Question about Cadet Manufacturing C152 Com-Pak Plus Heater
I need four knobs for in the wall cadet heaters. Renter took all of the knobs off and lost them.
To find replacement knobs, please try either of the following online solutions:
http://www.reliableparts.com/catalog/Cadet-Repair-Parts-Accessories-466898
http://www.cadetelectricheat.com/heateraccessories.html
Hope this is helpful -
Cadet
Director of Marketing
lsteele@cadetco.com
Posted on Jan 24, 2011
My cadet wall heater wont turn off
My cadet heater was doing this so I pulled it off of the wall and saw that the two wires coming from the thermostat portion had melted out of their insulation and were crossed. The heat is of some concern, but for now I just wrapped them in electrical tape to insulate them better against melting
Mar 11, 2012 | Cadet Manufacturing Built-In Wall Heater
I am an electrical contractor of 20 yrs in spokane, Wa. I have used cadet heaters for most of that time. I have an apartment that I built and have rented out that is heated only by cadet heaters. In the...
i am also an electrician. we have had the same problems on our properties.the motor goes out which in turn keeps the element on and gets hot and burns up, setting a small fire. more smoke than fire. cadet needs to put a safety cut out so that when you lose the fan it shuts the element off and the other way around as well.
these are dangerous and will be replacing 100's of them
Jan 24, 2011 | Cadet Manufacturing Com-Pak Max CM202...
I need the little pins to set timer. Renter took them off. MK
The part number for those is:
156T1978A
They should be available thru local hardware sources and of course online if you so choose.
John
Jan 19, 2011 | Intermatic WH40 - Water Heater Time Switch...
I just need a wiring diagram---with a thermostat-- for a cadet FX-152 , 240 volt ,1500 watt wall heater
grainger has them- home depot. wire is easy wire one side straight to 1 wire on in coming power the other side use your thermostat to break curcit ie wire into stat out of stat to voltage
Jan 15, 2010 | Cadet Manufacturing CADET SL Series Small...
Cadet wall heater
Since I don't know what model of heater you have there might be a reset button to reset or an over temp switch (button sensor with 2 wires going to it) that needs to be replaced. You might check the recall list to see if this one has been recalled and should not be used.
Sep 11, 2008 | Heating & Cooling
Cadet wall mount and thermostat
your wiring is all wrong. for a 240 heater a 20/20 tandem breaker will not work with a 240 heater. you need a 20 amp two pole breaker. the two wires at the heater need to be connected to the line. you probably have two black wires at the heater. one connects to the white romex which should be taped black, and the other romex black connects to the other black wire. at the panel one white goes to one side of the breaker and the black to the other. the bare ground goes to the neutral bar.
Oct 27, 2007 | Cadet Manufacturing 67507 Heater
Cadet Manufacturing C152 Com-Pak  Plus Heater Logo
162 people viewed this question
Top Cadet Manufacturing Heating & Cooling Experts
Paul Carew
Tim Whalen
Are you a Cadet Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
