My lid switch fuse keeps blowing. I replaced the lid switch and put in another fuse and it worked until I opend the lid again. The fuse blew again and now replacing the fuse does not help.
    Top Expert:
  • Washing Mach... Master
  • 9,472 Answers
You have a short in the wire. Follow the wire to the control panel and look for anyplace it may be touching another wire or it may have a bare spot and is shorting out.
Posted on Dec 31, 2010
Testimonial: "I believe you are correct but I have not been able to find the source of the short. We had issues with it before so it's time for a new one. Thanks!"
Why does the fuse immediately blow on my power door locks? how to fix this?
You have a short somewhere in the system. Maybe one of the lock actuators or a switch. To test disconnect all locks and switch then replace fuse if don't blow start with driver door and reconnect lock check fuse see if it blew if not reconnect switch active lock check fuse see if ok. Continue with each door separate using same steps until fuse no good you will have found short. Replace shorted part.
Apr 30, 2016 | Cars & Trucks
1998 plymouth breeze hazard flasher fuse keeps blowing
check the hazard switch pull the switch and put a volt meter on the connections with wiring connected to switch if it don't respond or just gives you a L.O your switch is bad and shorting out could happen just from being used a lot or something internal broke switch for that shouldn't be all but 50$ or just go to a parts/scrap yard
Jan 22, 2014 | 1998 Plymouth Breeze
I have a 2005 cavilier..it keeps blowing the main 30amp fuse when the ac is turned on..any help
you need to inspect all AC WIRING, to find the SHORT, thats causing the fuse to blow ! donot put another fuse in until you locate the shorted condition, ( bad connection, frayed wire, bare wire touching metal along this circuit, you might have a bad switch, your ac has two switches under hood, one @ high pressure side and one @ low pressure side. and your main control switch, check all wires & connections
Mar 11, 2013 | 1991 Chevrolet Cavalier
I have a 1994 Ford Thunderbird LX V8. A few months ago when I put the car in park, the air conditioner and the battery amp guage quit working. I found a fuse that was bad and I replaced it and then the...
I'm betting it has something to do with the shift lock actuator or the harness to the actuator. I'm pretty sure it is located on the top of the steering column on your vehicle. The lower part of the dash will need to be removed and then the steering column lowered in order to gain access to it.
This vehicle does have an airbag and unless you experience with airbag systems I would not recommend tackling this yourself.
unplug the interlock. Replace the fuse. Start the vehicle. with your foot on the brake manually release the interlock with you hand and shift through the gears. If the fuse does not blow your on the right track. If the fuse does blow let me know and I'll get you some more info.
Let me know if you have any questions and thank you for using Fixya.com
Oct 25, 2011 | 1994 Ford Thunderbird
Have an HK AVR510 it stopped all sound. I opend it up and found that (under 10 years of dust) that one of the 125V 2A fuses had blown. (it is the first fuse on the right looking from the front of the...
I am now having a very similar issue with an av 100 unit I have had for quite some time now. Bought replacement fuses for it the same exact size and they keep blowing as well.. one thing I notice in the original fuse is that there appears to be a resistor in the fuse case.. maybe it requires a special fuse.
Dec 19, 2010 | Harman Kardon AVR 510 Receiver
I took the cover off of my dvd player to clean the lense. Upon putting the top back on I touched the lid to the back of the power button on the inside and got sparks and blew the fuse. I have tried...
A semi-conductor has shorted. It will continue to blow fuses until you replace the shorted component. If you have electronics background, you can locate the short with a multimeter and a schematic diagram.
Dec 14, 2010 | Panasonic Audio Players & Recorders
Fuse blows every time I put power to Washer. What is the easiest fix?
check for any damaged wiring or door switch if nothing obvious you will need to check other components motor heater timer etc you will need the test equipment to do this or you will need to call a service tech cheers
Nov 05, 2009 | Maytag LSE7806A Top Load Stacked...
Blown Mains Fuse
You should repleace the old transformer with the new one
Jun 13, 2008 | NAD C370 2-Channel Amplifier
Fuse keeps blowing out in my maytag washing machine
the power surge probably shorted out something in the main wire harness or fried your motor. remove the screws from the control panel and look for any wires that are discolored, charred or disconnected. in the event you do't find it there trace the wiring thru the cabinet looking for the same thing. if you don't find that, replace the motor
Nov 16, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
67 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
