Question about Polaroid FLM-4034B 40 in. LCD HDTV
I got no power. tried to fix the humming nois and then nothing. Can I order a new power supply panal from you?
    Master:
  • 691 Answers
You can order from shopjimmy.com or discount-merchant.com
Posted on Dec 31, 2010
The control panal on my weslo cadence treadmill is not working
Do the following :
1) Lube the deck belt follow the instruction manual, maybe the deck is worn.
2) Lube the roller bearing.
3) Align the deck belt.
4) Test the drive bel.
5) Test the input voltage motor, if there are the motor need repair.
6) Test the output voltage board, for input voltage motor, if there are not The board is faulyt.
7) Run the software calibration for diagose, troubleshooting, and fix it, follow the steps from instruction manual.
8) Adjust the Reed switch, clean, and tight the connector very well.
sincerely. God bless you.
May 06, 2012 | Exercise & Fitness
Power supply irratating hum
1st of all, are you sure it's the Power supply that is humming and not one of the Cooling Fans inside - Cooling fans are often a lot more noisy than power supplies. However, if it's definitely the power supply there's a couple of things you can try.
1st of all, it's never a bad thing to get your vaccuum cleaner out and (on a low power setting with the computer turned off) just vacuum out any dust that might be in the fan of the power supply.
2nd: Is the hum coming from the power supply itself or from something the power supply is vibrating against - try moving the unit a little, and ensuring that there's nothing wresting against it.
I'm presuming you've checked the cabling and ensured that the power cable (from the wall) is firmly connected? If you haven't checked that.
3rd - if you feel confident doing this, turn off the pc, open the case and just check to make sure that there are no internal cable resting on fans or on the power supply. Lastly, if none of things fixes the problem and your machine is under warranty, I'd send it/take it back to the place you bought it from for a replacement (remember to back up any data you have on your computer first though otherwise you'll lose it)
Mar 03, 2011 | Acer Gateway DX483105 Desktop PC Intel...
Trying to find which fuse goes to the rear window washer.
First have someone stand near the washer resivor while another person trys the switch to wash it. Listen for the motor to hum. If nothing is humming then you can check the fuses. If it is humming then make sure the resivor is full of fluid. There is a panal on the right hand passenger side in the rear where the resivor should be located. If not right then check left. Its back there some place.
Once you have checked that and no go get back to me and I will help you find the fuse. The Raz
Apr 17, 2010 | 2008 Nissan Armada
Loud humm when the drive channel is on
I suspect the power supply has an issue. Most likely bad filter capacitors. This could cause "motorboating" where power is drawn and supply voltage collapses and then recovers repeatedly.
Time for the repair shop. The parts cost should be nominal... labor... well...
Mar 15, 2010 | Fender Hot Rod Deluxe Guitar Combo...
My tv is ringing, how can I fix?
is it like a buzzing sound? is so then it would be coming from your speakers. and would possibly mean a new sound board is in order. another possibility is that their is a hum from the power supply unit. but that's the power control board on the tv. this can also cause audible humming. if it sounds like a high voltage hum from a 60 hertz cycle then it is the power modal on the board failing more then likely.
good luck with it. and get a second opinion as i can easily be wrong. thanks for using fixya
Oct 05, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Low Hum Noise in Bearcat III Scanner
Yes, it does sound like a bad power transformer. Try powering it using a DC supply or battery and see if the hum goes away.
Mar 27, 2009 | Uniden BC60XLT-1 Handheld Scanner
EMachine will not turn on.
Sounds like the power supply is faulty. Power supplies are very dangerous to try and repair, even for qualified technicians. I would also suggest not trying to plug it in or turn it on until the new power supply is in place. Faulty power supplies have been known to cause motherboards to permanently malfunction. Note: researching your issue, I came across several forum posts with complaints about emachines and their power supplies. The best way to solve this problem is to purchase a new power supply. If shopping online, www.tigerdirect.com and www.newegg.com are two places that specialize in PC hardware. A 400-watt power supply would probably more than do the trick for you. The cheapest one I found was $18.00. Make sure the power supply is compatible with your motherboard before you buy.
Dec 27, 2008 | E-Machines eMachines Desktop PC
No Picture on PDP4294
Normally the sets have seperate power supplies for the input/main logic board and the HV which drives the panal (could be 2 parts on the same board). It sounds like you have a problem with the power board that drives the panal and HV. Check to see if any fuses are blown, if the fuse is blown, you can try replacing it, but if it continues to pop, then the main fets that drive the HV are shot and will need to be replaced.
Apr 13, 2008 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Polaroid FLM-4034B 40 in. LCD HDTV Logo
59 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
