Question about Sony VAIO Notebook
I wanna driver software and touchpad softwares and how to install...
    Brigadier General:
  • 8,909 Answers
Go to http//esupport.sony.com and follow the instructions after you have found the driver you require.
Posted on Dec 31, 2010
Touchpad scroll is not working
Have you installed the touchpad drivers and software?
Windows generic drivers, don't install that kind of things.
Go to HP website, download all touchpad drivers and software, and install them.
May 15, 2013 | Compaq Presario CQ60-220US PC Laptop
Keyboard working fine, touchpad is not working at all. have a mouse plugged into usb port. plugs from keyboard are in correct ports.
You may have to install the driver software for your keyboard to enable the touchpad to function. Did the keyboard come with a special installation CD? If not, visit the Solidtek website to download the software there.
May 05, 2011 | Solidtek Keyboard, Touchpad
My mouse pad in my computer wont work when i tap it
It will depend on what touch pad (and related software) is installed on the particular computer, but you will find the tap option under the Control Panel. Open your control panel, select "Mouse" There will be a TAB in the mouse properties called "touchpad" (surprise, surprise!) where you can toggle tapping on/off.
Hope this helps. PS: if you DONT see the touchpad option - you will first need to install the drivers/software for your touchpad. Most HP touchpads are the Synaptics Touch Pads - Find the drivers here: --> Click here!
Feb 07, 2011 | HP Computers & Internet
Dell touch pad stops working and starts working again in about 5 seconds. I just push my finger around the pad in circles until it starts moving again. This makes it very troublesome to play online...
its the software that is conflicting with your hardware, uninstall the new installed software, and if possible reinstall the fresh copy of OS.
Feb 14, 2010 | Dell F3534 Touchpad
My touchpad scroll not working
Problem with touchpad driver. Download and install latest driver from the manufacture's website (synaptics, alps...) if you know the driver name.
Else try the software DriverMAX
(downloadable at http://www.innovative-sol.com/drivermax/)
Im using DriverMAX. Its a good software that can automatically detect versions of drivers in our computer and update them if you have internet connection.
Also ensure that in startup programs (RUN>MSCONFIG) the touchpad driver entry is enabled!!
Oct 26, 2009 | BenQ Joybook 5100U Notebook
I have a Toshiba Tecra M8 and the touchpad stopped working. I can still use a USB mouse, but i've tried the FN F9 key to make sure that the touchpad is enabled but it still isn't working. Are there drivers...
Check in the device manager and see if the touchpad is listed under pointing devices.If it is not there try add hardware and see if it detects the hardware. If it is there check to see if it says device is working properly. Sometimes touchpads require software to operate properly so check and see if software was uninstalled. You can also download the drivers/software from Toshiba, try removing the touchpad in the device manager and then re-booting the computer. When windows re-boots it should start installing new hardware found. Use the driver/software you downloaded from Toshiba. If none of these work your touchpad may be bad.
Sep 05, 2009 | Toshiba Tecra® M8-ST3093 PC Notebook
Dell studio 1737 mousepad not working
You can try the steps below and this definately should fix the issue.
Download and install the latest touchpad driver:
Uninstall the touchpad driver:
1. Click the Start button, point to Settings, and then click Control Panel.
2. When the Control Panel window appears, double-click the Add or Remove Programs icon.
3. Locate the software for your keyboard or mouse in the list below.
• Microsoft IntelliPoint software
• Logitech software
• DellTouch software
• Synaptics software
• Alps software
• Set Point software
4. Click to highlight the device name and then click the Remove button.
5. Follow the prompts to uninstall the input device driver/software.
Download and Install the Latest Touchpad Driver Available:
Please follow the link below to install the latest touchpad driver.
http://tinyurl.com/5k9tth
1. Locate “Input device drivers” and click on (+) sign next to it.
2. Select “Touchpad”, click Download Now. You may receive a warning and an option to run or save the file.
3. Click Save.
4. When the Save As window appears, designate a folder (desktop) to save the file that is being downloaded, and then click Save.
5. When the download is complete, go to desktop and locate the same file.
6. Right click on it and run as administrator.
7. Click on allow and follow the simple instructions to update the touchpad driver.
Please do not forget to rate the solution.
Regards,
Musheer.
Jun 12, 2009 | Dell Studio 1737 Laptop
HP Pavilion DV1000 touchpad and keyboard freezes
sometimes its a hardware driver software and OS driver software conflict on touchpad. if after OS installation the touchpad is already detected, no need to install the touchpad driver. try disabling the touchpad driver you installed. hope this helps
May 30, 2009 | HP Pavilion dv1000 Notebook
The touchpad on my Inspiron 1521 will not left click. The cursor will move on screen and the right click button is still functional but the left button has lost all sensitivity. Any ideas on how to fix it?
You can try the steps below:
1.Click the Start button, point to Settings, and then click Control Panel.
2.When the Control Panel window appears, double-click the Add or Remove Programs icon.
3.Locate the software for your keyboard or mouse in the list below.
Logitech software
DellTouch software
Synaptics software
Alps software
Set Point software
4.Click to highlight the device name and then click the Remove button.
5.Follow the prompts to uninstall the input device driver/software.
http://tinyurl.com/4o6gq9
1.Locate “Input device drivers” and click on (+) sign next to it.
2.Select “Touchpad”, click Download Now. You may receive a warning and an option to run or save the file.
3.Click Save.
4.When the Save As window appears, designate a folder (desktop) to save the file that is being downloaded, and then click Save.
5.When the download is complete, go to desktop and locate the same file.
6.Right click on it and run as administrator.
7.Click on allow and follow the simple instructions to update the touchpad driver.
Regards,
Musheer.
May 05, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
I have dell inspiron 1525, the left touch pad key is not working..i did sray some dust remover spray thinking it might be a dust issue..it did work after that for couple of hours but then stopped...
You can try the steps below to fix the issue.
• Logitech software
• Alps software
http://tinyurl.com/3vlce4
3. Click Save.
Regards,
Musheer.
Mar 16, 2009 | Dell F3534 Touchpad
Sony VAIO Notebook Logo
23 people viewed this question
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
