictures" menu option.
  • Step 3 Select a picture that you'd like to use as your Zune wallpaper.
  • Step 4 Select "Apply as Background" to change your Microsoft Zune background to reflect your newly selected picture.
  • on Jun 02, 2010 | Audio Players & Recorders
    Sony trinitron kv35s26 no high voltage.
    Continuous blinking of standby light to Sony TVs indicates a fault with its II2C bus. Your set need an through checkup, which can only be done by any experienced service technician. Anyway, try the site linked here, and see is there any details which could help you. Do a search by entering the brand name to your device by its search box at top right of the display window, because, posts are not arranged in alphabetical order, but by brand name at first.
    Dec 21, 2012 | Televison & Video
    The fan ossilates but doesn't blow any air
    my guess just from what you have told me would be the motor on the fan has given up. there aretwo mototrs in it , one to run the fan and the other one makes it ossilate. As a temporary fix if you are able to get the fan apart and access the motor you can give the shaft a manual turn with your fingers and see if it will get it going. also as funny as it may sound sometimes if you just tap on the motor lightly but firmly with a small wrench it will also get it going again. What has most likely hjappened is the little brushes in the motor wear out and dont make a perfect electrical contact once they are worn so a little coaxing sometime gets it going again but no gauranties.
    Let me know if this works and you can also let me know the age of it as well. Thanks for your patience and good luck.
    Dec 12, 2010 | Lasko 2554 Tower Fan
    How do I turn off the tap to click with Windows 7 newly installed?
    Go into the CONTROL PANEL. Then click on the MOUSE icon.
    There should be a tab "TAPPING".
    You will find the setups you need in there.
    Apr 27, 2010 | ASUS Eee PC 701 Notebook
    After installing newly charged batter when I turn
    How old is the batt.? I purchased a digital camera and after 2 months the batt. went bad. Have had it now 2 years and several batt.later.
    Dec 25, 2009 | DXG Technology Video Cameras
    Bolt on timing belt tension thing is stripped on 93 escort.
    If the blots threads are gone then probably the threads in the hole it goes into are gone also. You need to get a thread tap to run into the hole to create new threads and then get a replacement bolt to install into the newly tapped threads. Good luck. You can buy a good tap and die set that will have the thread tappers you will need to so this.
    Mar 10, 2009 | 1993 Ford Escort 4 Door
    Problem in my HITACHI CMT2153 TV
    hi, the problem is in the vertical ossilation if only u can trace the bad component.. let me know
    Jan 10, 2008 | Televison & Video
    Plumbing Logo
    163 people viewed this question
    Top Plumbing Experts
    Paul Carew
    Tom Chichester
    Are you a Plumbing Expert? Answer questions, earn points and help others
