Question about GPS
I had the battery out of the car while I put a new auto trans in.when I put it all back together the security horn comes on and will not let me start the engine.this is a 1995 2.2 toyota camray.
    Brigadier General:
  • 7,191 Answers
You have posted the problem under "GPS Devices" category.
Kindly submit the question under 1995 Toyota Camry section on the website by clicking this link so that the best car experts can view and post a solution to the problem.
On the page which opens, type the question in the "Ask an Expert" box and click on "Ask a Question" button.
Thanks for using FixYa.
Posted on Dec 31, 2010
New battery new starter. fuel pump comes on but when I turn the key to start all dash lights go out and nothing?? help please :(
Dirty battery cable terminals, faulty cables or loose earth connection, engine wont turn water in cylinders, battery goes open circuit under load. can cause this fault.
Nov 13, 2016 | Cars & Trucks
1997 pathfinder is there anyway to bypass the security system car keeps flashing lights and honking horn and won't turn over battery is good any help?
try restarting the car brain!!! Troubleshoot: disconnect battery and put it beside than wait for 30 seconds, take negative wire, positive wire from battery and hold them together for 20 seconds than retrive the steps and put things back together.
Jul 13, 2015 | Cars & Trucks
Horn keeps going off unexpectedly- usually at night
Often times the problem is a weak horn relay or a weak horn pad on the steering wheel. You can remove the horn relay or fuse to prevent the horn from blowing until the problem is fixed.
Feb 19, 2015 | 1998 Lincoln Continental
How do i get the transmission mounted to the motor of a 1979 ford bronco
is this a auto or manual ? if manual then it takes patience as the pilot bearing is a very close precision fit and has to be damn near exact. if auto, make sure the torque converter is properly installed and seated all the way in trans. I always use a floor jack under harmonic balancer to tilt motor down and to secure engine movement as well as a floor jack under trans on piece of plywood 1 foot square so not to damage trans pan. lift trans align pilot pins and get bolt or two started. just take your time and it will go providing these are the proper items being put together
Apr 11, 2011 | Ford Bronco II Cars & Trucks
I change the turn signal lever I took apart unplunged everything carefully put everyhing back together carefully but as I was workig on it I heard my horn honk twice I look no bear wires anywhere finish...
your security system is activated. try turning the key on let set for 10 minutes turn it off then start. on some models it has to be done 3 times on off on off on off start. 10 minutes each time
Jun 22, 2010 | 2000 Chevrolet Tahoe
Putting together the 2.9 engine and dont know if there should be a tube that the transmission dip stick goes into
There should be a tube that comes up from the auto trans with one tab to secure it to the bell housing bolt (trans bell housing bolt goes through tab, then through the bell housing) to the engine block. Pass side.
Feb 24, 2010 | 1989 Ford Bronco II
Security system/battery
plz check the following and update me
1. Fuel (To be exact proper air/fuel ratio, normally it is about 14/1)
2. Spark (in appropriate moment)
3. Proper timing (the valves should open and close only in appropriate time)
4. Compression in the cylinders (Normal compression is 120 - 170 psi. The engine won't start if the compression is lower than 70 - 80 psi.)
Jul 14, 2008 | 1997 Honda Accord
GPS Logo
24 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
