Question about Brother Multi-Function Center MFC-665CW All-In-One InkJet Printer
Paper jam I have a brother 665cw printer.it tells me there is a paper jam. I have taken the tray out and the back cover off several times and there is no paper jamed .but it still shows paper jam on the screen, can you help with this problem please
  • Anonymous Mar 17, 2009
    I have taken the back off, opened the top scanner, removed the tray and taken out the jam. Unplugged it and tried running card stock through it, but still it says paper jam and does not sound good either. HELP!!!
  • Brother Master
  • 13,433 Answers
Give this a shot
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Posted on Jun 03, 2009
I was printing off the computer and got a paper jam. After clearing the paper jam and restarting the printer I can not get it to print. It prints by going through all the motions, just no ink on paper...
Posted on Jul 25, 2009
Unable to init. 50, Unable to Init 30,
paper jam or some sensor problem, in error 30, clean the strip encoder located at the top of the printer head, his color is transparent.
Jan 04, 2014 | Brother MFC-665CW All-In-One InkJet...
Im getting unable to print 50 error on my brother mfc 665cw
The paper jam you had probably lifted the long, thin, plastic encoder strip out of its slot. It is making the printer think paper is still jammed. Try gently pushing the strip back into the slot. You might have to use a screwdriver or other thin instrument to get to the strip.
Be sure printer is off when you do this.
Sep 18, 2011 | Brother MFC-665CW All-In-One InkJet...
How to open drum to remove the jammed paper inside
Hi Good day!! here are the steps how to remove paper jam in brother hope it help's you!!
1. Pull the paper tray completely out of the printer.
2. Pull the jammed paper up and out of the printer.
3. Press the cover release button and then open the front cover.
4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
5. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared.
6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
7. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
8. Pull the Duplex Tray completely out of the printer.
9. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
10. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
11. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
12. Put the drum unit assembly back in the printer.
13. Put the paper tray in the printer.
14. Close the front cover.
Oct 19, 2010 | Brother MFC-7440N Laser Printer
I have a paper jam
Relax my friend,don't worry.Your printer has two major sector one is paper feed sector or other is fixing unite.it problem is fixing unite there are a sensor it is displace or broken leg.
You try to several time to open it but no success.so you need help an authorized dealer or service center.
Dec 13, 2009 | Brother DCP 7010 Multifunction Laser...
My Brother HL 5250DN printer has started making a loud clicking sound when it tries to feed paper for printing. It then stops and the paper light starts flashing.
Clear the jammed paper as follows.
Observe Cautions signs in printer.
Always remove all paper from the paper tray and straighten the stack when you add new paper. This helps prevent multiple sheets of paper from feeding through the printer at one time and prevents paper jams.
1. Press the cover release button and then open the front cover.
2. Slowly take out the drum unit and toner cartridge assembly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
3. Pull the paper tray completely out of the printer.
5. Pull the jammed paper up and out of the printer.
6. Open the front cover again.
7. Open the back cover.
8. Pull the tabs at the left and right hand sides toward you to open the fuser cover (1).
9. Using both hands, gently pull the jammed paper out of the fuser unit.
10. Close the back cover.
11. Pull the duplex tray completely out of the printer.
12. Pull the the jammed paper out of the printer or the duplex tray. Put the duplex tray back in the printer.
13. Push down the blue lock lever and take the toner cartridge out of the drum unit. Clear the jammed paper if there is any inside the drum unit.
14. Put the toner cartridge back into the drum unit until you hear it lock into place. If you put the cartridge in properly, the blue lock lever will lift automatically.
15. Put the drum unit and toner cartridge assembly back in the printer.
16. Put the paper tray firmly back in the printer.
17. Close the front cover.
18. Make sure that the Paper LED is now off and the printer is ready.
After clearing paper jam if noise persist printer may need a Repair Tech and parts replacement for broken or wore parts.
Dec 04, 2009 | Brother Office Equipment & Supplies
Paper jam while printing on BROTHER MFC-290C all-in-one
hey
try this
alternative :
Jun 03, 2009 | Brother MFC-290C Printer
Paper jam
For this and any other print jam problems try this;
Open the scan bed tray and push down the button at the front (scan bed tray open switch)
I found if your print jam occurs and you go through this procedure, the jam clears itself.
With the tray still up and switch held down, try and print something.
See how far the paper goes through the print cycle before jamming. If it jams when it reaches the print head...clean under the print head and try again.
Hope this helps
Mar 17, 2009 | Brother Multi-Function Center MFC-665CW...
Printing problem with MFC-665CW
1. Take paper tray completely out of the machine.
2. Remove the rear cover, clean the paper pick-up roller.
3. Put rear cover back, put paper tray into machine.
4. Copy a blank page for paper feeding test.
Jan 23, 2008 | Brother Multi-Function Center MFC-665CW...
Brother Multi-Function Center  MFC-665CW All-In-One InkJet Printer Logo
296 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
