Question about Whirlpool Refrigerators
Indoor icemaker not working - Whirlpool Refrigerators
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Jan 01, 2011
Summerhouse in wintertime, without indoor warming: can I use glycol to avoid frezzing?
I would not reccomend it,if it is something you dont want on your dishes and cookware its not a good idead to add to dishwasher. You could turn off water supply under sink start washer to relieve all pressure from supply line and remove drain hose from pump tolet out all water that it contained at all times. I would do this for dishwasher,washing machine and if equipped the water valve on the refrigerator icemaker.
Aug 17, 2011 | Dishwashers
Indoor icemake is jammed
you don't mention a model or type of icemaker, but here is what I have done in the past.
Sometimes the ice melts together (door left open, etc). Take out all your ice and put into an ice chest, making sure that any large pieces are discarded or used elsewhere. Clean out any ice or pieces on the ice feeder screw or arm. Then close the door and make sure the screw it is rotating without any ice in it.
If all is OK, then put the ice back in and that should solve the problem. Good luck.
Dec 10, 2010 | Whirlpool Refrigerators
Whirlpool indoor icemaker doesn't make ice, I unthawed it for 9 hrs and still no ice, what could be the problem
hi how are you....does the freezer have a button on the side for infrad ,if so you might have a problem with it...remove ice maker ,dump water out of it ..put back together....unplg cord to ref....wait 5 mins...plug in..see ice maker arm ,starts to move...or wait ,close door...come back in a couple of hours .see if it works...mike doctor airr appl.repair..843-384-8474...call if need assitance...
Mar 26, 2010 | Refrigerators
After 2yrs of not using the icemaker, moved
Good day,
Pour water from small paper cup until it near fills the well of the ice maker. With the lever down, close freezer door and wait 2 to 3 hours. If it dumps then the ice maker should be good, if not, replace ice maker.
If dumps O.K. then the dual water valve is bad, and needs replaced.
You should check the fill tube that runs from the back of the machine to see if it is blocked with ice. (requires removing ice maker) but even so, if it is iced, you'll need to clear, but the water valve in the back rear of the machine is leaking and still needs replaced.
Thanks for using FixYa
Dec 20, 2009 | Refrigerators
Whirlpool indoor ice maker not making ice
Could not locate your model number. However, Check fill tube for icemaker inside the freezer. Iced solid? replace water valve. No ice in fill tube? Get correct model number and resubmit your request.
Sep 11, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Not making ice, indoor water spout working
Check the temperature in the freezer. The temperature must be below 0 degrees for most icemakers to perform properly.
Jun 14, 2009 | Refrigerators
Ice smells.
If you have a silver metal braided line to water source that is your problem. Replace mine with a braided vinyl line and it cured it. ps flush new line for about two minutes.
Dec 29, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kitchen Aid indoor ice maker
hi there,
i would recommend a technician to help you with this. this part that fell out is from the motor head off the icemaker. have the technician put it back together and make sure that there is nothing else loose.
Jun 14, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Kenmore indoor icemaker frozen wil not dispense ice
Hi. I need more information to help you with your problem. Model number and a better discription of your problem. Will not come out of the ice maker itself or the ice dispenser? Thanks, Mack
Mar 23, 2008 | Refrigerators
Ice maker
By manually moving the ejector blades you have now broken the ice maker module. (The brain and the motor of the icemaker). Kitchenaid had a batch of thermostats that arent working properly in these Indoor ice makers. I reccommend getting an entire new IDIM icemaker. You will have the improved module whith stronger gears (however you still cannot manually move them) and the improved thermostat.
Nov 24, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
65 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
