Question about Amana PTC093B35AM Air Conditioner
Braker trips, and when re-start the unit FP shows
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
You have a defective compressor tripping the breaker or control card issue. The FP means you had a power failure, hence the breaker trip.
Their is nothing you can do. I do not think you have the equipment to repair or test the unit.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Dec 31, 2010
Washing machine trips breaker
I am wondering if you have some thing else on the same braker that is running at the same time.
Jul 01, 2014 | Frigidaire GLET1142FS Dryer
I have a Beachcomber Model 350 hot tub abd the GFCI is tripped and won't reset
You may have a bad heating element. But first make sure you have power to the gfci. (check the braker) You can test this by disconnecting the heater leads and see if it will reset. If it still trips try disconnecting your equipment one at a time, ie. blower, ozone, circ pump, booster pumps. If nothing solves the gfci issue you need to replace the gfci. All of this is assuming you have a blank gfci receptical monted to your spa pack.
If your talking about the 50 amp gfci at the braker box try pushing the braker all the way to the off position then back to the on possition. If it trips right away do the above.
Aug 06, 2013 | Pool & Spa
I HAVE XB10 HVAC SYSTEM TRIPS BREAKER
could need a start assist for compressor or could be weak breaker
Dec 03, 2012 | Heating & Cooling
My europower ep2500 amp the braker trips when I power it on
Hi,circiut braker trips only when the load on it is to much.
That is carry what is bigger than it watt, or can not carry too well. If you have another amp., you can put some load on that to reduce to braker always tripping off.
If that is the only amp. you have in what you are doing, just reduce the amp. volume to half(setting at 12 O CLOCK). it will work, but will not be too loud as before.
Take care.
May 21, 2010 | Behringer EUROPOWER EP2500 Amplifier
Usually trips breaker but occasionally works fine....when hooked to higher amp breaker line works fine.
it could have a small leak to ground on it,,, thats why it trips the brakers,, on a higher braker the leek off also needs to be higher than 50milly amps to trip the braker,,, this unit uses 13 amps
Oct 31, 2009 | Faberware 12-55 Cup Coffee Urn
No power on kenmore range
Make sure there's power getting to your range, oven or cook top. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power with a voltmeter or by plugging something else in.
If everything above is ok, move on to the power cord junction point. make sure the power cord has not separated from the junction point on the backside of the unit.
Jul 16, 2009 | Kitchen Ranges
Breaker trips when unit is turnedon. Breaker works properly.
replace the timer.
It is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 27, 2009 | Kenmore Washing Machines
Circuit breaker trips when turning unit on. only unit on circuit has triped on several circuits can find no shorts on wiring.
DOES IT BLOW THE BRAKER AS SOON AS IT TURNS ON OR DOES IT TAKE A FEW SECONDS. INSTANTLY WOULD MORE LIKELY BE A SHORT IF FEW SECONDS THE COMPRESSOR IS PROBABLY DRAWING MORE AMPS THAN THE BREAKER CAN HANDLE SO IT BLOWS. TRY TAPPING THE COMPRESSOR NEXT TIME YOU ATTEMPT A HOUSE CURRENT START UP. i HAVE A WINDOW AIR CONDITIONER THAT NEEDS TAPPED FOR STARTUP FOR THE SUMMER SEASON. GOOD LUCK
May 01, 2009 | Dometic RM2852 Refrigerator
Circut breakers
Is it after it has ran for a while or tripping every time it comes on? If after it runs awhile check your wire tightness at the breaker and at the unit. Loose wiring will heat up a braker and trip it. Also check to see that the rating of the unit and the breaker are matched.
Jun 05, 2008 | LG L1004R Air Conditioner
Amana PTC093B35AM Air Conditioner Logo
109 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
