Question about Dryers
Heating unit starts and turns off after 4 to 5 seconds
  • 4,323 Answers
Hi
When dryer won't heat or won't turn on or will behave as its behaving with you it means that the Thermal fuse which is located inside duct on the back has gone bad and should be replaced as it cannot be reset. If their is continuity when you check the fuse then it means that the control board is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Dec 31, 2010
We have a new Amana 16 Seer Heat Pump chpf4860d6da and every time the unit turns on the house lights dim for a split second. We had the electrician and local power company check the incoming lines and...
I think you hit the nail on the head. The undersized (to light a gauge) wiring would cause that problem. In most cases it should be at least a 4 or 6 gauge wire. AC Units pull a lot of power in their start up or peak cycle. Hence, the need for the proper wiring.
Apr 01, 2011 | Amana PTH123B25AJ Heat Pump Air...
I have a 5 ton ac with two 10 kw heat strips. The problem is that the unit runs constantly on one stage with the temp. set at 66 degrees in the winter. The second stage heat will kick on if I manually...
Between two stages, the difference temp has been set up to call for second stage.. If you need immediate heat what you did is right. But again you have to reduce to your required temp. Hence, wait the second stage get started.
Jan 13, 2011 | Heating & Cooling
Ac problem
Turn the thermostat off to see if the unit turns off. If it
does than you must have had a call for heating or cooling.
Put into heating mode let unit turn on, lower the setpoint and unit should turn off. If unit is not heating
than you have a problem with the outdoor unit.
Putinto cooling mode, turn thermostat all the way down, let unit start turn thermostat all the way up
if unit shuts off, unit is operating properly
Feb 06, 2010 | Heating & Cooling
The printer has stopped functioning all together.
C3851: Abnormal Low Temp. (Heater)
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Reset your Toners and Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
Mar 31, 2009 | Konica Minolta bizhub C250 All-In-One...
Rheem heat pump. blower will not turn off
The fans are set to delay for 60-90 seconds to remove all heat from the heat exchanger/heater elements.
If the fan runs any longer than 3-4 minutes after the Emergency Heat shuts off, you may have a bad sequencing relay in the air handler.
Jan 27, 2009 | Heating & Cooling
LG PTAC acting strange in heat mode
I believe the problem in lies in the dual stage heat mode setup on the thermostat, but the unit going into defrost does make the unit act kinda strange. Even more so than other types of equipment. I would suggest hiring a licensed HVAC service technician if the problem cannot be resolved by yourself.
Dec 15, 2008 | LG LP120HED Wall/Window Air Conditioner
Furnace
Try to start the unit again and put your hand on the gas valve and feel if the valve clicks before the ignitor stops glowing , if it does click your valve is bad , I just changed one last Fri. with the same problem
Oct 28, 2008 | Goodman GMS90703BXA Heater
Hayward Heat Pro Electric won't stay running
from the Hayward support site....
Why is my pump cutting off and on every 5-10 seconds?
  • Hayward motors are factory wired for 240 volts unless the motor is 120 volts ONLY. Check the voltage of the incoming supply power and ensure the motor is wired or can be wired for this voltage (data plate on motor will help provide voltage and wiring information). Also check for loose or badly connected wires. Contact a certified electrician for repair.
Sep 24, 2008 | Hayward Heatpro 100,000 Digi. Thermostat...
Kenmore elite dishwasher 665 15962990
Hold down the "HEATED DRY" button for 4 seconds to unlock.
Try to press these botton in sequence,Heated Wash, Heated Dry, Heated Wash, Heated Dry.release your hand, the unit will go into diagnostic mode. that is all leds will ON for a few seconds,and start normal operations.
If that does not work, you might need to check the electronic control board if the ribbon is seated properly.
Finally solution, is to change the electronic control board.
Jul 27, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Malfunction C 3851
C3851 Abnormal Low Temp. (Heater):
• The temperature of the Heating Roller Thermistor/ 1 (TH1) is lower than a given level of degree for 1 second or more uninterruptedly during
Ready mode, Low Power mode or printing.
• The temperature of the Heating Roller Thermistor/ 2 (TH3) is lower than a given level of degree for 1 second or more uninterruptedly during
Try resetting. To reset a Rank A error follow these steps:
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
Dec 17, 2007 | Konica Minolta bizhub C250 All-In-One...
Dryers Logo
27 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
