Question about Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera
I get a "Card locked"
  • Canon Master
  • 4,738 Answers
Move the tiny slide switch on the side of the card to its other position. Also, you should only be deleting pictures from your card using your camera's delete or format functions. Deleting from the computer may eventually corrupt your card. For more info, see this link.
Posted on Dec 31, 2010
I forget password of sandisk 2gb micro sd memory card
you can unlock your sd card by formatting*.
formatting memory card will delete all datas
formatting method*
use a softtwaer phone for formatting.. (example nokia 6120c, 5800etc )
insert your sd card into the softwaer phone.. select SETTINGS > DATA MGR > MEMORY > OPTIONS > FORMAT MEMORY CARD
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I have an Ultra II 4gb memory card that is locked and I can't seem to unlock it. I've tried from multiple cameras, card readers, and computers, but can't seem to get it to work.
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 11, 2011 | SanDisk Ultra II 2GB Secure Digital Memory...
I am unable to copy files to my memory card the system is displaying the error as " disk is write protected "
1.Look for a switch or button on the side of the micro SD card or adapter. It might have a lock/unlock symbol on it. 2.Move the switch to the "Unlocked" position to remove write protection. This position may also be labeled "R/W" for read/write. If you have no switch, continue to Step 3. 3.Download and install Sony EzRecover (see Resources for link) and attempt to use it to format the card (this will erase all content). If this doesn't work, try Step 4. 4.Delete and repartition the micro SD card using Windows XP. Select "Control Panel" > "Administrative Tools" > "Disk Management." Select the micro SD drive and click "Delete." Right-click on empty drive and select "New Partition."
Dec 22, 2010 | SanDisk 2GB microSD Memory Card
Delete images and videos
Using a card reader on your PC, simply highlight the files (.jpg and .avi) that you wish to remove and click on the delete key.
It will remove them from your Sandisk Micro SD card.
Apr 12, 2010 | SanDisk 2GB microSD Memory Card
I cannot delete images off my sd card because it says its write protected. How do I turn off the write protection on my SanDisk 2GB sd card? is there a setting on my computer that i can change?
Most likely, there is a switch on the side of the card. Flip it over from where it is now and then you should be good to go. If that doesn't work, select the file you are trying to delete and right click and go to properties, then unselect read only in the lower area of the window.
Dec 29, 2009 | SanDisk 2GB Secure Digital Memory Card
What type of SD card does the digital camcorder recommend? Will a 2GB DC card work?
You need a faster SD card for camcorders usually - checkout Sandisk Ultra II series. or Sandisk Extreme III
Dec 23, 2009 | Jazz DV-179 Digital Camera
Why would all my pictures disappear if i never deleted them.?
if you r sure that u havnt deleted then check if they are hidden or not, a virus can also affect the pics so beware of the virus!!!!! to check the hidden files click folder option then ckeckmark show hidden files and folder then apply and check ur pics.
Oct 16, 2009 | SanDisk 2GB microSD Memory Card
Memory card locked
On your SD card, there is a small tab near the top (similar to floppy a disks), just switch that the other way it should fix that lock error.
Jun 11, 2009 | SanDisk Ultra II 2GB Secure Digital Memory...
Not able to 'delete' a picture from my Lumix TZ3
Sounds like a MobileMate quirk Tanya. Use your USB cable connection to your PC/Camera interface and delete pics that way too see if this funny goes away.
If it does, and I believe it will, then it is a SanDisk issue not revising the File Allocation Table(FAT) after deleting the Pic File on the mem card.
You could also find out if this is just an SDHC SD card reader issue by using an older less dense standard 1 or 2Meg non-SDHC mem card in the reader and see if issue goes away.
The fallback of course to view and delete the pics on the camera before download, or download pics then note which pic file numbers you want deleted after viewing on PC, then put SD card back in camera and delete them there.
Another option for trial, is to cut and paste the whole DCIM folder, or sub pic folder to your PC from off the SD card using the card reader. The camera automatically generates subfolders under the DCIM folder if you completely remove(deleting by a cut or move), when you take your first picture on a camera with a DCIM but not sub pic folder. Try this first and I think you will find all pics will be deleted from camera that are in a subfolder under DCIM. If not, then cut or move the whole DCIM folder and create a new DCIM(empty) folder on the SD card using the PC and card reader. Of course using this method you cannot selective delete individual pics from the mem card. You would be deleting them all after the Folder cut or move from the SD card.
Dec 02, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Canon PowerShot SD1200 IS / Digital IXUS 95 IS Digital Camera Logo
94 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
