Question about Motorola Mobility EQ7 Wireless Bluetooth HiFi Stereo Speaker 89243N 1 ea
I have a Motorokr EQ7 Bluetooth Speaker System. I've used it before with my Droid X without problems. Today, it is paired and connected but no audio on the EQ7 nor my Droid X. I've noticed that the red Microphone Mute Indicator on the EQ7 is flashing. This could be the problem. Is there a way to stop the Microphone Mute Indicator?
Problems to pair motorkr EQ5
Is the EQ5 in pairing mode? What happens when you search for the speaker?
Mark
Motorola Support
Aug 15, 2014 | Motorola Mobility Motorokr Eq5 Bluetooth...
My iPhone don't work with my Bluetooth speaker system
Paired is not connected. Connecting is the next step after pairing. Then make sure that the ilive speaker is set as the dudio output device.
Dec 22, 2013 | iLive Bluetooth Speaker System
I can't get my Braven 570 bluetooth speakers to connect to anything using bluetooth
Hi,these devices like bluetooth hand set or speakers must be paired in the master device,for example turn the speaker on make sure its blutooth is visible too all and find it with your phone device if your phone can see it try to go to option and make a new pair device,if your phone cant see it you may have problem with the speaker,try to read manual,if you still have problem,something goes wrong with device,and if it works successfully you can pair it in the laptops or PCs
kind regards
Apr 16, 2013 | Computers & Internet
I am pairing EQ7 to iPad. Sound is garbled and intermitent. Batteries are fine
Thats because your only paired with the phone. if you go to settings (assuming you have an android o.s) then "wireless and networks" then "bluetooth setting" you will see it only says "connected to (phone) not audio. This means your not completely paired. You will have to reset the speaker. Thats done by pressing the "skip back" and "skip forward" buttons at the same time until all the lights blink at the same time on the speaker. Usually 10 seconds. Then try to repair with the speaker. The code it will ask for (assuming you didnt change it from the factory settings)is 0000. That should work. Let me know if you ever have a problem with it being stuck on mute. Im still trying to figure that one out.
Feb 08, 2011 | Motorola Mobility EQ7 Wireless Bluetooth...
I have the droid backflip and my boss has the first droid from verizon, neither can find the bluetooth headphones (motorokr s9 black & red) how can i pair the headset to my phone if i cant find it
Make sure you put the headset into discoverable or pairing mode, there should be specific instructions that came with your head set to do this, then use the droid or the backflip to scan for the devices and it should find them.
Oct 18, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
Trying to connect motorola s9hd to the laptop
assuming you have bluetooth installed on your laptop,
1) you have to disable the bluetooth pairing of your s9 with another device that you may have paired with it earlier - like a mobile phone. disconnect previously paired devices first.
2) turn on the bluetooth feature on your pc and ask it to "search" for devices. assuming your s9 is on standby, your pc should be able to "locate" and pair with it assuming the s9 is within an arms length distance from the computer.
3) make sure that the s9 is completely charged to eliminate that power issues as well
Apr 07, 2009 | Motorola Mobility MOTOROKR S9 + Bluetooth...
Motorola Mobility EQ7 Wireless Bluetooth HiFi Stereo Speaker 89243N 1 ea Logo
157 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
