Question about Master Heaters Air Hogs Sharp Shooter Helicopter 1
When The helicopter is in the air it constantly spins no matter how much it is trimmed. The helicopter worked before perfectly and all the parts seem intact. When it spins it seems to try to calibrate itself or adjust because when I attempt to trim the helicopter it becomes more stable but then it suddenly spins much faster and makes a noise. It spins clockwise and I am turning the trim counter-clockwise. Everything else about the helicopter seems normal but it will not allow itself to be trimmed. It simply increases it's rate of spin if it becomes stable. One thing I noticed was that using different amounts of throttle appeared to make it either spin at a slower speed, or increase speed and make a strange noise. I know it is supposed to spin a bit more when more thrust is applied but this increase in spin was extremely rapid. The noise it makes seems like a familiar sound of a motor turning something into a different position and not the sound of something broken. We have tried removing all lighting but it it had no effect. We have other remote-controlled helicopters but they are not on at the same time. There does not seem to be any other form of interference which would affect it. I suspect it is trying to auto stabilize incorrectly, but what do I know.
  • 6 Answers
SOURCE: My Havoc Heli is really hard to control and I need help.
You have to keep tapping the right trim button. Keep tapping it until it stops spinning. If the spinning stops and it just turns, Use the the left right moving analog un til it flies straight.
Posted on Jun 30, 2009
SOURCE: i have an apache 3 channel helicopter.the top
Same problem I had. There are two motors. One to spin the top blade and a second to spin the bottom. My motor was defective out of the box to spin the top blade. Very poor quality as my AH 64 had a bad circuit board. I had to take parts from one to fix the other.
Posted on Sep 12, 2009
SOURCE: crashed blade 400 repaired it unsure of servo settings helicopter tilts forward and tends to spin around
dude is your swash plate levle if it is not it will cause your heli to drift
or if not go on youtube and reset your dx6i settings
Posted on Sep 29, 2009
SOURCE: silver bullet helicopter wont stop spinning counterclockwise
i would continue to hold the trim. this happended to mine and i held the trim for a couple of seconds and it leveled out. also i have a problem, mine wont generate enough lift to take off. do you have a solution for that?
Posted on Feb 17, 2010
SOURCE: Apache havoc micro... can not trim the helicopter
Another cause might be that the tail prop is slightly bent, so that even though it's spinning fast enough, it isn't cutting the air adequately to maintain stability. Check that the prop can lie flat across the back, or compare it with one of the extra props you have, and replace if necessary.
Posted on Jul 06, 2010
How could i use my iphone 4g to control my toy helicopter
    • 1 Remove the main rotor blades, throttle up the helicopter while holding it in your hand and twist the helicopter from side to side to determine if the gyro is working. The gyro should make the tail rotor spin faster when the helicopter twists; you will be able to hear a difference. If the gyro does not appear to be working, replace it. Some gyros have a sensitivity adjustment screw; try making small adjustments if possible.
    • 2 Check the tail rotors and see if they are connected correctly. If the tail rotor blades are not pitched correctly they will not be able to hold the helicopter still.
    • 3 Test the tail rotor motor and see if it seems strong and responsive. Brushed motors, like those commonly used to drive tail rotors, can wear out in a relatively short time. Replacing the motor may solve your problem if the gyro seems to be working.
    • 4 Check the trim on your transmitter. Ideally the trim should be in the center of the stick movement. You may need to dial in some extra right trim or you may find the trim is set too far to the left.
Jan 20, 2013 | Toys
How to correct trimming problems did what the insteuctions said and keep having the same spinning counterclockwise problem
Just bought the air hogs helicopter with the crane. Had the aircraft constantly spinning clockwise, no matter how much I turned the trim control counter clockwise the aircraft still rotated. I then turned the trim control in the opposite direction until I noticed the aircraft had stopped spinning, and used the rudder control to fine tune forward flight. So, get the aircraft to hover and turn the trim button in the opposite direction until you see that the aircraft spinning slows right down. If you continue to turn the trim control in the same direction the aircraft will increase its spin, so just dial back the trim.
Dec 29, 2012 | Air Hogs Havoc Heli Helicopters
Spins counterclockwise...already adjusted trim
This problem can be especially confounding because the way the copter distributes torque on a slick floor can be a spin opposite to what you see in the air!
The solution is to get the machine in the air quickly and make your trim adjustment based on that. The tail rotor is very sensitive as you know so you need to be working that stick constantly to acheive trim, this is part of what flying an RC copter is all about. A four channel copter is much harder to fly but your dragonfly can prepare you for this.
Dec 24, 2010 | Jumbo RC JUMBO HELICOPTER
My son's helicopter just spins around and won't lift up anymore. It has been sitting for about a month, but worked fine before that. Any solutions? Could the blades have been bent? They don't look like...
replace batteries with new ones and then you let it spin while you trim it out by pushing rotor button ,for heli that spins clockwise push trim button on left side and a heli that spins counter clockwise push trim button on right side continue pushing the corrective button until spining slows and eventually your sons heli will fly straight again these instructions are in the owners manual
Nov 28, 2010 | Air Hogs Havoc Heli Helicopters
Ive a s006 alloy shark remote controlled helicopter and i need to adjust it so it stops spining around but instructions arent clear
have you tried using the trim buttons?,after take off when its around 2ft in the air if the tail spins to the right tap the left trim button a few times and if its spinning left tap the right button a few times and this should stop it spinning it works ok on my one
Apr 28, 2010 | Head Cover For Syma Alloy Shark Rc...
Heli spins counter clockwise
See solution 2 for post "How do i fly my spin master air hog rc helicopter?"
Jan 03, 2010 | Spinmaster Air Hogs RC Reflex Micro...
Helicopter keeps spinning in circles and won't lift.
There is a "trim button" on the controller. Ex: if the helicopter is spinning left, press the "R" trim button repeatedly. Takes a little practice to get it down to flying with out hitting anything. Good luck.
May 17, 2009 | Spinmaster Air Hogs RC Reflex Micro...
Where can I get copy of instructons - Air SBEGO Mini IR Helicoper
have you made sure that the helicopter is charged completely?
if so when you try to take off if it spins to the left then hit the r trim on the remote and if it spins to the right then hit the l trim on the controller.
honestly all the instructions do is tell you how to put batteries in the controller.
Dec 30, 2008 | Sky I Blade Mini IR Helicopter W/ Remote...
Master Heaters Air Hogs Sharp Shooter Helicopter  1 Logo
60 people viewed this question
Top Master Heaters Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Master Heaters Toy Expert? Answer questions, earn points and help others
