Question about Canon CanoScan N670U Flatbed Scanner
Change word changing word text from scanned image how do i do that please
  • 258 Answers
Some scanning software do not provide this option.
To check if yours has it, start the scanning software. preview and then when giving the file name see if you can put in a file type for word .doc or .docx
Posted on Jan 17, 2009
Change orientation on canon dr-7580 scanner
Two step process, scan and save the image, then print and select landscape
Sep 13, 2012 | Canon DR-7580
I have a problem after scanning, I cannot bring the document up in MS Word to edit. The document arrives on my computer screen but I can not edit it
You need OCR software installed in your PC
go to www.hp.com then type OCR application then download it in your pc
OCR Application File name: s.gif 23902_hpcom_OCR_120_003.exe [1/1, 54.84M]
http://h10025.www1.hp.com/ewfrf/wc/genericSoftwareDownloadIndex?cc=us&dlc=en&lc=en&softwareitem=oj-72836-2&jumpid=reg_R1002_USEN
Text Cannot Be Edited After It Is Scanned to a Word Processing Program
Issue After scanning into a word-processing program, the text in the original is not editable. Workaround The process of changing text from an image to editable text is called optical character recognition (OCR). Text should automatically be converted in the OCR process when the Send To destination is a word-processing program. If it does not, check the items in the following list:
  • Select Editable Text as the image type in Scan Settings . In Windows XP, this setting is automatically selected if Scan Document is selected in the Director program.
  • Scan at a resolution of at least 300 dots per inch (dpi) for correct OCR conversion. Check the default resolutions in the Scan Settings on the Resolution tab.
  • If portions of the scan are cut off, turn off the Auto Crop feature in the Scan Settings on the Scanning tab by clicking to clear the check mark.
  • Tables, text boxes, and spreadsheets might not be editable. The border around them makes the OCR program read them as images. Readiris OCR, which is included with the HP Officejet G and K series, can recognize these images. Instead of selecting the word-processing program in the Send To list, send the scan to Readiris. Use the Table Drawing tool on the right side of the window to change the type of image to a table, and then use the OCR. The text inside of the box should now be editable.
    NOTE: Handwritten messages might not be captured by the OCR process.
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | HP PSC 1315 All-In-One InkJet Printer
How do I change the default file format from Jpeg to PDF on a xerox M24??
The following information provides an Overview of the Printer's available Scan Settings. 1. To enter the Scan mode, from the Printer's Main (Copy) Screen press the Menu button.
2. On the two-button selection screen, press the right-hand Scan/E-mail button. Note: If you press the lefthand "Copy" button by mistake you will be returned to the Main (Copy) Screen. You will then have to press the Menu button again to return to the two-button selection screen.
3. The Scan screen consists of three Tabs, with each Tab displaying a number of feature settings. From left to right, the three Tabs are labeled: Basic Scanning, Scan Options, and Image Quality/File Format.
4. When the Basic Scanning Tab is selected, three columns of settings are displayed. The first (left-hand) column of settings contains four "Output Color" selections, including: Auto, Full Color, Grayscale (256G), and Black. The second (center) column of settings displays four scan resolutions. The available selections include: 200 dpi, 300 dpi, 400 dpi, and 600 dpi. The third (right-hand) column of settings displays "2 Sided Original" selections including: 1 Sided, 2 Sided (H to H), 2 Sided (H to T), and More.... If you press More..., a screen displays with two setting selection buttons on the left, enabling you to select either 1 Sided or 2 Sided. If you choose 1 Sided, you can select an original orientation of Head to Top, or Head to Left. If you choose 2 Sided, two additional orientation buttons (Head to Head, and Head to Toe) become available for your selection. Note: To support "2 Sided" (Duplex) Scanning you will need to use the Printer's Duplex Automatic Document Feeder. When changing or viewing More... settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
5. After an Output Color is selected from the first column of the Basic Scanning Tab, and the Image Quality/File Format Tab is pressed, a screen is displayed allowing you to choose and configure the settings for Original Type (Text & Photo, Text, Photo), Image Compression (High, Normal, Low), Contrast, File Format, and Auto Exposure.
- Press the Original Type button to select the most effective scanning for your original image type. Options are Text & Photo, Text, and Photo. - Press the File Format button to select your scanned file format. Options are TIFF/JPEG, JPEG, DocuWorks, and PDF. - Press the Lighter/Darker/Contrast button to adjust scanned image density (lightness and darkness) and contrast. Use the supplied arrows to make the desired setting adjustments. - Press the Image Compression button to set the degree of data compression, used especially with JPEG scans. Options are High, Normal (default), and Low. - Press the Auto Exposure button to enable or disable this scanning feature with the ON or OFF buttons. When changing or viewing settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
Mar 28, 2011 | Xerox Workcentre M24 Color Copier
My scanner is sending my scans as images not text.
you must convert to text, most scans save as pdf or tiff (yours is most likely a tiff) choose save as... and change extension to .wrd or .doc
Aug 04, 2009 | HP Photosmart C4580 All-in-One InkJet...
I want to scan text from a page.help me
While you are scanning an Doc, you need to change the scan type from Image to Doc.
Jul 16, 2009 | BenQ Scan to Web 4300U Flatbed Scanner
Can't change the text on a scanned document.
It sounds like you have scanned it as an image or a PDF.
If you want to edi it you will need to OCR the image (effectivly this means read it and convert it to text)
May 28, 2009 | Epson Stylus CX4200 All-In-One InkJet...
I am unable to edit documents that I have scanned. I have tried to download the OCR driver but I am still having a problem. Please help
If you are scanning text as an image, the image cannot be editred, because the computer doesn't know the image is text.
You have to scan with OCR to edit text.
You can use PaperPort to add text to scanned images
May 08, 2009 | Office Equipment & Supplies
Scanning a document so I can change text
1. Scan that document in 200 dpi grayscace mode.
2. Use any OCR Software (like omni page, ABBY) to convert this image into text.
3. then edit it.
Nov 27, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
EpsonCX3900 NOT SCANNING TEXT AND SAVING AS TEXT IN Vista
There is absolutely nothing wrong with either your system or the scanner device, its just quite normal the scanned document are often saved in PDF or a image file formats, All you need is a text converter software (OCR) through which you can convert the scanned image or PDF file to text document and the best part is that you can even edit the text of the scanned document and make changes if you would like to as well. Here is the link for the text converter software download.
http://www.charactell.com/scanstore/InstSocr.exe
Click on the link to download and install the software that you require.
Alternatively you can also copy and paste the link in your web b browser address bar and hit the enter key to start downloading wizard.
Regards
Malik Khan
Jan 21, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
Canon CanoScan N670U Flatbed Scanner Logo
old marine
old marine
