Question about JVC HA-G55 Consumer Headphones
I have old JVC headphones - model HA-D40. The audio still works well but the ear piece covers have deteriorated. Can you recommend a way to replace these ear pads. They are slightly oval and about 3 3/4 by just under 4" in dimension.
5 Suggested Answers
SOURCE: how do i change the batteries on my ha-w500rf
Remove the ear pad on the Left ear which has the power switch on,
The remove the 4 screws, then there are two silver screws holding the outer cover in place, remove these and then tae the cover off.
You will see there are two AA Ni-Cd batteries inside these can be replaced ith any rechargable batteries you wish
Posted on Jun 18, 2010
Grubhead
  • 5487 Answers
SOURCE: JVC HA-S700 Cable Problem
You might want to check out my tip on dealing with dodgy plugs/cable on headphones.
Posted on Jul 11, 2010
Grubhead
  • 5487 Answers
SOURCE: need headphone pad
Try E-Bay!
  • 7 Answers
SOURCE: The headphones have stopped working
Andrewjdonne,
This is usually caused by a short in a wire. If you are brave, you can open up the headphones and find the wire that has shorted out and repair it. Usually this happens at the point where the headphones pivot. This may require the use of a soldering gun, or at least some new wire and electrical tape. Nothing you can't find at radioshack. Let me know if you need help opening the casing up to find the bad connection!
~Kudos~
Posted on May 04, 2011
Ha-nc100 replacement earpads cushion
CHECK YOUR LOCAL CRAIGSLIST, EBAY, OR AMAZON. THEY SELL HEADPHONES THAT EITHER ARE FOR PARTS OR HAVE BOTH CUSHIONS AND BEING IN WORKING ORDER.
I ALSO SUGGEST FOR YOU TO CHECK:
http://www.jvc.com
OR
SEARCH GOOGLE BY INSERTING THE FOLLOWING WITHIN THE SEARCH BAR: " BUY CHEAP HEADPHONE CUSHION FOR AN; HA NC100 SET OF HEADPHONES"
IN YAHOO SEARCH BAR YOU CAN TYPE:
" DOES ANYONE KNOW WHERE I CAN BY AN HEADPHONE CUSHION FOR JVC HA NC 100 HEADPHONES,
OR
DOES ANYONE GOT A SET OF JVC HA NC100 HEADPHONES FOR SALE THAT MAY BE USED FOR PARTS OR EQUIPPED WITH BOTH CUSHIONS THAT ARE IN PROPER WORKING CONDITION?"
I ALSO SUGGEST TO CHECK www.overstock.com
Dec 02, 2013 | JVC HA-NC100 Consumer Headphones
Jvc headphones retractable cord
The JVC HA-NC250s are a new version of their previous model 100, and JVC claims that they will cancel up to 85% of ambient noise, coupled with better sound. In this case, JVC claims up to 16.5 db reduction at 150 kHz. These on-the-ear headphones are very lightweight at 5.3 ounces and are extremely comfortable. The head band has a reasonable amount of sliding expansion for bigger heads, and the oblong ear pieces themselves rotate and fold flat for storage. JVC uses memory foam on the earpieces, as well as double housing, for extra noise isolation. The earpieces have 40 mm neodymium drivers, which are the same size and type that the Creative Aurvanas offer.The JVC HA-NC250 noise canceling headphones. Note the ear-cushion instruction tab that explains how to replace the hidden battery.
The NC250s come in a semi-rigid black case with a dual airline-plug adapter, a mini-to-RCA phono plug adapter and a 4' detachable headphone cord. JVC includes one AAA battery, which should last approximately 50 hours. A simple sliding switch on the right side turns the noise reduction on along with a small red LED. Learning how to add the battery to the headphones required that I study JVC's user manual. The process involves having to remove the earpiece covering to get to the battery compartment, which isn't at all obvious.
Jul 22, 2012 | Audio Players & Recorders
After soldering, my left ear piece sounds lower than the right piece
More likely the heat from the soldering iron has damaged the earpiece speaker. The cone is plastic film.
Oct 03, 2017 | JVC Air-Cushion Headphones HA-FX66W
The headphones have stopped working in the left ear. They are jvc ha-v570 headphones. Is there anything i can do?
Andrewjdonne,
~Kudos~
May 03, 2011 | JVC HAV570 Consumer Headphones
There is constant static in the left ear when the noise cancelling is turned on. The only way to solve this is to turn the noise cancelling feature off. Is there another solution?
these things are suppost to have a little static noise when on. next time get noise reduction headphones. they are like headphone style ear protection like what construction workers use. but only more stylish and they contain speakers. and no killing batteries for good sound. they are regular headphones but with really good sound isolation
Oct 25, 2010 | JVC HA-NC250 Headphones
My dog chewed on earphone and the sound is all crackly. Is it possible to get one fixed and what would it cost?
HI. If your dog chewed on the actual hardware and wire strands, this will not be repairable. The strands that carry the actual sound data stream have been compromised and separated from the main strand that runs through the ear piece. This type of trauma cannot be repaired, unfortunately. You will need to replace the entire ear piece set. I can understand that you want to repair and not replace, but this will be the only option in your case. You will need to replace the entire ear piece set or deal with that deteriorating sound quality.
Aug 30, 2010 | Bose in-ear headphones - Black with...
How do you Fix earphone?
It may be the plug end and not the ear piece itself. Usually the problem is the plug, rather than the phones themselves.
Feb 09, 2018 | JVC HA-FX66A Consumer Headphones
I need replacement ear cushions as the originals have virtually dissolved into dust. Does anyone know who might be able to supply these?
Maplin might have some universal type ones. You could also salvage some of a cheaper brand new type, if you can find one the same size as the JVC.
Nov 12, 2009 | JVC HA-D690 Consumer Headphones
How do i change the batteries on my ha-w500rf jvc headphones
Sep 09, 2009 | Audio Players & Recorders
JVC HA-G55 Consumer Headphones Logo
149 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
