This
is pretty common and can be a pain. It's tacked in place with contact
cement or hot glue,
and sometimes there may have been enough moisture to corrode and seize
up.
You could heat it up
(hair dryer, maybe?) then use needle nose pliers. Be careful if heating
so you don't burn anything.
You
may be able to put the tips of needle nose pliers inside the broken
bulb's socket, gently but firmly force the pliers jaws apart and then
rotate the pliers to loosen it.
Another
cool trick is to put a big
glob of hot glue on the end of a stick or dowel, then shove it into the
broken base and let it cool about 5 minutes, then turn the stick.
I
like to put a little WD-40 or rust buster on the threads of the new
bulb, too. Grease, Vaseline, cooking oil, or anything like that will
work. Just a thin coat.
You can download GE
owner's manuals and installation instructions here.
It will have the part number of your bulb.
You can also find
helpful exploded view diagrams and order parts by entering your full
model number here.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
