Question about Kenmore Front Load Washer
Kenmore front loading waster. Model: 970-c45062-10. Loud whirring noise during spin. I can't seem to find this model listed anywhere to determine the replacement part I require. I even called Sears part centre and they didn't have it listed. I assume the noise is bearing related. Help!
  • Darkan9898 Dec 31, 2010
    It may help to know this was purchased in Canada (Ottawa, ON)
SOURCE: kenmore Front load washer model
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Posted on Aug 30, 2008
SOURCE: Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Posted on Nov 11, 2008
SOURCE: kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Posted on Dec 14, 2008
SOURCE: kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
Posted on Apr 03, 2009
  • 670 Answers
SOURCE: loud banging noise during spin cycle of my front
If you spin the drum by hand, does it make any kind of thumping or banging noise? If it does, then you probally have a broken spider arm(s). This is very expensive to repair, unless you are handy, it may not be worth fixing. The link below shows the problem and how it can be fixed.
http://www.jimwilliamson.net/misc/2006-08-28-front-load-washer/index.html
Posted on Dec 23, 2009
Cabrio washer wtw5500xw0 loud spin and grease on floor
FIXED Cabrio has loud noise during spin - ApplianceBlog
www.applianceblog.com/.../16339-Cabrio-has-loud-noise-during-spin
Aug 21, 2009 - 10 posts - ‎5 authors
Help Jake I have a Whirlpool Cabrio model WTW6600SW2 it is almost 2 ... a week just started making a very loud noise only during spin sounds like ... size washer (110.297) (loud whirring and grease splatter) and am trying to ...
How to tell if your bearings are bad on a Whirlpool Cabrio ...
? 1:01
https://www.youtube.com/watch?v=5rHn13lKjzc
Jan 19, 2012 - Uploaded by RenewAppliance
http://washerdryerrepairhelp.com/whirlpool-cabrio-maytag-bravo-and-kenmore-oasis- ... My floor under the washer machine hasgrease/oil marks. ... and make the suspension bad when it spinsmine has been like this for about 2 months now ... Noisy WhirlpoolCabrio washer during spin - Duration: 0:54.
Jan 16, 2016 | Washing Machines
Kenmore front loading waster. Model: 970-c45062-10. Loud whirring noise during spin. I can't seem to find this model listed anywhere to determine the replacement part I require. I even called Sears part...
You have a bearing problem. The bearings can be removed, there are 2 bearings and 1 rubber seal plug. The tub can be removed from the washer and split into 2 pieces (rear portion and front portion), and the bearings removed using a large hammer and a pipe (put the pipe in the hole so it contacts the bearing and hit the pipe with the hammer, then flip over the tub and do the other bearing - there are videos on You tube). The bearing part number for this washer are TSB 6306-2RS-CTS (smaller bearing) and 6307-2RS-CTS (the larger one). These are sealed bearings, and can be ordered off ebay or a bearing store.
Dec 31, 2010 | Washing Machines
I have a kenmore front load washer model 970-c42072. I'm experiencing a loud noise in the drum on the spin cycle even when it is empty no matter what setting (slow normal fast) What would be the...
If you turn the inner wash drum by hand, what kind of noise do you hear? If it is a thumping kind of noise, it would mean that the spider support arms are broken. If the noise is a loud rumbling sound, similar to a jet engine when it is spinning, it would mean that you have a bearing seal failure and the bearings need to be replaced. Either problem is a big job to fix since the entire washer needs to be taken apart. Get a few estimates before deciding whether it is worth fixing. Sorry.
Sep 01, 2010 | Kenmore 44072 Front Load Washer
Kenmore front loader Model Number 970-C42162-00 bearing behind drum pully very noisy
Had noise during spin cycle called for repair $79 dollors later its tub assembly its clamp on the back of drum cost $1000 dollors to repair so if you have 747 during spin cycle buy yourself a new machine.
Mar 16, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore 970-C41062-00 Spin cycle, belt keeps coming off
sounds as if yo umay have a bad rear bearing, and the off balance of it is "throwing " the belt. magor repair, and would ck with manufacture, for possible part warr
Mar 18, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore 90 series loud whirring/howling noise during spin cycle
Sounds like you have a broken motor coupler. They are inexpensive. Can be a little tough to replace but I can walk you through it. You can purchase a coupler here.
http://www.shop.washermd.com/product.sc?categoryId=1&productId=1
Dave
Dec 18, 2008 | GE WBSR3140DW Top Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore model 970-c44072-00
Probably broken shocks. 50 dollar part but pita to replace
Nov 09, 2008 | Kenmore 43142 Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Kenmore Front Load Washer Logo
212 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
